Go Back   Doom9's Forum > General > Linux, Mac OS X, & Co
Old 2nd February 2021, 15:08   #221  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
ChangeLog for ffhevc 4.3.9 and ffx264 4.1.5
* Replace the yadif deinterlacer with bwdif. It's faster and provides higher quality
Old 8th February 2021, 19:35   #222  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.4.0
* Support setting the Maximum Decoder Level
Old 10th February 2021, 20:51   #223  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffx264 4.1.6
* Support forcing an H.264 level
Old 16th February 2021, 19:53   #224  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.4.1 and ffx264 4.1.7
* Fix "too many arguments" error in the HEVC/H.264 Level code
Old 21st March 2021, 16:10   #225  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.4.2
* Fix a long-standing bug in the HDR code where the $hdr variable was used twice, once to check if HDR is selected and once to force signaling of HDR in case max-cll is 0,0. This resulted in an "y" being added after the specified max-cll value
* Renamed hdr_opt to hdr10_opt
Old 27th March 2021, 17:18   #226  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.4.3
* Remove hrd options for HDR encodes. They're not really needed
* Luma/Chroma Offset should be Optimization instead
Old 3rd April 2021, 20:32   #227  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.4.4
* Fixed a small bug where the -colorspace option was not added for BT2020 content in case SMPTE2084/HLG was chosen as transfer
Old 25th April 2021, 17:51   #228  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.4.5
* Remove +frag_keyframe for the MP4 container. Doesn't make sense when used with +fasstart.
* Cosmetics: use HDR10 word when asking HDR questions
Old 29th July 2022, 19:33   #229  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.4.6
* Fine tuning to the default encoding options
* Tweaks to the HDR10 code
Old 23rd January 2023, 11:37   #230  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.4.7 and ffx264 4.1.8
* Support more deinterlacing filters
Old 5th May 2023, 05:09   #231  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffx264 4.1.9
* Update default encoding options
* Bump up default CRF value from 19 to 21
Old 7th May 2023, 08:06   #232  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.4.8
* Update to the default encoding options
* Increased default CRF value from 21 to 23
Old 16th August 2023, 07:06   #233  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.4.9
* Ask for the Lanczos scaler width (alpha)
* Only ask to force HDR10 signaling in case Max CLL is not set or user has provided 0,0 as value
Old 17th August 2023, 04:47   #234  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.4.10 and ffx264 4.1.10
* Fix crop detection for HDR content
* Set Lanczos as default scaler option
Old 19th August 2023, 19:13   #235  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.4.11 and ffx264 4.1.11
* Improved FPS detection code
Old 21st August 2023, 12:59   #236  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.4.12
* By default, force signaling of HDR10 in case max-cll is unknown or 0,0
* Various small improvements
Old 25th August 2023, 14:04   #237  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffx264 4.1.12
Old 10th September 2023, 17:07   #238  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffx264 4.1.13 and ffhevc 4.4.13
* Bugfix in the video_noise_func() function
Old 27th October 2023, 12:40   #239  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.4.14 and ffx264 4.1.14
* Set side/wide audio channels as default
* Support the newly added channels for TrueHD audio
Old 6th November 2023, 19:00   #240  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.4.15 and ffx264 4.1.15
* Set the setpts + atempo option as default for FPS conversion
* Correct 5.0 and 5.1 channels option for TrueHD encoding. Should be 5.0(side) and 5.1(side)
