3rd October 2022, 19:50 | #21 | Link | |
3rd October 2022, 23:07 | #22 | Link |
SuperVirus
You don't get it.
(OR you just pretend that you don't :-/) Dolby bought MLP from Meridian, ""upgraded"" MLP to TrueHD, but today dares to sell an encoder that DOES NOT DO everything the TrueHD format specification allows. This is what I meant when I said that the DLLs and EXEs used by dee suck. By the way... and now going off-topic... please stop trying to ""correct"" me. It didn't work on your GitHub and it will surely not work here on Doom9. I rarely lie because I'm a terrible liar and I rarely am wrong because I normally know very-well what I talk about.😇
«Your software patents have expired.» Last edited by filler56789; 3rd October 2022 at 23:09. Reason: .......... |
4th October 2022, 00:59 | #23 | Link |
I didn't correct you, I was stating facts. SeeMoreDigital asked why the dialnorm was measured at -9dB. Your reply suggested that the measurement implementation is not correct which it is. On GitHub you were saying bullshit like developers are narrow minded for not supporting OSes that reached their EOL (Win 7): https://github.com/pcroland/deew/issues/34
4th October 2022, 02:00 | #24 | Link | |
10th October 2022, 06:24 | #27 | Link |
SuperVirus
DEE ran fine on my jurassic Core2 Quad.
{{ And FWIW, the GUI of DME also works fine under Windows 7, BUT its internal server requires Windows 8.1 (minimum).🤦 }} Therefore what ""people"" said is not true. Fortunately (and wisely) I turned off the notifications from pcroland's repository.
«Your software patents have expired.» |
14th October 2022, 22:12 | #29 | Link | |
There was another comment saying it works without it, too bad you turned off notifications :'( |
2nd November 2022, 10:30 | #31 | Link |
Acid fr0g
There is a strange behaviour of deew with two similar files. The first one is
Audio Format : DTS ES XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Bit rate mode : Variable / Constant / Constant Bit rate : Unknown / 1 509 kb/s / 1 509 kb/s Channel(s) : 7 channels / 7 channels / 6 channels Channel layout : C L R Ls Rs LFE Cb / C L R Ls Rs Cb LFE / C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 16 bits Compression mode : Lossless / Lossy / Lossy while the other is Audio Format : DTS ES XXCH XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Bit rate mode : Variable / Constant / Constant Bit rate : Unknown / 1 509 kb/s / 1 509 kb/s Channel(s) : 7 channels / 7 channels / 6 channels Channel layout : C L R Ls Rs LFE Cb / C L R Ls Rs Cb LFE / C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 16 bits Compression mode : Lossless / Lossy / Lossy The first one is accepted by deew, while the second one gives me the error ERROR: number of input channels can only be 1, 2, 6 or 8. Any idea about why?
@turment on Telegram |
2nd November 2022, 11:33 | #32 | Link |
Because the first one is DTS ES XLL 6.1 matrixed: the Cb channel are mixed inside Ls Rs, don't exist like a independent channel. The file is decoded to 5.1 (even the MA) and supported by dee.
The second one is DTS ES XXCH XLL 6.1 discrete: the Cb channel exist like independent channel. The file is decoded to 6.1 (even the core) and it is not supported by dee. Use Audition/TotalCode to EAC3 6.1 or down/up the 6.1 to 5.1/7.1 and dee
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 2nd November 2022 at 11:39. |
22nd April 2023, 14:57 | #36 | Link |
deew 3.0.0: - added AC4 immersive stere support by MartinEesmaa - add "dee_audio_filter_ac4_ims.dll" and "Object_0000.exe" from the AC4 zip to your DEE installation path and add "ac4_2_0 = 320" under the "[default_bitrates]" section in your config file. - mono input for TrueHD encoding error handling - FLAC recommendation prompt for lossless mono/stereo encoding |
