Old 26th February 2018, 17:31   #1  |  Link
LigH
LigH's Avatar
x264 (MABS build) with integrated FFMS2 and LAVF
LoRd_MuldeR pointed me at it, and I can only confirm:
The x264 builds created by media-autobuild_suite including FFMS2 and L-SMASH Source (video codecs only = mode 6/"fullv") can't open AVI sources and eventually fall back to AviSynth, trying to use AviSource.
x264 -o *.mp4 *.avi
ffms [error]: could not create indexer
lavf [error]: could not open input file
avs [info]: trying AVISource... succeeded
I will try to create a full build (mode 4/"full"), wondering if possibly the limiting to video codecs only may cause issues. Could anyone else with enough insight possibly check if MABS might be misconfigured for this case? Or is it possible that there is indeed a mistake in current x264 sources?
_
In the meantime, issue #758 appeared, and commit c566f85; will build again...
New German Gleitz board
Last edited by LigH; 15th April 2021 at 07:59. Reason: Since it works, it doesn't fail on AVI sources anymore
Old 26th February 2018, 18:08   #2  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Just want to add that the problem is not limited to AVI. Happens with MP4 or MKV as well.
The problem is always the same: FFMS reports "could not create indexer", and LAVF reports "could not open input file". Then x264 falls back to AVS.
Builds from here do not have FFMS enabled (unfortunately), but LAVF input does work.
Old 26th February 2018, 18:46   #3  |  Link
LigH
LigH's Avatar
I just updated MABS and recompiled. x264 in 32 bit is already done, and here FFMS2 starts indexing (to RAM, I'd assume).
So I will release a new set soon.
Old 26th February 2018, 18:51   #4  |  Link
LoRd_MuldeR
Software Developer
Great. BTW, index is written to file (or reused from file) when using "--index" option.
Old 26th February 2018, 19:55   #5  |  Link
LigH
LigH's Avatar
Updated on MediaFire. Regards to wiiaboo for a quick response.
Fun fact: They are even smaller now.
Old 26th February 2018, 20:26   #6  |  Link
LoRd_MuldeR
Software Developer
It is working now, thanks!
Old 2nd March 2018, 19:16   #7  |  Link
mkver
I didn't thought that others stumbled upon this problem, too. I actually thought that it never ever worked at all and that no one used it so no one complained. It seems that I stand corrected. Just out of curiosity: When did it stop working?
PS: That they are smaller now is probably due to the disabling of some audio codecs. (I tested an earlier version of MABS and there was code for disabling, but it didn't work.) One can reduce the size of the builds even further:
The size of my light x264 build with MABS: 17376256 B (all builds are x64).
After disabling all bitstream filters and enabling the extract_extradata-bsf (my test show this to be needed to actually get the codec parameters from transport streams; the h2645_mp4toannexb bsf are not needed for h2645 in mp4/Matroska) this is down to 17159680 B.
After also (trying to, see below) disabling subtitle decoders this is down to 17126912 B.
And looking at the list of disabled codecs I noticed that quite a few audio and subtitle decoders aren't disabled. The reason: MABS currently only disables decoders for which there is an encoder of the same name (I think I will report this). Fixing this brings the size down to 14960128 B. (Side issue: I have observed that if the input file has an mp2 audio track, lavf now emits a warning that it couldn't find the codec parameters for this stream. This might also happen for other codecs; similar things might also happen with the currently used list of codecs to deactivate. Does anyone know a way to stop lavf emitting warnings for non-video codecs?)
Finally, I also disabled some of the things that ffmpeg enables by default, but which is (to the best of my knowledge) unusable for lavf inside x264.exe: I added --disable-amf --disable-d3d11va --disable-dxva2 --disable-iconv --disable-schannel --disable-cuda --disable-cuvid. Now the size is only 13884928 B.
The relevant part of my script now looks like the following:
                audio_codecs=(
                    $(sed -n '/audio codecs/,/external libraries/p' ../libavcodec/allcodecs.c | \
                      sed -n "s/^[^#]*extern.* *ff_\([^ ]*\)_decoder;/\1/p")
                LDFLAGS+=" -L$MINGW_PREFIX/lib" \
                    log configure ../configure "${FFMPEG_BASE_OPTS[@]}" \
                    --prefix="$LOCALDESTDIR/opt/lightffmpeg" \
                    --disable-{programs,devices,filters,encoders,muxers,debug,sdl2,network,protocols,doc,bsfs} \
                    --enable-protocol=file,pipe \
                    --disable-decoder="$(IFS=, ; echo "${audio_codecs[*]}")" --enable-gpl \
                    --enable-bsf=extract_extradata \
                unset audio_codecs
Any suggestions/comments/improvements?
mkver is offline   Reply With Quote
Old 10th August 2018, 19:31   #8  |  Link
LoRd_MuldeR
Software Developer
Some new commits have arrived in the official development tree. Any chance for updated x264 builds?
https://git.videolan.org/?p=x264.git;a=summary
(Highlights seem to include "4:0:0 (monochrome) encoding support" and "Sony XAVC" support)
Old 10th August 2018, 20:08   #9  |  Link
LigH
LigH's Avatar
New upload: x264 core:157 r2932 303c484
x264 0.157.2932 303c484
(libswscale 5.2.100)
(libavformat 58.17.101)
(ffmpegsource 2.30.0.0)
Win32: built on Aug  8 2018, gcc: 7.3.0
Win64: built on Aug  8 2018, gcc: 8.2.0
x264 configuration: --chroma-format=all
libx264 configuration: --chroma-format=all
x264 license: GPL version 2 or later
libswscale/libavformat/ffmpegsource license: GPL version 2 or later
Old 10th August 2018, 20:53   #10  |  Link
LoRd_MuldeR
Software Developer
Old 10th August 2018, 21:11   #11  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Thanks for the update!
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
Old 2nd November 2018, 15:14   #12  |  Link
LigH
LigH's Avatar
New (and updated) upload: x264 core:157 r2935 545de2f
x264 0.157.2935 545de2f
(libavformat 58.19.102)
Win32: built on Nov  1 2018, gcc: 7.3.0
Win64: built on Nov  1 2018, gcc: 8.2.0
Old 13th December 2018, 16:13   #13  |  Link
LigH
LigH's Avatar
(libswscale 5.4.100)
(libavformat 58.24.100)
Win32: built on Dec 13 2018, gcc: 7.4.0
Win64: built on Dec 13 2018, gcc: 8.2.1 20181207
Old 14th December 2018, 07:05   #14  |  Link
manolito
manolito's Avatar
Thanks for the new build,
for me it is the fastest of all the current r2935 builds (only tested 32-bit version).
(Probably stupid) question:
What do I do with the included ffmsindex.exe?
I use X264 under StaxRip with the latest stable ffms2 version 2.23.1. I only use the 32-bit versions.
Should I replace the 2.23.1 version of ffmsindex with the version which comes with your build? Is it compatible, is it necessary, what are the advantages?
Cheers
manolito
Old 14th December 2018, 07:12   #15  |  Link
LigH
LigH's Avatar
I am not sure myself how useful a separate indexer is, but MABS builds it along x264. So I assume that x264 can make use of the index files if they are provided together with a source file, and the FFMS2 demultiplexer is used in x264.
Old 15th December 2018, 22:26   #16  |  Link
qyot27
qyot27's Avatar
ffmsindex isn't built alongside x264, it's part of the FFMS2 build. It does nothing with/for x264.
From x264's --fullhelp,
--index <string>        Filename for input index file
I just tested it; that parameter makes x264 output the index from the initial pass to <output filename> rather it being used from RAM, and it also specifies a previously-generated index file to use, skipping the indexing step.
The FFMS2 version will have to match exactly for any index written by ffmsindex.exe or ffms2.dll (via AviSynth, for instance) to work with x264. And if the FFMS2 linked into x264 is static, then that only holds true for the exact binaries used there - if/when an update to ffms2.dll/ffmsindex.exe happens, FFMS2 will be newer than the one in x264 and force x264 to re-generate the index file rather than re-using it (or vice-versa; in my short test, x264 and its linked FFMS2 was newer - October 2018 - than the C-plugin build, from September).
In other words, only bother with ffmsindex if you're using FFMS2 as a plugin for AviSynth or VapourSynth, not when using the FFMS2 input on x264. If you're only using x264, stick with the indices it saves when using the --index parameter.
Old 15th December 2018, 22:31   #17  |  Link
LigH
LigH's Avatar
sigh
And ffms2.dll is not built by MABS.
OK, so I can omit the separate indexer safely.
Old 6th February 2019, 18:34   #18  |  Link
LigH
LigH's Avatar
(libavformat 58.26.100)
Win32: built on Feb  6 2019, gcc: 7.4.0
Win64: built on Feb  6 2019, gcc: 8.2.1 20181214
Old 13th March 2019, 10:30   #19  |  Link
LigH
LigH's Avatar
New upload: x264 core:157 r2945 72db437
x264 0.157.2945 72db437
(libavformat 58.26.101)
Win32: built on Mar 12 2019, gcc: 7.4.0
Win64: built on Mar 12 2019, gcc: 8.3.0
_
But wait! There's more...
New upload: x264 core:157 r2969 d4099dd
x264 0.157.2969 d4099dd
Win32: built on Mar 13 2019, gcc: 7.4.0
Win64: built on Mar 13 2019, gcc: 8.3.0
Interesting commitdiff remark:
Remove compatibility workarounds
This will break decoding with older versions of FFmpeg/Libav.
So keep your decoders up to date. I don't know how old is "too old" here...
Old 14th March 2019, 04:16   #20  |  Link
manolito
manolito's Avatar
Please I need some clarifications here...
Does this only apply to the X264 input, or does this mean that older player software or hardware won't be able to decode files created with this version any longer?
Out of curiosity I encoded a file with this latest r2969 32-bit version and tested if all my playing or transcoding software could handle it. No problem whatsoever, even under XP where I need to use some older decoders. And my Xtreamer box (latest firmware from 2011) also had no problems decoding the file.
Looks like a non-issue to me...
Cheers
manolito
