Old 1st August 2021, 12:26   #41  |  Link
WolframRhodium
Originally Posted by tormento View Post
Does Test2 work for CUDA too or is it AVX2 bonded?
Both are included and are implemented in different dlls.
WolframRhodium is offline   Reply With Quote
Old 1st August 2021, 12:36   #42  |  Link
real.finder
ColorBars(width=640, height=480, pixel_type="yv12")
LoadPlugin("BM3DCPU_AVS.dll")
ConvertBits(bits=32)
BM3D_cpu(sigma=0.5, radius=2)
BM3D_VAggregate(radius=2)
ConvertBits(8)
22 fps with no mt (no Prefetch) on i7-8700
I have a question about BM3D_VAggregate, it's cpu only? and seems it's Duplicate in both cpu and cuda dlls and that seems not ok
See My Avisynth Stuff
Old 1st August 2021, 13:20   #43  |  Link
WolframRhodium
ConvertBits(8)
It's cpu only since its performance is limited by memory bandwidth and has low arithmetic intensity. Test2 moved that function to the cpu dll so there should be no conflict.
Old 2nd August 2021, 09:25   #44  |  Link
tormento
Acid fr0g
tormento's Avatar
Any changelog for test2 on CUDA?
@turment on Telegram
Old 2nd August 2021, 09:32   #45  |  Link
kedautinh12
Read readme file in file downloaded
Old 2nd August 2021, 11:29   #46  |  Link
WolframRhodium
Nothing besides now it depends on the CPU version on VAggregate.
Old 3rd August 2021, 00:58   #47  |  Link
Reel.Deel
Any possibility of also supporting AVX? I see the VS version supports it, according to the documentation: The cpu version is implemented in AVX/AVX2 intrinsics...
Old 3rd August 2021, 01:48   #48  |  Link
kedautinh12
But in Requirements, he wrote only AVX2
Old 3rd August 2021, 02:08   #49  |  Link
WolframRhodium
I mean AVX and AVX2 intrinsics. Sorry for the confusion.
Old 3rd August 2021, 02:44   #50  |  Link
Reel.Deel
Ahh gotcha, I guess that explains this error in AVSMeter:
Exception: 0xC000001D [STATUS_ILLEGAL_INSTRUCTION]
Module: BM3DCPU_AVS.dll
Address: 0x000007FEC45204E6
Figured it was worth asking about AVX since I see just "AVX" in the requirements of the VS version, but in other parts it says AVX/AVX2.... well I guess that leaves me out of it till I build my next PC
Old 5th August 2021, 20:24   #51  |  Link
tormento
Acid fr0g
tormento's Avatar
I am having AVS+ exception error when using test2 on the following script:
SetMemoryMax()
SetFilterMTMode("DEFAULT_MT_MODE", 2)
LoadPlugin("D:\Eseguibili\Media\DGDecNV\DGDecodeNV.dll")
DGSource("F:\In\1_33 Grosso guaio a Chinatown\grosso.dgi",ct=132,cb=132,cl=0,cr=0)
BM3D_cuda(sigma=0.5, radius=2)
ConvertBits(16)
Prefetch(6)
I am using a SandyBridge with no AVX2 but it should give no error with the CUDA version. Am I doing something wrong?
Old 5th August 2021, 20:39   #52  |  Link
Reel.Deel
"BM3D_CUDA" depends on "BM3D_CPU" for temporal denoising. In other words, avx2 capable processor is required.
@WolframRhodium
Since the first test version worked on the gpu only, would it be possible to add a parameter to force gpu processing only? For those that do not have avx2.
Old 5th August 2021, 20:41   #53  |  Link
tormento
Acid fr0g
tormento's Avatar
I think it would be easier to provide 2 versions as every script author should otherwise check if cpu supports avx2 and I don't know if there is such capability in AVS+.
Old 5th August 2021, 23:41   #54  |  Link
kedautinh12
SetMemoryMax()
ConvertBits(16)
Prefetch(6)
Of course BM3D_VAggregate() move to BM3DCPU in test2, try delete BM3D_VAggregate() and check script again
Old 6th August 2021, 06:51   #55  |  Link
WolframRhodium
Thanks for the report. Please check the latest version (test3). I separate VAggregate from BM3D_CPU.
Old 6th August 2021, 10:30   #56  |  Link
tormento
Acid fr0g
tormento's Avatar
No offense, I know you try to help, but sometimes I feel your posts are just to increase post counting.
How can you run BM3D without aggregation?
Old 6th August 2021, 10:32   #57  |  Link
tormento
Acid fr0g
tormento's Avatar
Thanks, I will try ASAP and report.
Old 6th August 2021, 10:53   #58  |  Link
kedautinh12
Lol, i know i'm noob. I just try help with my ability
Old 6th August 2021, 13:34   #59  |  Link
tormento
Acid fr0g
tormento's Avatar
Tested and working.
Now, I have to understand which is better between this and KNLMeansCL...
Old 9th August 2021, 08:35   #60  |  Link
Reel.Deel
Thank for the update. I also confirm that it works
Question, are arrays allowed? I took a peek at the source code (line 429) and it made me think that arrays are allowed just like the VS version.
When I set sigma to [0.5, 0.0, 0.5] it sets the U plane to 255, if I use [0.5, 0.0, 0.0] it sets both U/V to 255. If I use [0.0,0.5,0.5] it sets the Y plane to 255. So I guess that using an array does work, I just don't know if setting sigma to 0 should behave that way.
