Old 21st February 2023, 00:15   #1  |  Link
kolak
Video segments detection
Is it possible to detect black, video bars, silence, freeze frames through vs with some log with frame numbers?
Old 22nd February 2023, 07:07   #2  |  Link
_Al_
Four questions , pretty heavily compressed. :-)
Black could be detected using PlaneStats with some threshold and checking max values.
Video bars (of known type? Check diff) or check for gray left,right and green in the middle.
Detect silence perhaps not, because vapoursynth cannot evaluate audio, FrameEval would not work (could be wrong).
Freeze frames check for differences using PlaneStats or Diff to detect no changes within a threshold limit,
all DIY stuff.
The easiest part would be actually to print results using matplotlib.
_Al_ is offline   Reply With Quote
Old 23rd February 2023, 01:31   #3  |  Link
kolak
Which bring us to the point where using ffmpeg is way easier
Old 23rd February 2023, 06:55   #4  |  Link
_Al_
Including those plots? :-) ffmpeg does what it can do. All of us using it for a reason.
As soon as you get python going though, it seams like there is no limit (tapping into C libraries of course).
Old 23rd February 2023, 19:37   #5  |  Link
kolak
Yes, but in this case I need just numbers and getting these is way easier with ffmpeg. Black, freeze frame and silent detection filters work quite well in ffmpeg.
Then I need to generate FCP XML to create a timeline. This is more tricky, but doable.
It will be all Python based (which I can do), but only at basic level.
