Go Back   Doom9's Forum > Capturing and Editing Video > NLE - Non Linear Editing
Old 16th October 2019, 10:31   #1  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Lossless export from Davinci Resolve?
Hi there,
I basically gotta work on the encoding of a documentary.
The whole project has been edited in AVID and it's now gonna be color-corrected in Davinci Resolve.
After that, they're gonna send the file over and I'm gonna have to encode it to make the official Bluray version (I'm gonna use Avisynth and x264 of course), the Motion JPEG2000 version for the DCP for which I'm gonna use Avisynth and ffmpeg/OpenDCP and the MPEG-2 XDCAM version for air-time in our linear channels using Avisynth and ffmbc.
Davinci Resolve is running on Windows 10 and they wanted to know how they have to export it. I don't have access to that computer, so I can't check which codecs it supports on export.
I do know, however, that it cannot export in AppleProRes 'cause it's running on Windows.
Anyway, since my encode it's gonna be a lossy one, I'd like to make them export the whole thing in lossless, so the question to you folks is: which lossless codecs does Davinci Resolve support on Windows?
And, if it doesn't support any lossless codec, which is the "less lossy" codec and settings I can ask them to export the file as?
The final project is gonna be a BT709 SDR 100 nit FULL HD 8bit yv12, even though it has been shot in UHD 10bit 4:4:4 planar in log with a number of nits that were actually enough to make an HLG HDR content. I know you may think that it's "madness" to go for a FULL HD SDR 8bit in 2019 (almost 2020), but the documentary is full of old archive footages coming from very old 35mm and it took a lot of time to remaster it, upscale it to FULL HD with NNEDI and Spline64 with 16bit precision and convert it to BT709, so bringing it to UHD and BT2020 HLG would be madness and it would also potentially make it look not only worse but also different from how the author wanted it to look like, so...
Anyway, in a nutshell, does Davinci Resolve support lossless codecs?
And if it doesn't which is the less lossy one I can ask them to export?
Thank you in advance as always,
Frank.
Old 16th October 2019, 10:52   #2  |  Link
ChaosKing
Never used davinci resolve, but here is a list of supported decoder/encoder on each plattform https://documents.blackmagicdesign.c...Codec_List.pdf
ChaosKing is online now   Reply With Quote
Old 16th October 2019, 15:29   #3  |  Link
poisondeathray
Uncompressed (MOV, AVI) and image sequences ( EXR , TIFF, DPX) are the only "true" lossless export formats . It does not support 3rd party codecs
If Prores 4444XQ is "good enough" for some situation, DNxHR 12bit 4444 should be "good enough" too , so if you don't need mathematically lossless, that' s what people use on Win version of Resolve for those situation
However, beware that FFMpeg/Libav (and thus avisynth) can have some issues with decoding DNxHR 4444, because of the ACT (adaptive color transform) used in official codec implementations (such as Resolve, Adobe, Avid) , so if subsampled 422 is ok, that 's the variant I'd use if using avisynth or ffmpeg
https://trac.ffmpeg.org/ticket/8157
Old 16th October 2019, 15:44   #4  |  Link
Cary Knoop
Cary Knoop
Cary Knoop's Avatar
You also might want to take a look at the Kakadu option.
Cary Knoop is offline   Reply With Quote
Old 16th October 2019, 17:02   #5  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Whoa, that's gonna make a huge file. It's gonna be impossible to send it over, even using Aspera.
Oh, God, no. That reminds me of when I had to deal with shootings made by Blackmagic 6K cameras in .dng lossless. Each and every frame was an image, everything was kept together with metadata and... sure, it was lossless, so maximum quality recorded by the camera with the maximum amount of stops (nits) available, but the size was HUGE and making a mezzanine file took a hell lot of time and it was a nightmare... Really, an absolute nightmare!
Yep, if they were on OSX, I would have asked them ProRes4444XQ. Wavelet transform at such an high bitrate, 10bit and 4:4:4 can't really make any visible damage, so it doesn't matter if it's not mathematically lossless as long as it's visually lossless.
Anyway, they are on Windows, so they cannot export on ProRes, therefore I'm actually gonna go with DNxHR 4444 12bit. I mean, it still uses the Wavelet transform (which is a good transform by the way), it has 12bit and 4:4:4 so it's definitely gonna be fine.
I see...
Well, the thing is that 4:2:2 is definitely gonna be fine for the H.264 yv12 8bit bluray encode and for the MPEG-2 XDCAM yv16 8bit encode, however I would really like not to upscale the chroma for the DCP encode which is gonna be MJPEG2000 4:4:4 12bit. If it's really gonna be an issue when I try to index it with, let's say, FFMpegSource2 or LWLibavVideoSource in Avisynth because of the fact that some blocks were encoded in YUV and some others in RGB, then perhaps I'll ask them to send over a 4:2:2 version and then I'm sadly gonna upscale the chroma for the DCP version. I gotta say that I wasn't aware of the "hybrid" RGB/YUV approach used by the adaptive color transform. It's a shame that it's not decoded properly, though.
Old 16th October 2019, 21:18   #6  |  Link
poisondeathray
This should work ; and it has a lossless option too
ffms2/lsmash decode as RGB48 , but it's a slow decoder for JPEG2K , probably not well optimized
Old 17th October 2019, 16:09   #7  |  Link
kolak
I see...
If you want this as source for BD then DNxHR HQX or Cinefrom YUV (best setting) are way good enough and can be reliably exported from Resolve on PC (and later processed).
Old 18th October 2019, 12:49   #8  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
In the end, I asked them to export an DNxHR 4:2:2 planar 12bit and I'm gonna upscale the chroma to 4:4:4 for the MJPEG2000 Cinema encode (Avisynth + ffmpeg and OpenDCP), while I'm gonna downscale the chroma to 4:2:0 planar and then dither everything down to 8bit with the Floyd-Steinber error diffusion for the Bluray release in H.264 (Avisynth + x264 + ffmpeg + Scenarist).
Old 18th October 2019, 13:57   #9  |  Link
Cary Knoop
Cary Knoop
Cary Knoop's Avatar
...then dither everything down to 8bit with the Floyd-Steinber error diffusion for the Bluray release in H.264
Are you sure you want to use Floyd–Steinberg dithering for H.264?
Old 18th October 2019, 14:37   #10  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
That's what I generally use. Shall I send to x264 the 12bit output directly and let it dither it down automatically to 8bit?
Ideally, I'd like to avoid getting banding artifacts while retaining as many details as possible. Since it's a documentary, though, there are many old archive footages that are very grainy (we had a discussion about them when I encoded them to make our internal mezzanine files and the director was against de-graining them as he wanted to keep the original with the original grain). Some other footages, instead, are the ones we shot in studio or travelling across the country but with accurately handled light in log with 17 stops which have then been graded to BT709 100 nits in post-production which is a waste considering that 17 stops are more than enough to get 1000 nits, but we decided to have our entire workflow as SDR for historical reasons. (i.e it didn't make much sense to have 4K HLG interviews perfect in every detail and a crappy 35mm digitalized and upscaled on the next scene).
The rest of the contents which are not interviews or archive footages are just relatively slow pan.
It has been entirely shot at 25fps progressive.
Old 18th October 2019, 16:05   #11  |  Link
kolak
Works well, but you need to add tiny amount of noise as well and use fairly high bitrate, eg. 30Mbit+.
I've not found anything else as efficient and 'transparent'.
x264's Sierra-2-4A is also ok.
Old 18th October 2019, 16:18   #12  |  Link
Cary Knoop
Cary Knoop
Cary Knoop's Avatar
But isn't Floyd–Steinberg dithering just a tad too good to survive the H.264 "macro-block hammer"?
Here is an example of a Floyd–Steinberg dithered clip. Look at the black patches, they are a bit too restless, using a lower quality dithering seems better for H.264/VP9.
https://www.youtube.com/watch?v=MDtQPJJ20Q8
Old 18th October 2019, 16:30   #13  |  Link
kolak
For typical low bitrate web encodes probably it's. For BD with good encodes at relatively high bitrate not necessarily. I was using Cinemacraft h264 encoder- maybe it behaves differently than x264.
Youtube is no near BBD quality, so it's rather very different scenario.
Old 18th October 2019, 16:31   #14  |  Link
poisondeathray
Youtube bitrates and encoding is not going to be representative of blu-ray bitrates with offline encoding
Old 18th October 2019, 16:34   #15  |  Link
kolak
You should use Cineform RGB export in Resolve. Would preserve 12bit, RGB nature and then would be plenty to make BD version.
Old 18th October 2019, 16:44   #16  |  Link
Cary Knoop
Cary Knoop
Cary Knoop's Avatar
True, but dithering with noise is going to be a challenge even for Blu-ray encodings right?
Old 18th October 2019, 16:49   #17  |  Link
poisondeathray
Yes - and x264 is good at retaining dither and grain at those bitrates for BD . That's what it's known for
Old 18th October 2019, 17:57   #18  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
I hope it will survive at BD-tier bitrate.
Ok, that's what I thought.
Yep, x264 is my de-facto choice for H.264 encodes and official BD releases, not only 'cause it's open source, but because it's the best.
I say it also 'cause it has been proven to be better than closed-source encodes in terms of SSIM/PSNR/VMAF with tests I've made internally in the company I work for.
Sure, since it's an official BD, I'm gonna use a two-pass encode with x264.
You should use Cineamcraft RGB export in Resolve. Would preserve 12bit, RGB nature and then would be plenty to make BD version.
I see. That would be great 'cause this way I won't have to upscale the chroma when I got to 4:4:4 12bit MJPEG2000 for the cinema version and of course it's gonna be more than enough for the yv12 8bit encode.
Old 18th October 2019, 19:13   #19  |  Link
kolak
If you use relatively high bitrates (30Mbit+) Cinemacrfat can be better than x264. It has better quality distribution between I,P,B frames. At lower bitrates x264 is better. x264 can also produce nasty artefacts at high contrast edges as well (even at 30Mbit+), up to level which makes (otherwise very good encode) unacceptable. As for bigger studio Cinemacraft has also plenty other features which can be useful (segment re-encode/replace, SDI preview, etc). It's also faster than x264 as in order to be at reference level you need to run x264 at slow or even very slow preset. In the same time you can make nice BDs with x264 as well
For interlaced content my choice was actually Sony's Blu-Code encoder, which wasn't that popular. As for today BD authoring business brings no money (well you can make money if you get good contracts, but it's a lot of work), so I moved away from it
Cineform is also good as it's wavelet based, so re-encoding to JPEG2000 will cause less quality loss due to same nature of the encoding technique.
Old 18th October 2019, 19:38   #20  |  Link
poisondeathray
When you have a noisy, grainy source - that's difficult to compress. 35Mb/s might actually be considered relatively "low" in that scenario depending on how much noise and grain you actually have. 30Mb/s might not be "enough" for some encoders. 35Mb/s might not be enough. That's where a higher compression efficiency encoder helps. Watch out for splotchy ugly grain distribution in some of the other encoders.
Yes, x264 can have problems when using default settings. The AQ redistribution tends to generate a "halo" like effect of reduced grain around edges. When combined with higher psy-rd and psy-trellis, there can be artifacts not obscured by the grain. Also, there can be noticable I/B/P fluctuations. That's why the --tune grain preset has adjusted settings for --aq-strength and IP/PB ratios. You can adjust them farther if it's still a problem .
Yes, segment reencoding especially is sorely lacking for x264 . Supposedly it was going to get it for a separate special BD version, but never materialized
The problem with VMAF/SSIM/PSNR etc... they do not measure noisy grainy sources very well. VMAF is slightly better, but still has demonstratable problems in this 1st generation of models. Be careful not to rely on them to heavily, especially in the noisy/grainy scenario . Double check with your eyes as well
