#202 | Link |
Posts: n/a
Some way to save a template ??
Hi ProWo,
This is a great little app, I mostly use it for converting audio, however, I have just recently needed to change the colour space on some videos, and I find this is the easiest way to do it. But having to go thru all the settings for each new job, is a bit of a pain, is there some way that you can save the settings you use regularly, as a template or preset ?? Regards |
#203 | Link | |
Thank you for liking my program. As for your wish, I think that in most cases the tasks are different and that such templates are simply underused. Besides, it would be a considerable coding effort. |
#204 | Link | |
Posts: n/a
OK, that's fair enough, but it would be nice if there was something like an .ini file that you could edit to suit some settings that you would use EVERYTIME. Cheers |
#205 | Link | |
Posts: n/a
I have to "sing the praise's" on this little app you've created, yet again. Today I learned something about it, that is awesome, the "cut" function. I have a TV series that has the annoying "previously" review that goes for more than a minute, and I tried another idea I had, but it only cut the video. So after a bit of trial and error to see what the settings did, I was able to get all 8 episodes cut to my liking ![]() And another good thing, because it doesn't take very long to process, if you've miscalculated the start point, you just go back and run it again. This is going to be SO, SO handy for the "Game Of Throne's", for example, cutting off that "boring" intro, and so many other series & TV episode's. AWESOME ![]() ![]()
#206 | Link | |
![]() Try the latest beta (v3.0.9.02, online now). Fixed some small bugs in the cutting section. |
#207 | Link | |
Posts: n/a
My observations of the latest beta.. Using the "Cut" feature, once a clip is loaded, and you've entered the required "Start Time", you have to just quickly click on the "End Time" (which hasn't been changed) button to get the "Check Time" button to re-appear, to proceed. Also, is seems that you have to "Quit" the app, if you want to edit another clip, not a big problem, tho. Other than that, it's been working well ![]() EDIT:- A bit more info, regarding HDR10 & HDR10+.. This is the original MediaInfo:- Code:
Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5@Main HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 1 h 7 min Bit rate : 3 070 kb/s Width : 3 840 pixels Height : 1 600 pixels Display aspect ratio : 2.40:1 Frame rate mode : Constant Frame rate : 24.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.021 Stream size : 1.44 GiB (94%) Language : English Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 197 cd/m2 Maximum Frame-Average Light Level : 137 cd/m2 Code:
Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5@Main HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 1 h 5 min Bit rate : 3 070 kb/s Width : 3 840 pixels Height : 1 600 pixels Display aspect ratio : 2.40:1 Frame rate mode : Variable Frame rate : 24.518 FPS Original frame rate : 24.000 FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 0) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.020 Stream size : 1.44 GiB (96%) Writing library : x265 3.5+86-6da609e41:[Windows][GCC 12.2.0][64 bit] 10bit Encoding settings : cpuid=1111039 Language : English Default : No Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant EDIT #2:- I changed the "P-level" to 6.2, and now it seems to be OK...so it's just a learning curve. Code:
Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L6.2@Main HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 1 h 7 min Bit rate : 3 070 kb/s Width : 3 840 pixels Height : 1 600 pixels Display aspect ratio : 2.40:1 Frame rate mode : Constant Frame rate : 24.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.021 Stream size : 1.44 GiB (94%) Language : English Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 197 cd/m2 Maximum Frame-Average Light Level : 137 cd/m2 ![]() EDIT #3:- No, there is still something with running it thru "Cut" that changes it, again. Is there a way to have multiple settings at the same time, as it appears that every option, is a seperate process. eg:- can't do a cut, AND a P-level change at the same time. If I do a P-level change to get the HDR10 & HDR10+ displayed in MediaInfo, doing a "Cut" on the converted clip, removes the HDR10+. Last edited by TDS; 8th March 2023 at 08:32. |
#208 | Link | ||
As for HDR10 / HDR10+: Did you use the Keyframe Cut variant? If so, the original file is only cut and remuxed. It may be that the FFmeg mkv muxer changes/forgets/not copies some tags. But the video track should remain unchanged and keep all characteristics of the original video track. I think the changed tags are just cosmetic. |
#209 | Link | |
Posts: n/a
Like I said, I'm on a learning curve with this, but I'm sure Ill get there. I'll "take note" of the settings I've been using, and report back. EDIT:- new day, more testing (or familiarization), I wasn't using "Frame Cut", so I have just ran one thru using "Frame Cut", and indeed, it retains (display's) HDR10/HDR10+ in MediaInfo. , However, the problem with using "Frame Cut", it's not cutting it exactly where it needs to be, so I might have to do "Frame Accurate Cut", and then run it thru to change the "P-frame" ![]() OK, just did the "P-frame" test, and that didn't bring back the HDR10+, but the HDR10 is there, so like you said, it might just be cosmetic. And not that it should matter, but I running FFMPEG 6.0 EDIT #2:- OK, everything seems to be going OK, I am editing "The Game of Thrones", and Season 1 is 6.2 HDR, and after the "Cut", it still is, however, Season 2 (and up to Season 7) are "only" 5.1 HDR, and after a "Cut", they are 5.0, but no HDR "flag" in MediaInfo, and I can't change that outcome. I've just noticed that some are being changed from 5.1 to 5, and that might be why the HDR flag is missing, as the one that are still 5.1 are still showing as HDR. I think that there might need to be some way to change the P-level from the "Cut" page, not a separate operation. But even tho it's not "flagged" as HDR, when I play the edited clips in PotPlayer, they are indicated to be HDR.... And another strange thing, every so often, when you "Check Times", it throws up an error about the "search range being too small". I've noticed you don't get much feedback, so I hope you don't mind me bothering you.... Last edited by TDS; 9th March 2023 at 05:22. |
#210 | Link |
Posts: n/a
Latest beta version v3.0.9.03
Noticed you posted this on page 1, so I have just tried that, not sure what the differences are, as you didn't post anything about it (like you usually do). Still randomly changing the P-levels, I think I'm going to have to re-encode them first to 6.2 HDR10/HDR10+, and then run them thru "Cut". Cheers |
#211 | Link | |
If you want you can try it, online now. Last edited by ProWo; 10th March 2023 at 15:01. |
#212 | Link | |
Posts: n/a
OK, looking forward to what you've done, however, attaching the app like you have, is not a good way to do anything on this Forum, due to the "Attachments Pending Approval", can take a LONG time...might be best to either wait 'til you've made in available for everyone, or upload it to MediaFire or similar, then provide a link. Regards. |
#214 | Link | |
Posts: n/a
I'm using it on the same PC, same files. I can't see any differences ![]() And the player doesn't display, you can hear it, but you can't see it, then it stops, and has a mini lockup, then you have to press ESC. Ran one file thru "Cut", and it's still downgrading from Level 5.1 to 5, and no HDR10 info is displayed in MediaInfo. But PotPlayer detects it as being HDR.... Strange...I will try it again after I have re-encoded to Level 6.2. Cheers |
#219 | Link |
Posts: n/a
Hi, I certainly will, but tomorrow (my time).
Will report back, of course, thanks ![]() EDIT:- Well, I really don't know what's going on with this, but I think I've stumbled on what's is making this change the P-level & HDR10 status... IF I don't do any cutting, the P-level & HDR10 status don't change, HOWEVER, when I do do a cut, that when things get messed up. So here is a link to a 5 minute sample of the video that I am working on (and some before & after MediaInfo)... test sample Last edited by TDS; 15th March 2023 at 02:09. |
#220 | Link | |
No problems here. Same P-Level as source.
| Display Modes | |
