13th August 2016, 23:55 | #21 | Link |
Another one (i5 2500K @ 4GHz, XP32, AVS+ r2085):
Internal resizers: Code:
[Runtime info] Frames processed: 1000 (0 - 999) FPS (min | max | average): 1.743 | 255682 | 17.60 Memory usage (phys | virt): 293 | 295 MiB Thread count: 13 CPU usage (average): 99% Time (elapsed): 00:00:56.812 [Script] colorbars(width = 1920 * 2, height = 1080 * 2, pixel_type = "yv12").killaudio().assumefps(25, 1).trim(0, 999) BilinearResize(width() - 64, height() - 64) BicubicResize(width() - 64, height() - 64) LanczosResize(width() - 64, height() - 64) Lanczos4Resize(width() - 64, height() - 64) BlackmanResize(width() - 64, height() - 64) Spline16Resize(width() - 64, height() - 64) Spline36Resize(width() - 64, height() - 64) Spline64Resize(width() - 64, height() - 64) GaussResize(width() - 64, height() - 64) SincResize(width() - 64, height() - 64) Prefetch(4) Code:
[Runtime info] Frames processed: 1000 (0 - 999) FPS (min | max | average): 6.480 | 16.84 | 16.66 Memory usage (phys | virt): 76 | 79 MiB Thread count: 89 CPU usage (average): 99% Time (elapsed): 00:01:00.031 [Script] colorbars(width = 1920 * 2, height = 1080 * 2, pixel_type = "yv12").killaudio().assumefps(25, 1).trim(0, 999) BilinearResizeMT(width() - 64, height() - 64, threads = 4) BicubicResizeMT(width() - 64, height() - 64, threads = 4) LanczosResizeMT(width() - 64, height() - 64, threads = 4) Lanczos4ResizeMT(width() - 64, height() - 64, threads = 4) BlackmanResizeMT(width() - 64, height() - 64, threads = 4) Spline16ResizeMT(width() - 64, height() - 64, threads = 4) Spline36ResizeMT(width() - 64, height() - 64, threads = 4) Spline64ResizeMT(width() - 64, height() - 64, threads = 4) GaussResizeMT(width() - 64, height() - 64, threads = 4) SincResizeMT(width() - 64, height() - 64, threads = 4)
Groucho's Avisynth Stuff Last edited by Groucho2004; 14th August 2016 at 00:02. |
14th August 2016, 01:13 | #22 | Link | |
Excessively jovial fellow
38.607 sec [77.706fps] #threads=1, prefetch=1 36.943 sec [81.206fps] #threads=2, prefetch=1 |
14th August 2016, 10:01 | #23 | Link |
As i'm often doing this at work during lunch break, and i have only at it a 2 cores CPU without HT, when i've checked on it between 1 or 2 threads, there was a significant difference, and yes, looking also at the result, it scales with 2 threads.
I'm very busy today, but tomorrow i'll try on my PC some benchmark also... |
15th August 2016, 10:21 | #24 | Link |
Some tests on my PC :
[OS/Hardware info] OS version: Windows 7 (x64) Service Pack 1 (Build 7601) CPU (brand string): Intel(R) Core(TM) i7-6950X CPU @ 3.00GHz CPU (code name): Unknown Core 2 CPU clock (measured): 3624 MHz CPU cores / Logical cores: 10 / 20 [Avisynth info] Avisynth VersionString: AviSynth+ 0.1 (r2151, MT, x86_64) Avisynth VersionNumber: 2.60 File version: 0.1.0.0 Avisynth Interface Version: 6 Multi-threading support: Yes Linker/compiler version: 14.0 [Clip info] Number of frames: 10000 Length (hh:mm:ss.ms): 00:06:40.000 Frame width: 3776 Frame height: 2096 Framerate: 25.000 (25/1) Colorspace: YV12 [Runtime info] Frames processed: 10000 (0 - 9999) FPS (min | max | average): 118.3 | 149685 | 492.7 Memory usage (phys | virt): 1196 | 1191 MiB Thread count: 41 CPU usage (average): 99% Time (elapsed): 00:00:20.295 [Script] Colorbars(width=1920*2,height=1080*2,pixel_type="yv12").killaudio().assumefps(25,1).trim(0,9999) Spline36Resize(width()-64,height()-64) Prefetch(20) Code:
[OS/Hardware info] OS version: Windows 7 (x64) Service Pack 1 (Build 7601) CPU (brand string): Intel(R) Core(TM) i7-6950X CPU @ 3.00GHz CPU (code name): Unknown Core 2 CPU clock (measured): 3624 MHz CPU cores / Logical cores: 10 / 20 [Avisynth info] Avisynth VersionString: AviSynth+ 0.1 (r2151, MT, x86_64) Avisynth VersionNumber: 2.60 File version: 0.1.0.0 Avisynth Interface Version: 6 Multi-threading support: Yes Linker/compiler version: 14.0 [Runtime info] Frames processed: 10000 (0 - 9999) FPS (min | max | average): 459.2 | 505.2 | 502.5 Memory usage (phys | virt): 63 | 58 MiB Thread count: 61 CPU usage (average): 92% Time (elapsed): 00:00:19.900 [Script] Colorbars(width=1920*2,height=1080*2,pixel_type="yv12").killaudio().assumefps(25,1).trim(0,9999) Spline36ResizeMT(width()-64,height()-64) #Prefetch(20) Code:
[OS/Hardware info] OS version: Windows 7 (x86) Service Pack 1 (Build 7601) CPU (brand string): Intel(R) Core(TM) i7-6950X CPU @ 3.00GHz CPU (code name): Unknown Core 2 CPU clock (measured): 3623 MHz CPU cores / Logical cores: 10 / 20 [Avisynth info] Avisynth VersionString: AviSynth 2.60, build:Mar 31 2015 [16:38:54] Avisynth VersionNumber: 2.60 File version: 2.6.0.6 Avisynth Interface Version: 6 Multi-threading support: No Linker/compiler version: 6.0 [Runtime info] Frames processed: 10000 (0 - 9999) FPS (min | max | average): 21.46 | 43.44 | 43.26 Memory usage (phys | virt): 46 | 44 MiB Thread count: 1 CPU usage (average): 5% Time (elapsed): 00:03:51.170 [Script] Colorbars(width=1920*2,height=1080*2,pixel_type="yv12").killaudio().assumefps(25,1).trim(0,9999) Spline36Resize(width()-64,height()-64) Code:
[OS/Hardware info] OS version: Windows 7 (x86) Service Pack 1 (Build 7601) CPU (brand string): Intel(R) Core(TM) i7-6950X CPU @ 3.00GHz CPU (code name): Unknown Core 2 CPU clock (measured): 3623 MHz CPU cores / Logical cores: 10 / 20 [Avisynth info] Avisynth VersionString: AviSynth 2.60, build:Mar 31 2015 [16:38:54] Avisynth VersionNumber: 2.60 File version: 2.6.0.6 Avisynth Interface Version: 6 Multi-threading support: No Linker/compiler version: 6.0 [Runtime info] Frames processed: 10000 (0 - 9999) FPS (min | max | average): 404.0 | 484.2 | 481.5 Memory usage (phys | virt): 47 | 45 MiB Thread count: 41 CPU usage (average): 90% Time (elapsed): 00:00:20.769 [Script] Colorbars(width=1920*2,height=1080*2,pixel_type="yv12").killaudio().assumefps(25,1).trim(0,9999) Spline36ResizeMT(width()-64,height()-64) Last edited by jpsdr; 15th August 2016 at 10:24. |
15th August 2016, 10:59 | #25 | Link |
Groucho's Avisynth Stuff |
18th August 2016, 02:38 | #27 | Link |
intel SSE4.2 Release gave me 0x7e error in load plugin for both x64 and x86
the cpu is core i7 X 980 in os windows server 2008 R2, same intel SSE4.2 Release for nnedi3 always work
See My Avisynth Stuff |
18th August 2016, 08:45 | #28 | Link |
I'll check when back at home if i see anything strange in the build profile. My standard PC is no more than SSE4.2 (i7@850), and didn't have issue with it. Do you have the last Intel Redistribuable version ? (Don't know if it can be related...).
EDIT : Can you check if you have the same issue with either the AutoYUY2 filter and/or my VDub filters ? Last edited by jpsdr; 18th August 2016 at 12:08. |
18th August 2016, 15:29 | #29 | Link | ||
See My Avisynth Stuff Last edited by real.finder; 18th August 2016 at 15:34. |
18th August 2016, 16:13 | #30 | Link |
I think all are build as static (i'll chek later). Get and install the Intel Redistribuable, and check if it's this.
18th August 2016, 16:33 | #31 | Link | |
18th August 2016, 17:00 | #32 | Link |
You could try troubleshooting with Dependency Walker and AVSMeter (with the "-avsinfo" switch).
18th August 2016, 18:25 | #33 | Link |
I've checked the build profile, and found for now nothing unusual, and i must confess that i have no idea what error 0x7e is...
After, you still have the standard no Intel releases, they are here as safeguard for such kind of cases. And in the best case, speed difference would probably be only a few percent. Do you have the same issue with my VDub filters ? |
19th August 2016, 07:28 | #34 | Link | |
19th August 2016, 09:12 | #36 | Link | |
I've take a look at fk3db to see if i can do the same thing, but it's a lot more complex to follow, and the C++ is a little to much ++ for me... Last edited by jpsdr; 19th August 2016 at 09:19. |
19th August 2016, 10:00 | #37 | Link | |
19th August 2016, 11:54 | #38 | Link |
Broadcast Encoder
Tested using an i7 4 core, 8 threads, 3.60 GHz, 8 MB cache l3, AVX 2, using avisynth trying to upscale a progressive material via Spline64Resize and Spline64ResizeMT to 4K and encode it with x265.
It indeed increases the speed as the "pitch" reached by the standard Spline64 is 3.05, and is stable at 2.88 fps, while Spline64MT reaches a "pitch" of 3.84 and is stable at 3.24 fps, which is a very good improvement for me! I tested it using an old processor as well, which is a monocore dual thread, which supports up to SSE3 trying to downscale from 1080p to 720p via Spline64 and I can tell ya that the Mt Version takes longer to start and it doesn't have any noticeable benefits. So... it really depends on your CPU. I'm gonna try it on an AMD 6 core as soon as I can, as AMD handles multithreading differently compared to Intel (in a worse way, most of the time) and maybe AMD CPUs will be the ones who will benefit most from it. Oh, by the way, you said that you tried to do it with f3kdb, right? If you have time, how about doing it with the old good LSFmod as well? *_* |
19th August 2016, 13:09 | #39 | Link |
It seems to me that you mainly measured the encoding speed.
19th August 2016, 20:29 | #40 | Link |
I've made a new version with optimized threads repartition according physical cores.
Some tests with it : Code:
[OS/Hardware info] OS version: Windows 7 (x64) Service Pack 1 (Build 7601) CPU (brand string): Intel(R) Core(TM) i7-6950X CPU @ 3.00GHz CPU (code name): Unknown Core 2 CPU clock (measured): 3624 MHz CPU cores / Logical cores: 10 / 20 [Avisynth info] Avisynth VersionString: AviSynth+ 0.1 (r2172, MT, x86_64) Avisynth VersionNumber: 2.60 File version: 0.1.0.0 Avisynth Interface Version: 6 Multi-threading support: Yes Linker/compiler version: 14.0 [Clip info] Number of frames: 10000 Length (hh:mm:ss.ms): 00:06:40.000 Frame width: 3776 Frame height: 2096 Framerate: 25.000 (25/1) Colorspace: YV12 [Runtime info] Frames processed: 10000 (0 - 9999) FPS (min | max | average): 471.4 | 509.3 | 506.4 Memory usage (phys | virt): 63 | 58 MiB Thread count: 41 CPU usage (average): 60% Time (elapsed): 00:00:19.749 [Script] Colorbars(width=1920*2,height=1080*2,pixel_type="yv12").killaudio().assumefps(25,1).trim(0,9999) Spline36ResizeMT(width()-64,height()-64,threads=10) #Spline36Resize(width()-64,height()-64) #Prefetch(20) Code:
[Clip info] Number of frames: 10000 Length (hh:mm:ss.ms): 00:06:40.000 Frame width: 3776 Frame height: 2096 Framerate: 25.000 (25/1) Colorspace: YV12 [Runtime info] Frames processed: 10000 (0 - 9999) FPS (min | max | average): 460.0 | 502.9 | 501.0 Memory usage (phys | virt): 64 | 59 MiB Thread count: 61 CPU usage (average): 90% Time (elapsed): 00:00:19.962 [Script] Colorbars(width=1920*2,height=1080*2,pixel_type="yv12").killaudio().assumefps(25,1).trim(0,9999) Spline36ResizeMT(width()-64,height()-64,threads=0) #Spline36Resize(width()-64,height()-64) #Prefetch(20) Code:
[Clip info] Number of frames: 10000 Length (hh:mm:ss.ms): 00:06:40.000 Frame width: 3776 Frame height: 2096 Framerate: 25.000 (25/1) Colorspace: YV12 [Runtime info] Frames processed: 10000 (0 - 9999) FPS (min | max | average): 118.2 | 217181 | 450.0 Memory usage (phys | virt): 624 | 619 MiB Thread count: 31 CPU usage (average): 63% Time (elapsed): 00:00:22.222 [Script] Colorbars(width=1920*2,height=1080*2,pixel_type="yv12").killaudio().assumefps(25,1).trim(0,9999) #Spline36ResizeMT(width()-64,height()-64,threads=0) Spline36Resize(width()-64,height()-64) Prefetch(10) Code:
[Clip info] Number of frames: 10000 Length (hh:mm:ss.ms): 00:06:40.000 Frame width: 3776 Frame height: 2096 Framerate: 25.000 (25/1) Colorspace: YV12 [Runtime info] Frames processed: 10000 (0 - 9999) FPS (min | max | average): 125.1 | 191873 | 493.3 Memory usage (phys | virt): 1196 | 1191 MiB Thread count: 41 CPU usage (average): 99% Time (elapsed): 00:00:20.273 [Script] Colorbars(width=1920*2,height=1080*2,pixel_type="yv12").killaudio().assumefps(25,1).trim(0,9999) #Spline36ResizeMT(width()-64,height()-64,threads=0) Spline36Resize(width()-64,height()-64) Prefetch(20) The fastest : MT version with 10 threads (not what i hoped... ) The more memory used : Core version with 20 threads. The more threads created : MT version with 20 threads. Well, it depends of CPU and maybe a little tunning also. Well, finaly, it's up to you to choose whatever version you want to use... Last edited by jpsdr; 19th August 2016 at 20:32. |
