Old 3rd July 2008, 00:40   #41  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
It's not quite there yet
Backing up HD-DVD / BluRay is quite doable, and once you've done a few it's not bad at all.
But - it's nowhere NEAR as easy as DVD Shrink. With that lovely little app you do this:
1) Insert disc
2) Select features you want
3) Encode / Burn
With HD, you have to
1) Decrypt EVOs/M2TS files on the fly with AnyDVD HD
2) Probe the file structure to find your target streams using eac3to, and output these to elementary streams on your hard drive - possibly re-encoding audio on the fly
3) Load the elementary video stream into AviSynth and write a filter chain as necessary
4) Load the AviSynth script into encoding software, and encode as you please
5) Mux the video and audio
~MiSfit
Old 3rd July 2008, 09:52   #42  |  Link
Octo-puss
Thanks! That's EXACTLY that kind of answer I wanted.
All of these steps are needed and can't be done differently then?
Octo-puss is offline   Reply With Quote
Old 3rd July 2008, 15:51   #43  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
1) Install AnyDVD HD
2) Select any EVO/M2ts in RipBot264
Old 4th July 2008, 08:40   #44  |  Link
dat720
Originally Posted by Octo-puss View Post
Well, it's not that easy with zero knowledge. But ok.
There is a thread titled DVD Shrink for Blu Ray in the decrypting forum which contains the answer to your question, if you also notice in my signature there is a guide which covers converting HD/BluRay to avi/mkv.
I don't mean to sound rude or like a dick!! but i have put up with some of the stupidest questions from public servants everyday, and get a little snappy sorry.
dat720 is offline   Reply With Quote
Old 4th July 2008, 08:42   #45  |  Link
dat720
Have you tried encoding the streams directly? if you haven't tried or noticed, mencoder can do it without requiring avs script's and it cut's out a hell of a lot of steps!
Old 24th July 2008, 21:54   #46  |  Link
odin24
odin24's Avatar
Location: The Great North (the better half of North America)
BD ripping issue.
Has anybody experienced this issue?
I recently ripped a BD with AnyDVD HD, the m2ts main movie file played back on my PC scrambled with the entire screen pixelized and green. The exact same file played fine on my PS3.
odin24 is offline   Reply With Quote
Old 30th July 2008, 17:16   #47  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
What were you using to play the file? Also, what version of AnyDVD HD were you using?
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Old 30th July 2008, 20:17   #48  |  Link
odin24
odin24's Avatar
I double checked my FFDshow configurations and found that VC1 was diasbled, thus the scrambled playback only on my PC, fine on my PS3. I'm not sure how VC1 was disabled, but I'm good now.
Thanks for the reply.
Old 28th August 2008, 15:44   #49  |  Link
mrginthehouse@hotmail.com
After ive decrypted a blu-ray film useing br decrypter and then play it back it comes up
unsorported file.can any one help.
mrginthehouse@hotmail.com is offline   Reply With Quote
Old 9th October 2008, 00:43   #50  |  Link
gonwk
@ awhitehead,
THANKS for the Great Thread!
G!
gonwk is offline   Reply With Quote
Old 24th September 2009, 12:45   #51  |  Link
james.chung
Hi! Everyone, i just start to copy the blu-ray movies about two mouths, but i fail many, many, many times, i waste many blank BD-R disc. Finally, i did sucessfully using the two solfwares which is AnydvdHD & Blue Cloner, but After i copy it, i can't play it back on the computer, it's very rare! Only i can play it back on my home Blu-ray player. Anyone knows what's going on? One more thing is that 50GB BD-R DL is a MUST to do the job! Because there's no such solfware to shrink the BD yet. Hopefully, it'll coming soon!
james.chung is offline   Reply With Quote
Old 24th September 2009, 20:12   #52  |  Link
setarip_old
setarip_old's Avatar
@james.chung
Hi!
"BD-Rebuilder" will compress BluRay discs to either FULL (including menus and extras) or movie-only versions that can be burned to any size BluRay media and/or DVD5 and DVD9, for playback on both standalone players and PC software players...
setarip_old is offline   Reply With Quote
Old 19th October 2009, 15:52   #53  |  Link
james.chung
@setarip_old
How are you doing? I have another problem, i just brought a Mr. & Mrs Smith BD, but i cannot make a copy using both Blue Cloner & DVDFab with anydvd HD work in the background, The DVDFab just shut down everytime it reading the disc, and the Blue Cloner just make a copy, but only show the preview and main menu, it cannot play the movie. All other BD movie i have, so far it didn't give me any problem. Any idea? by the way, i didn't intall the BD rebuilder yet, i tried before, but i can't install it sucessfuly for some reason. Anyway, hope you can help me, or anyone who read this message. Take care! And thank you very much!!!!!!
Old 19th October 2009, 16:44   #54  |  Link
setarip_old
@james.chung
Hi!
As of today, a properly and completely installed "MakeMKV" (including the most current "SVQ" folder and files) should by itself (No need for "AnyDVD") be able to rip the "Mr. and Mrs. Smith" BluRay directly to .MKV...
Old 20th October 2009, 03:11   #55  |  Link
@james.chung
Please start a new thread for your problems. Don't pollute info stickies!
Old 5th June 2010, 01:24   #56  |  Link
starscomeout
Which software should I use?
Hi All,
I have not ripped any of my Blu-ray or HD DVDs to hdd as of yet, but have a large number of standard DVDs ripped to hard drives, which was done with using DVD-shrink. I now want to start ripping my HD and Blu-ray movies to hdd. I have on order, yet to arrive, a LG Blu-ray/HD combo drive. I am finding it a little confusing to what software I should be using to rip both my HD and Blu-ray movies with, and what is good software I should be using to play back the ripped files? I have read the starting of this thread, but I am not sure if it is out of date or not since it was started in 2007, so I would appreciate any help/advice that anyone could provide me.
Best Regards,
Don
starscomeout is offline   Reply With Quote
Old 25th December 2020, 13:18   #57  |  Link
finlay31
The post was long but it was helpful.
finlay31 is offline   Reply With Quote
