Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > DVD burning
Old 18th August 2014, 03:49   #21  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Ah, antivirus. That's more specific.
ImgBurn uses "Open Candy", an adware installing platform.
The warnings are just for PUP (Potentially Unwanted Programs).
Are you on single-user computer or share with family? Or even a work computer?
Try installing with "Run as Administrator".
The AV should only be affecting the .tmp adware files that are removed after you close the isntaller.
It shouldn't be affecting the install.
I've seen a lot of threads about virus/malware when installing.
Those might be more relevant.
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
