#162 | Link |
Thanks for this. VapourSynth looks like a lot of effort to get going with, so I tried AviSynth+. Installed over the top like it suggests. Works a treat. Had to remove the SetMTMode() stuff from my scripts, aside from that it's running without issues. Yet to see if it crashes or not, but currently getting double the fps encoding rate compared to the old AviSynth so I'm pretty happy so far.
#163 | Link | |
Groucho's Avisynth Stuff Last edited by Groucho2004; 4th September 2016 at 10:56. |
#164 | Link |
The biggest differences are MT related. If you're not using it at all, you won't notice any differences without looking for new functionality. If you are, you'll have to do what Groucho2004 said to Statick. Either way you're better off, to be honest.
#168 | Link | |
okay well it seems I'm still having crashes with QTGMC and x265
I've removed all references to MT from my script, so crashes due to that have been eliminated. I've tried this with the AviSynthMT dll, original AviSynth dll, and AviSynth+, and I get the same result regardless of which I use. I've also tried using my high quality x265 settings and the "ultra fast" preset, it makes no difference which I use The encode reaches 100% and then crashes at the end with an access violation. If I remove QTGMC from the script, the encode works fine, if I use x264 instead of x265 the encode works fine. QTGMC into x265 crashes this same way every time, at 100% when the encode is completed. Any thoughts? Quote:
#169 | Link |
Statick!
Note version all Avisynth and plugin, better use Avsmeter (http://forum.doom9.org/showthread.ph...08#post1585008) and send log. I am recently use QTGMC for encoding by x265 both version 32 bit and 64 bit without problem with Avisynth+. I think problem related with plugins. yup. |
#170 | Link |
@Statick
As yup pointed out, this may be related to a wonky plugin in your auto-load directory. Run "AVSMeter -avsinfo -log", this will create a log file ("avsinfo.log"). Post the log file.
Groucho's Avisynth Stuff Last edited by Groucho2004; 8th September 2016 at 11:58. Reason: Typo |
#171 | Link |
wow, that is a useful tool! thanks for that
looks like I have a problem with yadif.dll just tried replacing that dll with the one from the QTGMC VitMod plugin package in the first post (which I'm pretty sure is where this dll came from in the first place) and still getting the same error Code:
Log created with: AVSMeter 2.3.8 (x86)
[OS/Hardware info]
Operating system: Windows 10 (x64) (Build 14393)
CPU: AMD FX(tm)-8320 Eight-Core Processor
Vishera X4
CPU clock (measured): 3690 MHz
CPU cores / Logical cores: 8 / 8
[Avisynth core info]
VersionString: AviSynth 2.60, build:Mar 31 2015 [16:38:54]
VersionNumber: 2.60
File version: 2.6.0.6
Interface Version: 6
Multi-threading support: No
Linker/compiler version: 6.0
Avisynth.dll location: C:\Windows\SysWOW64\avisynth.dll
Avisynth.dll time stamp: 2015-03-31, 07:40:58
PluginDir2_5 (HKLM, x86): C:\Program Files (x86)\AviSynth\plugins
[Avisynth CPP 2.6 plugins]
C:\Program Files (x86)\AviSynth\plugins\DirectShowSource.dll (2.6.0.3)
C:\Program Files (x86)\AviSynth\plugins\mt_masktools-26.dll (2.0.48.0)
C:\Program Files (x86)\AviSynth\plugins\RgTools.dll (n/a)
C:\Program Files (x86)\AviSynth\plugins\TCPDeliver.dll (2.6.0.7)
[Avisynth CPP 2.5 plugins]
C:\Program Files (x86)\AviSynth\plugins\AddGrainC.dll (1.5.2.0)
C:\Program Files (x86)\AviSynth\plugins\avstp.dll (1.0.1.0)
C:\Program Files (x86)\AviSynth\plugins\dfttest.dll (1.9.4.0)
C:\Program Files (x86)\AviSynth\plugins\EEDI2.dll (0.9.2.0)
C:\Program Files (x86)\AviSynth\plugins\eedi3.dll (0.9.1.0)
C:\Program Files (x86)\AviSynth\plugins\FFT3DFilter.dll (2.1.1.0)
C:\Program Files (x86)\AviSynth\plugins\mvtools2.dll (2.6.0.5)
C:\Program Files (x86)\AviSynth\plugins\nnedi.dll (1.3.0.0)
C:\Program Files (x86)\AviSynth\plugins\nnedi2.dll (1.6.0.0)
C:\Program Files (x86)\AviSynth\plugins\nnedi3.dll (0.9.4.0)
C:\Program Files (x86)\AviSynth\plugins\SSE2Tools.dll (n/a)
C:\Program Files (x86)\AviSynth\plugins\TDeint.dll (1.1.0.0)
[Avisynth C 2.5 plugins]
C:\Program Files (x86)\AviSynth\plugins\yadif.dll (1.7.0.0)
(!) Plugin errors found, see section [Plugin errors] at the end of this document.
[Internal (core) functions]
AVIFileSource
AVISource
AddBorders
AlignedSplice
Amplify
AmplifydB
Animate
Apply
ApplyRange
Assert
AssumeBFF
AssumeFPS
AssumeFieldBased
AssumeFrameBased
AssumeSampleRate
AssumeScaledFPS
AssumeTFF
AudioDub
AudioDubEx
AudioTrim
AverageChromaU
AverageChromaV
AverageLuma
BicubicResize
BilinearResize
BlackmanResize
Blackness
BlankClip
Blur
Bob
Cache
ChangeFPS
Chr
ChromaUDifference
ChromaVDifference
ColorBars
ColorBarsHD
ColorKeyMask
ColorYUV
Compare
ComplementParity
ConditionalFilter
ConditionalReader
ConditionalSelect
ContinuedDenominator
ContinuedNumerator
ConvertAudio
ConvertAudioTo16bit
ConvertAudioTo24bit
ConvertAudioTo32bit
ConvertAudioTo8bit
ConvertAudioToFloat
ConvertBackToYUY2
ConvertFPS
ConvertToMono
ConvertToRGB
ConvertToRGB24
ConvertToRGB32
ConvertToY8
ConvertToYUY2
ConvertToYV12
ConvertToYV16
ConvertToYV24
ConvertToYV411
Crop
CropBottom
Default
Defined
DelayAudio
DeleteFrame
DirectShowSource
Dissolve
DoubleWeave
DuplicateFrame
Echo
EnsureVBRMP3Sync
Eval
Exist
FadeIO
FadeIO0
FadeIO2
FadeIn
FadeIn0
FadeIn2
FadeOut
FadeOut0
FadeOut2
FixBrokenChromaUpsampling
FixLuminance
FlipHorizontal
FlipVertical
FrameEvaluate
FreezeFrame
GaussResize
GeneralConvolution
GetChannel
GetChannels
GetLeftChannel
GetParity
GetRightChannel
Grayscale
Greyscale
HasAudio
HasVideo
Hex
Histogram
HorizontalReduceBy2
ImageReader
ImageSource
ImageSourceAnim
ImageWriter
Import
Info
Interleave
InternalCache
Invert
IsAudioFloat
IsAudioInt
IsBool
IsClip
IsFieldBased
IsFloat
IsFrameBased
IsInt
IsInterleaved
IsPlanar
IsRGB
IsRGB24
IsRGB32
IsString
IsY8
IsYUV
IsYUY2
IsYV12
IsYV16
IsYV24
IsYV411
KillAudio
KillVideo
Lanczos4Resize
LanczosResize
Layer
Letterbox
Levels
Limiter
LoadCPlugin
LoadPlugin
LoadVFAPIPlugin
LoadVirtualdubPlugin
Load_Stdcall_Plugin
Loop
LumaDifference
Mask
MaskHS
Max
Merge
MergeARGB
MergeChannels
MergeChroma
MergeLuma
MergeRGB
MessageClip
Min
MixAudio
MonoToStereo
Normalize
Null
OpenDMLSource
Ord
Overlay
PeculiarBlend
PixelType
PointResize
Preroll
Pulldown
RGBAdjust
RGBDifference
RGBDifferenceFromPrevious
RGBDifferenceToNext
ReduceBy2
ResampleAudio
ResetMask
Reverse
SSRC
ScriptClip
ScriptDir
ScriptFile
ScriptName
SegmentedAVISource
SegmentedDirectShowSource
Select
SelectEven
SelectEvery
SelectOdd
SelectRangeEvery
SeparateColumns
SeparateFields
SeparateRows
SetMemoryMax
SetPlanarLegacyAlignment
SetWorkingDir
Sharpen
ShowAlpha
ShowBlue
ShowFiveVersions
ShowFrameNumber
ShowGreen
ShowRed
ShowSMPTE
ShowTime
SincResize
SkewRows
SpatialSoften
Spline
Spline16Resize
Spline36Resize
Spline64Resize
StackHorizontal
StackVertical
String
Subtitle
Subtract
SuperEQ
SwapFields
SwapUV
TCPServer
TCPSource
TemporalSoften
Time
TimeStretch
Tone
Trim
Turn180
TurnLeft
TurnRight
Tweak
UDifferenceFromPrevious
UDifferenceToNext
UPlaneMax
UPlaneMedian
UPlaneMin
UPlaneMinMaxDifference
UToY
UToY8
UnalignedSplice
VDifferenceFromPrevious
VDifferenceToNext
VPlaneMax
VPlaneMedian
VPlaneMin
VPlaneMinMaxDifference
VToY
VToY8
Version
VersionNumber
VersionString
VerticalReduceBy2
WAVSource
Weave
WeaveColumns
WeaveRows
WriteFile
WriteFileEnd
WriteFileIf
WriteFileStart
YDifferenceFromPrevious
YDifferenceToNext
YPlaneMax
YPlaneMedian
YPlaneMin
YPlaneMinMaxDifference
YToUV
abs
acos
asin
atan
atan2
audiobits
audiochannels
audioduration
audiolength
audiolengthf
audiolengthhi
audiolengthlo
audiolengths
audiorate
bitand
bitchange
bitchg
bitclear
bitclr
bitlrotate
bitlshift
bitlshifta
bitlshiftl
bitlshifts
bitlshiftu
bitnot
bitor
bitrol
bitror
bitrrotate
bitrshifta
bitrshiftl
bitrshifts
bitrshiftu
bitsal
bitsar
bitset
bitshl
bitshr
bittest
bittst
bitxor
ceil
cos
cosh
exp
fillstr
findstr
float
floor
fmod
frac
framecount
framerate
frameratedenominator
frameratenumerator
height
hexvalue
int
lcase
leftstr
log
log10
midstr
muldiv
nop
pi
pow
rand
revstr
rightstr
round
sign
sin
sinh
sqrt
strcmp
strcmpi
strlen
tan
tanh
ucase
undefined
value
width
[External (plugin) functions]
AddGrain
AddGrainC
AddGrainC_AddGrain
AddGrainC_AddGrainC
AmplifyDifference
BackwardClense
Clense
Difference
DirectShowSource
DirectShowSource_DirectShowSource
EEDI2
EEDI2_EEDI2
FFT3DFilter
FFT3DFilter_FFT3DFilter
ForwardClense
Interleaved2Planar
LimitChange
MAnalyse
MBlockFps
MCompensate
MDegrain1
MDegrain2
MDegrain3
MDegrainN
MDepan
MFlow
MFlowBlur
MFlowFps
MFlowInter
MMask
MRecalculate
MRestoreVect
MSCDetection
MScaleVect
MShow
MStoreVect
MSuper
Planar2Interleaved
Quadruple
ReduceFluctuations
RemoveGrain
Repair
RgTools_BackwardClense
RgTools_Clense
RgTools_ForwardClense
RgTools_RemoveGrain
RgTools_Repair
RgTools_VerticalCleaner
SSE2Tools_AmplifyDifference
SSE2Tools_Difference
SSE2Tools_Interleaved2Planar
SSE2Tools_LimitChange
SSE2Tools_Planar2Interleaved
SSE2Tools_Quadruple
SSE2Tools_ReduceFluctuations
SSE2Tools_Shrinkby2
SSE2Tools_TransformColor
SSE2Tools_Truncate
Shrinkby2
TCPDeliver_TCPServer
TCPDeliver_TCPSource
TCPServer
TCPSource
TDeint
TDeint_TDeint
TDeint_TSwitch
TSwitch
TransformColor
Truncate
VerticalCleaner
avstp_avstp_set_threads
avstp_set_threads
dfttest
dfttest_dfttest
eedi3
eedi3_eedi3
eedi3_eedi3_rpow2
eedi3_rpow2
mt_adddiff
mt_average
mt_binarize
mt_circle
mt_clamp
mt_convolution
mt_deflate
mt_diamond
mt_edge
mt_ellipse
mt_expand
mt_freeellipse
mt_freelosange
mt_freerectangle
mt_gradient
mt_hysteresis
mt_infix
mt_inflate
mt_inpand
mt_invert
mt_logic
mt_losange
mt_lut
mt_lutf
mt_luts
mt_lutspa
mt_lutsx
mt_lutxy
mt_lutxyz
mt_makediff
mt_mappedblur
mt_masktools-26_mt_adddiff
mt_masktools-26_mt_average
mt_masktools-26_mt_binarize
mt_masktools-26_mt_circle
mt_masktools-26_mt_clamp
mt_masktools-26_mt_convolution
mt_masktools-26_mt_deflate
mt_masktools-26_mt_diamond
mt_masktools-26_mt_edge
mt_masktools-26_mt_ellipse
mt_masktools-26_mt_expand
mt_masktools-26_mt_freeellipse
mt_masktools-26_mt_freelosange
mt_masktools-26_mt_freerectangle
mt_masktools-26_mt_gradient
mt_masktools-26_mt_hysteresis
mt_masktools-26_mt_infix
mt_masktools-26_mt_inflate
mt_masktools-26_mt_inpand
mt_masktools-26_mt_invert
mt_masktools-26_mt_logic
mt_masktools-26_mt_losange
mt_masktools-26_mt_lut
mt_masktools-26_mt_lutf
mt_masktools-26_mt_luts
mt_masktools-26_mt_lutspa
mt_masktools-26_mt_lutsx
mt_masktools-26_mt_lutxy
mt_masktools-26_mt_lutxyz
mt_masktools-26_mt_makediff
mt_masktools-26_mt_mappedblur
mt_masktools-26_mt_merge
mt_masktools-26_mt_motion
mt_masktools-26_mt_polish
mt_masktools-26_mt_rectangle
mt_masktools-26_mt_square
mt_merge
mt_motion
mt_polish
mt_rectangle
mt_square
mvtools2_MAnalyse
mvtools2_MBlockFps
mvtools2_MCompensate
mvtools2_MDegrain1
mvtools2_MDegrain2
mvtools2_MDegrain3
mvtools2_MDegrainN
mvtools2_MDepan
mvtools2_MFlow
mvtools2_MFlowBlur
mvtools2_MFlowFps
mvtools2_MFlowInter
mvtools2_MMask
mvtools2_MRecalculate
mvtools2_MRestoreVect
mvtools2_MSCDetection
mvtools2_MScaleVect
mvtools2_MShow
mvtools2_MStoreVect
mvtools2_MSuper
nnedi
nnedi2
nnedi2_nnedi2
nnedi2_nnedi2_rpow2
nnedi2_rpow2
nnedi3
nnedi3_nnedi3
nnedi3_nnedi3_rpow2
nnedi3_rpow2
nnedi_nnedi
[Plugin errors]
Plugin C:\Program Files (x86)\AviSynth\plugins\yadif.dll is not an AviSynth 2.6 or 2.5 plugin.
Note: C-Plugins must be loaded explicitly with "LoadCPlugin()"
#172 | Link | |
#173 | Link |
@Statick
1. Remove "mt_masktools-26.dll" and use masktools from here 2. Remove "avstp.dll" Let's see if that helps.
Groucho's Avisynth Stuff |
#174 | Link |
Also, post your full script.
#176 | Link |
Ah, OK (I'm not familiar with GUIs). One more thing you might try is restrict the source filter to one thread (add "threads = 1" to LWLibavVideoSource).
#177 | Link |
okay I've removed mt_masktools.dll and used the dll from the link, removed avstp.dll, and added "threads = 1" to LWLibavVideoSource. I've also tried going back to AviSynth+.
still getting the same crash at 100% appreciate the help here guys! any more ideas? |
#179 | Link |
I'm out of ideas. I am however pretty sure that it's not the filter chain, especially since it doesn't happen with x264. Maybe you should post this in the megui subforum.
#180 | Link | |
I'll try another encode and report back if it works |
| Display Modes | |
