Old 6th October 2022, 15:09   #1  |  Link
retaining1
What is the best filter I should use in this specific case?
I have some files, and I want to reduce their size to 99MB exactly (I use x264 2pass), usually the files are in 720p and average 400~500MB.
I would like to remove the noise to exactly the same as it is in this image below: (left as I want, right is how my encode is coming out).
Can anyone tell me which noise filter I should use?
retaining1 is offline   Reply With Quote
Old 6th October 2022, 17:03   #2  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Bitrate is too low and hence you are getting visible macroblocks in encoded footage.
Old 6th October 2022, 18:14   #3  |  Link
retaining1
Yes, I know that, but this image you see on the left also uses the same bitrate encoding, with 2pass 99MB output, but it uses some filter that smoothes the macroblocks, do you have any idea?
Old 6th October 2022, 20:50   #4  |  Link
Atak_Snajpera
You may try MDegrain filter
Old 7th October 2022, 02:03   #5  |  Link
TDS
Formally known as .......
TDS's Avatar
Firstly, what encoding app are you using ??
And how do you expect to get decent quality at that file size. !!!
I would strongly suggest using some SMDegrain pre or sub filter.
Check this out:-
https://forum.doom9.org/showthread.php?t=182881
Long term RipBot264 user.
RipBot264 modded builds..
TDS is offline   Reply With Quote
Old 7th October 2022, 23:16   #6  |  Link
retaining1
Check this out:-
Im Using StaxRip, I tried MDegrain, but the encoder time from 4 minutes went up to 3 hours, the problem is not the quality, the quality is exactly the same as the photo on the left, the difference is exactly in the smoothness, the one on the left has the impression of better quality because the macroblocks do not appear(because of the smoothness), but the quality is exactly the same, there is no difference, the difference is the smoothness! I will send you 2 links for you to compare the videos in real time.
take note that the file on the left which I want to get to the same filter, was also encoded at 99mb.
Old 9th October 2022, 13:40   #7  |  Link
TDS
TDS's Avatar
https://assistonlineapi.online/make/...0abf1d29be9126 (left)
https://assistonlineapi.online/make/...4e0f51ce159062 (my encode)
It would have been better if you had of uploaded the actual file you're working with, instead of that.
But it looks like the "original" is pretty bad quality to start with
Not too much you can do with that..
Old 9th October 2022, 18:48   #8  |  Link
rwill
With which x264 settings is that? default?
I think x264 psy-rd could cause such blocking and does not work well at low rates.
Have you tried with "--tune ssim" or even "--tune psnr" for getting rid of the little blocks? Maybe increase deblock to 1:1 or 2:2 ?
Old 10th October 2022, 05:50   #9  |  Link
retaining1
yes default, thank you for your tips, improved a lot, I'm using it too Depth 10-bit, helped.
Old 10th October 2022, 06:23   #10  |  Link
rwill
Well don't use 10bit with H.264, its a decoder compatibility nightmare. Low rates do not really benefit much from high bitdepth anyway.
Old 10th October 2022, 23:55   #11  |  Link
retaining1
Thanks for the info, it helped a lot =)
encoding, filter, staxrip
