Go Back   Doom9's Forum > Hardware & Software > Hardware players
Old 25th February 2019, 13:50   #1  |  Link
LigH
LigH's Avatar
Need external 4K picture slideshow player for 4K TV set with idiotic firmware
There is a 4K TV set: Sony KD-49X8005C. It can play a variety of videos from an attached USB stick. But it is unable to play an album of JPEG images in a loop. Copying the files with several different names does not help, it detects them as copy and plays only unique pictures only once. Altering the copies with a sequence of EXIF record time stamps did not work well either. And the worst: When the album has been played once, Sony advertizing is played.
So I hope there are media players which can also play slideshows of a picture album directory via HDMI 1.4/2.x in 4K resolution in a loop. Autonomous players (reading from USB stick, SD card, or internal memory) are preferred. But if there aren't, the last hope may be Fire TV 4K stick or Chromecast Ultra, if there is a chance to feed two of them simultaneously with different content by a media server on a laptop.
New German Gleitz board
Old 25th February 2019, 15:50   #2  |  Link
there is so much. so i just start with i'm coming up with first.
windows background slide show. load the images disable the taskbar set the timer done. you can even sync it with a different PC. windows 10 runs on ARM so there are cheap SOC as an option.
wallpaper engine.
linux will be able to do this so you can just use a raspberry thingy and be done with it.
Old 25th February 2019, 16:04   #3  |  Link
LigH
LigH's Avatar
There will not be any PC next to the TV set.
Old 28th February 2019, 17:37   #4  |  Link
Selur
Selur's Avatar
fire tv + FlickFolio + Flickr should work according to: https://www.churchmotiongraphics.com...computer-free/
Old 28th February 2019, 20:22   #5  |  Link
LigH
LigH's Avatar
We decided.
And ordered a Xiaomi Mi Box.
Old 1st March 2019, 02:44   #6  |  Link
mariush
Irfanview > Slideshow option in the menu...
freeware image viewer... runs on hdmi stick with any windows os, or some ancient pc with a card that has 4K output.
mariush is offline   Reply With Quote
Old 1st March 2019, 06:46   #7  |  Link
LigH
LigH's Avatar
Again: No PC.
Old 1st March 2019, 13:07   #8  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
How about encoding still images as a video stream?
Old 24th June 2019, 06:52   #9  |  Link
Jamaika
Maybe add Firmware update to v5.433
https://www.sony.co.uk/electronics/s...loads/00016021
Jamaika is offline   Reply With Quote
