Old 6th July 2020, 15:06   #21  |  Link
ProWo
July 06 2020 update to version 2.5.0.
Added: Video scan type detection (interlaced or progressive)
Modified: FFmpeg folder path.
Bugs corrected.
At the first start you have to specify ffmpeg.exe location path.
ProWo is offline   Reply With Quote
Old 14th July 2020, 09:18   #22  |  Link
ProWo
July 14 2020 update to version 2.5.2.
Added: DVD movie rip implemented (unprotected DVD's only). Point to the desired VTS and the entire movie will be ripped and imported.
Many small improvements.
Read the HowTo.txt
Old 16th July 2020, 22:04   #23  |  Link
ProWo
July 16 2020 update to version 2.5.3.
Fixed: A major bug when loading videos without duration information.
Read the HowTo.txt
Old 27th July 2020, 10:16   #24  |  Link
ProWo
July 27 2020 update to version 2.5.4.
Added: Audio Stream Language Info on Audio conversion.
Added: Audio DTS Output.
Improved: Video Stream Interlacing Detection.
Fixed: minor bugs.
Old 31st July 2020, 08:49   #25  |  Link
ProWo
July 31 2020 update to version 2.5.5.
Improved: Many fine tunings.
Fixed: minor bugs.
Old 6th August 2020, 12:24   #26  |  Link
ProWo
August 06 2020 update to version 2.5.6.
Improved: Detection of ffmpeg.exe, ffprobe.exe, ffplay.exe.
Improved. Error handling.
Fixed: minor bugs.
Old 10th August 2020, 17:15   #27  |  Link
De-M-oN
The audio section should offer
FLAC
Opus
OGG
There is no sense to put WAV in an encoding, with existence of FLAC.
So I recommend to add these 3 further major codecs.
Offer also more video encoders, especially NVEnc encoding.
De-M-oN is offline   Reply With Quote
Old 10th August 2020, 20:28   #28  |  Link
stax76
stax76's Avatar
Hello ProWo,
if you are looking for a website for your project I would like to suggest github, if open source would be an option.
It could make sense to bundle all dependencies, it's easier for people to get started and ensures that the ffmpeg built has all features you are using enabled.
Old 11th August 2020, 08:51   #29  |  Link
ProWo
FLAC
Opus
OGG
My project is meant to be a simple GUI, not a competition to Handbrake or others, so that even inexperienced users can get along with it and have the most necessary tools available. Wav as output has the purpose to allow various manipulations with all audio editors.
Old 11th August 2020, 08:54   #30  |  Link
ProWo
Originally Posted by stax76 View Post
Hello ProWo,
Hi stax76,
thanks for your input, I'll think about it.
Old 12th August 2020, 18:36   #31  |  Link
mbcd
Crashes directly on specifying sourcefile: "No given filename" on Process()
************** Ausnahmetext **************
System.InvalidOperationException: Der Prozess kann nicht gestartet werden, da ein Dateiname nicht angegeben wurde.
   bei System.Diagnostics.Process.Start()
Seems maybe ffmpeg.exe is not located.
mbcd is offline   Reply With Quote
Old 13th August 2020, 14:42   #32  |  Link
ProWo
What version?
Try the latest beta.
Old 13th August 2020, 16:10   #33  |  Link
mbcd
On both, beta and stable ... x86 and x64
Very courious behaving:
It starts only if I use it from inside the "download" folder, but not from any another drive (with full permissions).
But after a message that the stream must be copied because of a missing framerate (mkv) the UI is freezing ... and copying of these video is never completed ...
Old 13th August 2020, 16:20   #34  |  Link
ProWo
Try to delete this folder: C:\Users\user\AppData\Local\clever_FFmpeg_GUI.
user=your user name on windows
Then restart clever FFmpeg-GUI.
If you use the 64 bit version you must also use 64 bit ffmpeg.
Old 13th August 2020, 18:59   #35  |  Link
mbcd
Thank you for answering.
I respected verions of x86 and x64, that should not be a problem here.
Deleted folders in AppData.
Worked for one time, until this coying ... btw: ffmpeg has no problems with this file started manually by cmd.
Now clever_FFmpeg_GUI wont work again.
So I deleted again folder in AppData.
But on restarting clever_FFmpeg_GUI it even does not ask again for some location of ffmpeg.exe, and again this exception on loading a sourcefile appears. Folder with executable of clever_FFmpeg_GUI does not contain any ffmpeg.exe.
Lets see if others have same problems ...
Old 13th August 2020, 20:13   #36  |  Link
ProWo
Download the latest static build for your architecture (x64 or x86) from this page.
https://ffmpeg.zeranoe.com/builds/
Extract the file wherever you want. It will create a folder with a name like ffmpeg-20200812-bb59bdb-win64-static, with a bin subfolder; in this bin subfolder are the three files clever FFmpeg-GUI needs.
Delete the folder C:\Users\xxx\AppData\Local\clever_FFmpeg-GUI (where xxx=your user name on windows) again. The first time you start clever FFmpeg-GUI, navigate to the above bin folder in the folder browser. That's it. Now everything should work fine.
Old 14th August 2020, 10:09   #37  |  Link
mbcd
All this I did before ...
- Dowmloaded static build from Zeroane
- Extracted them to e:\ffmpeg-20200812-4ed6bca-win64-static
- Removed "clever_FFmpeg_GUI" from "C:\Users\XXXXX\AppData\Local"
- Extracted actual clever_FFmpeg_GUI-beta to "e:\clever_ffmpeg_gui_newest_beta"
Started "E:\clever_ffmpeg_gui_newest_beta\x64\clever FFmpeg GUI.exe"
And again ... no question for a location to the bin-folder of ffmpeg.
Opening a sourcefile results in exception again -> "No filename specified".
This is the only file in appData: "user.config":
<?xml version="1.0" encoding="utf-8"?>
<configuration>
    <configSections>
        <sectionGroup name="userSettings" type="System.Configuration.UserSettingsGroup, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" >
            <section name="clever_FFmpeg_GUI.My.MySettings" type="System.Configuration.ClientSettingsSection, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" allowExeDefinition="MachineToLocalUser" requirePermission="false" />
        </sectionGroup>
    </configSections>
    <userSettings>
        <clever_FFmpeg_GUI.My.MySettings>
            <setting name="spos_x" serializeAs="String">
                <value>175</value>
            </setting>
            <setting name="spos_y" serializeAs="String">
                <value>209</value>
            </setting>
        </clever_FFmpeg_GUI.My.MySettings>
    </userSettings>
</configuration>
As I said before, there must be some bad bug.
Where is path to ffmpeg saved? I dont see it in that user.config. And its not asked again ... so it must be saved somewhere ...
Should the be an file for Application Settings too? I dont see anyone.
Old 14th August 2020, 11:01   #38  |  Link
ProWo
Delete this file and restart clever FFmpeg-GUI.
(This file should have been in the C:\Users\XXXXX\AppData\Local\clever_FFmpeg_GUI folder).
Old 18th August 2020, 14:32   #39  |  Link
ProWo
August 18 2020 update to version 2.5.7.
Improved: Deinterlacing (Yadif: frame/frame, field/frame, interlaced marked frames only).
Added: Encode interlaced video as interlaced.
Fixed: minor bugs.
Old 20th August 2020, 10:24   #40  |  Link
mbcd
Sorry, still not working for me even with latest update.
As I said before:
There is no folder of clever_FFmpeg_GUI anymore in my appdata, but it still does not ask for a new path on restart.
You should take a look at my posted user.config.
You dont see "ffmpegPath" in there, you dont get questions about that?
Ive had a quick look into your sourcecode (as good as decompiling works), its definied to be in there, so there seems something going wrong. Some entries are missing in my user.config, every time its created.
Thats why I asked where you store path to ffmpeg ...
