Old 12th November 2025, 05:17   #681  |  Link
Lathe
Lathe's Avatar
YES!!! That was it! No wonder the snippets I made for you guys worked fine, for some odd reason the file 'Needed' to be run through MKVMerge first... I ran the entire original file through MKVMerge first and NOW I am encoding it with Clever (for some bizarre reason the current version won't open anymore and I have to use the last version, weird...) and YES! it is coming out just fine.
I'm glad I stumbled on it finally! I realized that the snippets I was making had been run through MKVMerge first and encoded just fine. Still don't understand 'Why', but I'm glad I figured it out...
Thanks for all the help!
Lathe is offline   Reply With Quote
Old 12th November 2025, 07:03   #682  |  Link
oniiz86
@Lathe That's great you found the cause of the issue or a reliable workaround but still doesn't that suggest that there is still a problem with Clever FFmpeg-GUI, why should it be any different, it ought to be the same don't you think, also isn't it a bit peculiar that others aren't experiencing the issue with your sample?
oniiz86 is offline   Reply With Quote
Old 12th November 2025, 07:14   #683  |  Link
Lathe
Lathe's Avatar
Yeah, I know it's strange... So strange... Must be the Season of the Witch... OOPS, sorry, got carried away there...
Well, I don't know WHY, but the snippets were created WITH MKVMerge, so that is how I figured out that whatever MKVMerge was doing was apparently 'Fixing' it. The only thing that gave that away was trying to encode the entire original file right after encoding a snippet of it. The snippet was encoding just fine, the entire (NON-MKVMerged file) was not.
So, there you go...
Old 16th November 2025, 07:13   #684  |  Link
Lathe
Lathe's Avatar
Hmmm... I still don't know what to do when they divide the movie up into a bunch of small files in the Blu-ray folder structure. I just took a look at the full 4k folder of 'HELLRAISER III' which is about 70 Gigs or so, but there is no single movie file to process, and I don't THINK there is any way to load it in Clever...
I tried dumping the entire folder into Handbrake, but I don't think it worked. I wonder what I can do to process the movie and also the Xtras...?
Old 16th November 2025, 07:33   #685  |  Link
Lathe
Lathe's Avatar
Ah! MakeMKV to the rescue! I didn't realize that it would collate all those files in a UHD structure. Awesome, now I have a file to input to Clever! (although, I wonder if there is a way to drop the BDMV folder into the program and have it discern what the main movie file is or give you a choice of playlists to encode?
Old 16th November 2025, 09:29   #686  |  Link
GeoffreyA
Donor
Exactly, MakeMKV is the tool of choice, creating a single file to work with.
I think it can open the BDMV index file; I forget what the extension is.
GeoffreyA is offline   Reply With Quote
Old 17th November 2025, 00:41   #687  |  Link
Lathe
Lathe's Avatar
Yeah, I kinda had to guess on that one, but thankfully when MakeMKV opens a navigating window, like any program it shows only the kinds of files you can select. So yeah, I did select the index file and I was amazing when it started putting everything together.
It's interesting how that still comes up with new releases, but only occasionally... I've always thought it was simply an anti-copying device, but I wonder why you only see it once in a great while and why...?
(always curious... )
Old 19th November 2025, 22:09   #688  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
You may try DGDemux on a playlist then you can preview what is waiting, or try BDInfo.
While authoring one can decide for a versatile structure with different playlists.
then split the available assets at segment borders into various .m2ts.
Then one can shuffle and chain these available .m2ts segments for
1.: Cut versions: (directors cut / theatrical cut / extended cut)
or
2.: Language-dependent renderings
(cartoons like "Ratatouille" may show paper headlines in languages matching one's player preference like fr, en, de)
or
3.: vacation edits private/official <your ideas here>
Old 20th November 2025, 02:35   #689  |  Link
Lathe
Lathe's Avatar
or
or
Wow, I think that may be a bit over my paygrade, but thank you kindly for the suggestion!
Old 24th November 2025, 16:34   #690  |  Link
ProWo
November 24, 2025 release version 3.4.8.
New Features, many improvements, changes and fixes.
ProWo is offline   Reply With Quote
Old 25th November 2025, 01:11   #691  |  Link
Lathe
Lathe's Avatar
Looks great, thanks mate! I like that 'Toggle Destination'
It's nice all we have to do now is simply click the 'Update' button...
Old 26th November 2025, 14:57   #692  |  Link
ProWo
November 26, 2025 release version 3.4.9.
Fixed: A major bug with automatic chapters creation.
Old 21st December 2025, 09:25   #693  |  Link
ProWo
December 21, 2025 release version 3.5.0.
Old 19th January 2026, 15:17   #694  |  Link
ProWo
January 19, 2026 release version 3.5.1.
Some changes and fixes.
