19th May 2013, 20:36 | #1 | Link |
Solved: Seamless branching gone wrong. Can someone asist?
Edit: problem solved and link updated.
I'm trying to create a multi-angle and seamless branching demo DVD with a tool I'm coding. So far, it works most of the time, except I got one scene which totally fails on my standalone SEG player. (which is very picky about correct buffering.) On it, all runs perfectly seamless, except for VOB id 5, Cell 2. There, the video gets very jerky and also plays one chunk from VOB id 4 inbetween which it is not supposed to. This problem does not occur on any of my software players and neither on the PS3. There must be some detail I did not think of yet, or some unnoticed bug. Can someone please check my test image? Maybe you can find an oversight. Note, that there are no seamless angle pointers yet, which is on my todo list. However, since neither VOB id 4 nor 5 are part of any multi-angle scene, that can't be the problem. Get the image (7 MB) here: http://www.abmischung.de/branchtest.7z
AMD Ryzen 5, 16 GM RAM, Nvidia GTX 1060, Linux Mint Last edited by LogicDeLuxe; 21st January 2014 at 13:46. |
20th May 2013, 18:21 | #2 | Link |
Big Bit Savings Now !
PCGEdit finds 2 (VTS 1, TTN 1) respectively 3 (VTS 1 TTN 2) cells flagged as seamless
where gaps exist and therefore the seamless flag should be unset. Maybe this helps ?
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 20th May 2013 at 18:30. |
21st May 2013, 12:00 | #3 | Link |
Thanks for taking a look.
What gap is PGCedit exactly refering to? Is it that some sectors are skipped? There are always jumps of a couple of seconds somewhere when seamless branching or multi-angle is involved, which should be perfectly fine and merely requires a slightly lower bitrate to give the player room to refill its buffers. Or has the gap todo with audio? Every VOB id's frame count is a multiple of 4 which makes it possible to the cut AC3 audio to the exact same duration (for PAL video), which I did. I also made sure, that there are no AC3 frames omitted, which most multiplexers do with a negative audio delay specified, unfortunately, but IFOedit doesn't. The problem doesn't occur at the seams anyway, which seem to work perfect, except in the middle of VOB id 5, Cell 2. Is there anything in particular I have to look for at cell boundaries (within the same VOB id) in interleaved streams maybe? In the meantime, I got multi-angle pointers implemented, but like I expected, it has no effect on this particular issue.
AMD Ryzen 5, 16 GM RAM, Nvidia GTX 1060, Linux Mint |
21st May 2013, 12:05 | #4 | Link |
I very much doubt that you can spot seamless issues with any software player, as this occurs only when the player has insufficient buffering (memory is expensive in a standalone).
Born in the USB (not USA) |
21st May 2013, 20:07 | #5 | Link | |
PS3 is not the same as standalone DVD player, so not good for testing. |
22nd May 2013, 13:23 | #6 | Link | ||||
It doesn't seem to be a cell boundary issue. I tried moving the chapter mark at the beginning of VOB id 4 so that VOB ids 4 and 5 can have just one cell each. The playback problem remains the same and still occurs in the second half of VOB id 5.
22nd May 2013, 14:19 | #7 | Link |
Both use more or less the same algorithm - interleaving of programs in order to allow a standalone, with a very limited on-board memory and with a max. 2x optical drive, to follow one of the paths without causing underbuffer.
22nd May 2013, 15:58 | #8 | Link | |
As I said- good luck- there are not many commercially released discs with seamless branching, because there are compatibility problems. Many players will never play such a disc fine anyway and this will be player's fault, not yours. You are relying on many apps, which may have some bugs etc, so really good luck Let us know if you make it working fine on few players Last edited by kolak; 22nd May 2013 at 16:02. |
22nd May 2013, 20:40 | #9 | Link | |
Angle change does only occur at an ILVU boundary, so why is a fixed GOP structure so important?
22nd May 2013, 23:35 | #10 | Link |
If ILVU then maintaining CBR AND Closed GOPs AND similar GOP structure safely delivers close (in terms of block distance)
skips when performing an angle change. So after a GOP is played and angle change is to be performed even with the minimum buffer the decoder always gets to see the next angle's playable I-frame data soon enough because it is indeed already in the buffer and/or the head doesn't have to move too far. This would be a very different scenario with VBR, where a more bit-hungry angle would require reading far ahead from its more bit-content partner angle. Then when user calls an angle change both positions in sector counts would differ much more. Harder to be able play the other angle from the same piece in time without a reasonable switching/searching delay, I guess.
21st January 2014, 13:44 | #11 | Link |
I got it sorted. Here is the new image: http://www.abmischung.de/branchtest.7z
The problem with the last image was that some entries in the nav packs for next ILVU's size were wrong. Apparently, the majority of players don't use that entry, but rely on the tables in the IFO files instead, thus didn't display this error. Thanks for your suggestions anyway.
21st January 2014, 23:26 | #12 | Link |
Hats off. You did it.
19th November 2014, 23:29 | #13 | Link |
My seamless branching and multi-angle authoring is in a usable state now. It is PAL only, though.
I tested it with quite some movies and also several different players. I have put a demo iso file to a more permanent place on my homepage here: http://www.abmischung.de/video_examples_en.html
29th November 2014, 19:15 | #14 | Link |
Wow. You did it again. Multiangle and seamless.
Your software is a muxer only ? Do you have to control encoder manually? Now with real-life footage and what about CGOP, bitrate modes, CBR (or even VBR, which deviation ranges allowed ?)
1st December 2014, 17:00 | #15 | Link | |||
3rd December 2014, 23:42 | #16 | Link |
That's impressive. Congratulations.
