23rd April 2020, 17:12 | #81 | Link | |
25th April 2020, 02:00 | #82 | Link |
waifu2x-caffe in the database but not searchable in the gui
https://forum.doom9.org/showthread.php?t=173673 |
25th April 2020, 07:05 | #83 | Link |
waifu2x-caffe was never added to vsrepo https://github.com/vapoursynth/vsrepo/tree/master/local
25th May 2020, 13:56 | #85 | Link |
Log and better error checking is on my todo (there is hidden console log, but you can't make it visible currently)
Try to update with vsrepo via console and see what it shows you. In powershell/cmd: vsrepo upgrade-all or vsrepo install yourpackage
26th May 2020, 23:26 | #87 | Link |
Hmm that is what vsrepogui also does. Do you have multiple python versions installed?
What happens if you click on the "Diagnose Problems" tab?
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 26th May 2020 at 23:30. |
27th May 2020, 10:09 | #88 | Link |
No, just one (3.8.2). It's installed in the Program Files, but I don't think that could be the problem because it used to work just fine a few weeks ago.
I don't see any problems. Code:
Checked Plugins: 57, Notices: 13, Errors: 0 P.S. I'm on Win7 x64 SP1. |
30th June 2020, 09:05 | #90 | Link |
See if this build shows any usefull err message https://www.dropbox.com/s/1b3l2bld6c..._test.zip?dl=1
30th June 2020, 13:39 | #92 | Link | |
And by defauft vsrepo uses the APPDATA folder... so I don't see how SVP could change that.
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 30th June 2020 at 13:42. |
30th June 2020, 14:28 | #93 | Link |
I can't see that here.
https://drive.google.com/file/d/1r8W...ew?usp=sharing Anyway it seems that with VirtualDub2 I need to load the plugins manually. Last edited by Alexkral; 30th June 2020 at 18:18. |
30th June 2020, 17:59 | #94 | Link |
Attachments Approval can take a long time here, better upload it somewhere else.
1st July 2020, 00:09 | #95 | Link |
It looks like you have R51 installed, but the "SVP version R50" is used/loaded. I don't know where you can change the appdata path in VS, maybe it is a patched version by svp?
VSRepoGui just uses what "vsrepo paths" returns.
6th July 2020, 18:07 | #96 | Link | |
7th July 2020, 18:48 | #97 | Link |
I will install Win7 in a VM and see if I can trigger the same error.
@leon Is python installed globally or is it a per user installation?
15th July 2020, 15:09 | #99 | Link |
Good and bad news.
I finally got my win7 up and running. For some reason it can not download anything. Error is always Code:
Failed to download ZNEDI3 r2, skipping installation and moving on Nothing done Will take some time to figure out what is wrong here exactly... Running as admin does not help
8th August 2020, 10:14 | #100 | Link |
If Python and VapourSynth are not in PATH then the app silently dies before any UI or error is shown, the average user will not be able to find out what's going on and just assume the app is broken, so it can be considered to be a bug.
For Each key In {Registry.CurrentUser, Registry.LocalMachine} dllPath = key.GetString("Software\VapourSynth", "VapourSynthDLL") If File.Exists(dllPath) Then Return dllPath End If Next Code:
For Each key In {Registry.CurrentUser, Registry.LocalMachine} For Each keyName In key.GetKeyNames("SOFTWARE\Python\PythonCore") exePath = key.GetString($"SOFTWARE\Python\PythonCore\{keyName}\InstallPath", "ExecutablePath") If File.Exists(exePath) Then Return exePath End If Next Next
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 8th August 2020 at 12:47. |
