24th April 2022, 22:16 | #61 | Link | |
Broadcast Encoder
Sometimes I get 10bit sources I don't have to apply any post processing to 'cause they're already fine and I'd just like to encode them to 10bit H.264, so going from 10bit planar to 16bit and then back to 10bit is a bit of a waste. I just wish x264 supported all Avisynth high bit depth input (10bit, 12bit, 14bit) and not just 8bit and 16bit... |
24th April 2022, 23:43 | #62 | Link | |
I think it's because of the old avs demuxer, where pixel formats such as yuv422p10 were not supported...I would think it should be possible to update it... Or if you use avs to raw pipe, or ffmpeg libx264 with avs input - there is no up/down conversion |
20th May 2022, 22:09 | #63 | Link |
No, 8 bit is always lossless with crf 0. It is just that profile high10 is in by itself not lossless so crf 0 for high10 is also not lossless, you need to force high444 [predictive] to do 10 bit lossless and that is what qp 0 does.
22nd September 2022, 20:57 | #66 | Link | |
