Old 11th April 2020, 12:57   #21  |  Link
tormento
Acid fr0g
tormento's Avatar
nu774/fdkaac_autobuild
DEAD PROJECT!!! Don't use this
This script no longer works because:
1) Due to recent TLS1.1 drop by github and too old OpenSSL version included in MSYS, downloading from github fails.
2) Makefiles are not updated to the latest FDKv2.
Use this.
I strongly suggest you to disable any antivirus while compiling or it will consume all resources.
@turment on Telegram
Old 5th December 2020, 04:35   #22  |  Link
kedautinh12
FDK-AAC v1.0.1
http://www.mediafire.com/file/9c79jk...GCC102.7z/file
Old 30th December 2020, 00:27   #23  |  Link
kedautinh12
FDK-AAC v1.0.1
https://github.com/nu774/fdkaac/releases/tag/v1.0.1
https://www.mediafire.com/file/09lrx...GCC102.7z/file
Old 18th January 2021, 07:58   #24  |  Link
szabi
Is it the newest version since than?
It helped me a lot.
Regards
szabi
szabi is offline   Reply With Quote
Old 27th March 2021, 11:09   #25  |  Link
kedautinh12
Yeah, this is last ver
Old 25th April 2021, 22:52   #26  |  Link
kedautinh12
fdk-aac new commits
https://github.com/mstorsjo/fdk-aac
fdkaac new ver
Can anyone compile it??
Old 29th May 2021, 05:54   #27  |  Link
kedautinh12
FDK-AAC v1.0.2 (2021-04-28)
https://drive.google.com/file/d/1z-C...w?usp=drivesdk
Old 29th May 2021, 11:33   #28  |  Link
GMJCZP
GMJCZP's Avatar
Originally Posted by kedautinh12 View Post
By law and justice!
GMJCZP's Arsenal
GMJCZP is offline   Reply With Quote
Old 8th June 2021, 09:53   #29  |  Link
tormento
Acid fr0g
tormento's Avatar
fdkaac 1.0.2 libfdk-aac 0.1.6+2.0.2 x86 (exe+shared dlls)
fdkaac 1.0.2 libfdk-aac 0.1.6+2.0.2 x64 (exe+shared dlls)
built by GCC 10.3.0
Old 9th June 2021, 10:37   #30  |  Link
kedautinh12
Thanks, but i don't know libfdk-aac use for??
Old 9th June 2021, 13:50   #31  |  Link
GMJCZP
GMJCZP's Avatar
For example:
By law and justice!
GMJCZP's Arsenal
Old 9th June 2021, 13:51   #32  |  Link
GMJCZP
GMJCZP's Avatar
built by GCC 10.3.0
By law and justice!
GMJCZP's Arsenal
Old 9th June 2021, 17:10   #33  |  Link
kedautinh12
Originally Posted by GMJCZP View Post
For example:
Thanks
Old 2nd October 2021, 05:34   #34  |  Link
kedautinh12
FDK-AAC-1.0.2-Git-2021-08-24
https://drive.google.com/file/d/1hlw...ew?usp=sharing
Old 2nd October 2021, 10:48   #35  |  Link
tebasuna51
tebasuna51's Avatar
Without changes in source code with the previous encode, only change the compiler (GCC102 -> GCC103).
A test with only a wav file:
The acc obtained is bitidentical with the previous encoder.
The fdkaac.exe have less size (721.408 bytes -> 718.848)
And maybe it's a little fast (7731024 samples processed in 00:02.471 -> 00:02.469)
Old 2nd October 2021, 14:59   #36  |  Link
kedautinh12
Source code change from Apr 28 to Aug 24
https://github.com/mstorsjo/fdk-aac/commits/master
Old 2nd October 2021, 18:47   #37  |  Link
tebasuna51
tebasuna51's Avatar
Like I say you, without relevant changes. I appreciate your efort to maintan the soft updated but must be more calm.
The encoder remain the same.
We don't need change the version for a literal in a error message or a puntual error in a specific compiler (from 2014) than not solve any bug in any encode.
Old 3rd June 2022, 13:25   #38  |  Link
kedautinh12
FDK-AAC v1.0.2 (2022-05-31)
https://www.mediafire.com/file/rjper2eoao58sfs/
Old 15th July 2022, 02:22   #39  |  Link
kedautinh12
FDK-AAC v1.0.3
https://www.mediafire.com/file/y4dltl4v51kwpue
Old 3rd August 2022, 16:06   #40  |  Link
Spo3tniKK
Thank you very much!
Spo3tniKK is offline   Reply With Quote
