2nd March 2009, 08:36 | #1281 | Link | ||
Programmer (or just 教务长)
Dean |
2nd March 2009, 10:18 | #1282 | Link |
A minor update (build 421): Players will show proper title count instead of 40 (when using jump/go to title)
My primary update server is still down, so when you update it will give you error on 1st mirror url but then will download the update from the second mirror. Dean Last edited by deank; 2nd March 2009 at 10:22. |
2nd March 2009, 10:27 | #1283 | Link |
Programmer
Okay, I am ready here to test the Panasonic SD playback on standalone Panasonic BD player
It turned out that I did not have the right card, but I have invested in a new reader/writer that supports SDHC and purchased a 8GB SDHC Class 4 card. I wanted to download the test files that were posted in another post in this thread, but it looks like they were removed. |
2nd March 2009, 11:37 | #1285 | Link | |
2nd March 2009, 14:34 | #1286 | Link | |
2nd March 2009, 15:58 | #1287 | Link |
Ive a Question
How much Space/Filesize in MB are taking the Menus from multiAVCHD ? Because i have to calculate the Bitrate for a few x264 AVCHD encodes and i dont want ot give to much Bitrate because i want author them later to AVCHD with Menu via MultiAVCHD Is there a minimum and maximum Filesize for Menus with one or MultiTrack AVCHD Discs? Last edited by ACrowley; 2nd March 2009 at 16:34. |
2nd March 2009, 17:47 | #1288 | Link |
You can do some tests yourself and check the size of all m2ts files with filenames from 1200 to 1406. Usually just about 5MB.
************** Here is a small preview of what I'm currently working on: I hope you like it. I have some more things to fix but I guess it will be out soon. |
2nd March 2009, 19:38 | #1290 | Link | |
FinalCut´ter
If you get this to work properly ... you will get a memorial statue in the fameous hall of programmers. That looks more than great. Last edited by kenguru2005; 2nd March 2009 at 20:04. |
2nd March 2009, 21:46 | #1291 | Link |
Thank you Dean !
Another donator !
My first post on this forum would be to thank you for this great app. ( Come on guys so many users and so few donators ? ) I am really looking forward the implementation of ability to use SD cards. Keep on the good job Dean ! P-A |
3rd March 2009, 04:58 | #1295 | Link | |
Programmer
And yes, Wow, that new GUI menu support looks awesome. |
4th March 2009, 06:08 | #1300 | Link |
There is probably an easy answer to this question but I haven't been able to find it. Once you have created a AVCHD folder with a number of titles in it, can you remove titles from the folder without having to go back to the original source videos? It's easy enough to add them - just not sure how to delete them.
Thanks |
