2nd April 2016, 19:43 | #1 | Link |
Loading and applying 3D LUTs
Just wondering how to go about loading and using .cube 3D LUTs in VapourSynth. I would like to use these LUTs here (1 / 2), but I'm not sure if this can this be done with std.Lut or is it one-of-those-things that will require a plugin?
Edit - I'm not the author, just posting link here for convenience. ------------------ Timecube, a plugin to load and apply 3D luts to a video:
Usage: timecube.Cube(clip clip, string cube="") Parameters: clip = Input clip, colorspace must be RGBS. cube = Path to 3D lut file, only .cube files are supported. Last edited by Reel.Deel; 27th August 2018 at 03:16. |
2nd April 2016, 20:59 | #4 | Link |
Professional Code Monkey
You'll need a new plugin for that. Is there format actually documented somewhere?
2nd April 2016, 21:04 | #5 | Link | |
2nd April 2016, 21:19 | #6 | Link | |
24th May 2017, 00:15 | #10 | Link |
29th May 2017, 06:59 | #11 | Link |
I currently use FFMPEG's 3DLut filter for .cube files. It's not as convenient as having a Vapoursynth/Avisynth plugin, but it's more flexible than Davinci Resolve. Resolve doesn't support efficient lossless codecs (FFV1, X264 lossless, UTVideo, etc), avisynth input, or piping VapourSynth scripts.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake? Curly: Burned at the stake! Moe: Why? Curly: A hot steak is always better than a cold chop. |
29th May 2017, 12:52 | #12 | Link |
Why didn't anyone tell me there's code I can borrow? Maybe I'll actually do something about this after I release R38
29th May 2017, 19:17 | #13 | Link |
If you can provide some before/after clips with a lut applied (and the lut file) so we can easily test a plugin that'd be great. Or this is not going to happen...
9th June 2017, 08:12 | #16 | Link |
I don't know how to use the vscube plugin. Any pointers would be appreciated.
9th June 2017, 09:07 | #17 | Link |
I'm also receiving the "Cube: must be RGBS" error. The .cube file works fine with FFMPEG.
UPDATE: Okay. It works now. Thank you.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake? Curly: Burned at the stake! Moe: Why? Curly: A hot steak is always better than a cold chop. Last edited by Revgen; 9th June 2017 at 09:46. |
