Old 24th April 2016, 17:41   #1  |  Link
shae
Brightness histogram shader?
Can anyone suggest a shader to show pixel brightness distribution?
I assume it's possible with a shader, and specifically in MPC-HC.
shae is offline   Reply With Quote
Old 24th April 2016, 18:40   #2  |  Link
Shiandow
This is not possible with a shader.
Old 19th May 2016, 02:32   #3  |  Link
shae
Is there documentation on what shaders exactly MPC-HC implements?
I think this is similar to what I'm looking for, at least the stats collection part, but it's supposedly a compute shader:
http://tomhammersley.blogspot.com/20...n-in-dx11.html
Old 19th May 2016, 06:04   #4  |  Link
vivan
/人 ◕ ‿‿ ◕ 人\
It supports HLSL pixel shaders, with one sampler (input image) and few input register/variables (image/pitch size and pixel coordinates) that outputs one image pixel.
vivan is offline   Reply With Quote
Old 12th June 2016, 16:19   #5  |  Link
shae
Thanks. I guess ffdshow will be the simplest solution.
brightness, histogram, shader
