Old 6th August 2021, 17:47   #1  |  Link
ashlar42
Dolby Vision on PC. Technically impossible or a matter of time?
Time and again we have seen the rise of "undefeatable" copy protection schemes only to have them defeated.
Now, for Dolby Vision currently only products that have Dolby's license can playback stuff. And no current PC GPU has that.
From the bottom of my ignorance I am wondering if the hardware is all in place for DV playback on PC and it's just a matter of understanding how to get around the DRM/Widevine/whatever thing or if there is a physical impossibility at work.
LG 77C1 - Denon AVC-X3800H - Windows 10 Pro 22H2 - Kodi DSPlayer (LAV Filters, xySubFilter, madVR, Sanear) - RTX 4070 - Ryzen 5 3600 - 16GB RAM
Old 6th August 2021, 17:54   #2  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Both Dell and Lenovo offer laptop PC's that support Dolby Vision...
Links: Dell's XPS 13 and Lenovo's ThinkPad X1 Extreme
Old 6th August 2021, 20:05   #3  |  Link
quietvoid
Requires licensed hardware on Windows.
Maybe the GPU APIs could be used somehow, since games support it..
LG C2 OLED | GitHub Projects
quietvoid is offline   Reply With Quote
Old 7th August 2021, 00:03   #4  |  Link
Asmodian
Playback of Dolby Vision bluray on the device?
madVR options explained
Old 7th August 2021, 12:11   #5  |  Link
ashlar42
I am aware of that. But in the case of TV led DV, from what I understand, the player simply passes on info to the TV.
So my question might be: is it just a DRM thing or is there something else at play?
Old 7th August 2021, 12:14   #6  |  Link
chros
chros's Avatar
Depends, e.g. with profile 7 FEL UHD BD titles the player itself combines the 2 layers together not the TV even with TV-led (that's why it still works with CX/C1 that doesn't have dual DoVi decoder chip).
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config
Old 8th August 2021, 12:14   #7  |  Link
ashlar42
Wow, another choice to gimp the sets after 9 series? DTS wasn't enough?
Old 2nd December 2021, 23:01   #8  |  Link
ashlar42
Now that DV in mkv container is happening (with the two video streams inside), I am wondering if somebody could devise something that, I guess at video renderer level, tone maps HDR10 dynamically based on DV info in the extra stream. I can't believe the industry has finally devised a way to restrict HTPCs from having best quality. :-(
Old 2nd December 2021, 23:17   #9  |  Link
nevcairiel
There is some movement to allow DoVi profile 5 and profile 8 to be played, and either tonemapped or converted to PQ/HDR10. Dual layer profile 7 (as found on Blu-ray) will require more work.
It's a start and allows playback of those profile 5 files in correct colors, as well as benefit from the profile 8 enhancements, as small as those actually are.
Pass-through of DV data to the TV remains an open problem, as there are no hardware APIs to do that, or it's unknown how to do it otherwise.
Old 3rd December 2021, 18:17   #10  |  Link
ashlar42
Oh... wow! So it wasn't a stupid idea. Glad to see this is being worked on.
This at video render level or codec level? Just curious. For now I'm glad for this update. :-)
Edit: any link to discussions where these developments are being discussed, etc.?
Old 3rd December 2021, 21:49   #11  |  Link
clsid
FFmpeg recently gained the ability to export the DV RPU metadata.
The conversion step to HDR10 is still missing. But maybe nevcairiel has a nice Christmas present for us, and that appears in a future LAVFilters release.
MPC-HC 2.2.1
Old 3rd December 2021, 22:54   #12  |  Link
quietvoid
Rendering. See https://code.videolan.org/videolan/l...e_requests/207
Old 4th December 2021, 15:31   #13  |  Link
ashlar42
Thanks for the extra info. Definitely something to look forward to, crossing fingers. :-)
Old 5th December 2021, 00:19   #14  |  Link
ashlar42
Wow. Merged already. Don't know the relation between work happening on VideoLAN and ffmpeg (and all projects based on it).
Old 26th January 2022, 23:02   #15  |  Link
dbezerra
Quietvoid, I see that DV can now be used with MPV as well. I have been playing with MPV as a secondary option (comparing it with MadVR) and DV support sounds really interesting! However, I am not sure how I should adapt my current tone mapping settings - any advice?
Right now I have the following: My goal is to output SDR with BT.2020 as I am using a JVC projector (RS500).
hdr-compute-peak = yes
target-prim= bt.2020
target-trc= gamma2.4
target-peak=100
tone-mapping=mobius
dbezerra is offline   Reply With Quote
Old 26th January 2022, 23:09   #16  |  Link
quietvoid
Tone mapping preference is highly subjective.
Currently this is my config:
hdr-compute-peak=yes
tone-mapping=bt.2390
tone-mapping-param=2.00
gamut-mapping-mode=clip
There are however pretty bad bugs with the new/current tone mapping.
My setup is a simple SDR display calibrated to 130 nits, however ICC profiles are somewhat broken with HDR at the moment.
Old 26th January 2022, 23:17   #17  |  Link
dbezerra
Thanks. And those settings are using vo=gpu-next and dolbyvision=yes, correct?
Old 26th January 2022, 23:31   #18  |  Link
quietvoid
Yes vo=gpu-next. Dolby Vision is mapped automatically, so it's not necessary to use the vf.
Old 4th February 2022, 08:28   #19  |  Link
sarsaK
hello, what should i do for dolby vision like hdr when creating MPV profiles what should i change for dv in below code (profile-desc=cond["video-params/primaries"]=="bt.2020")
sarsaK is offline   Reply With Quote
Old 4th February 2022, 15:36   #20  |  Link
quietvoid
I don't think there's a way to detect it, the video has no useful VUI.
