Old 16th April 2009, 05:45   #21  |  Link
turbojet
FULL-BD refers to BD-Rebuilder output though so while it may sound misleading when concerning retail BD it plays no role in the graph.
It could also be BD5/9 have PIP issues while BD25/50 don't. I didn't remember seeing any mention of red or blue laser media being used in the reports of it working or not working.
At first I wasn't planning on having the FULL-BD column as there's already a nice list of confirmed working players but I thought it might help to list what players have been tested and don't work.
Old 16th April 2009, 19:00   #22  |  Link
Rodger
Samsung bd-p2500 news !!!
NEW FIRMWARE IS OUT !!!
http://support.samsung.de/support/su...4=&filetype=FM
Formerly known as "the bitch" NOW I havenīt found ANY DISC that just wonīt play!!! Even discs that my Panasonic DMP-BD30 decidedly doesnīt play are loaded as fast as any other one.
DVD-R , DVD-RW, DVD+RW (DVD+R not tested) = OKAY!
Rodger is offline   Reply With Quote
Old 17th April 2009, 04:03   #23  |  Link
zodex
Samsung BD-P1600
avchd: yes
avchd-crop: yes
new-bd: no ("This Disc Cannot Be Displayed.")
zodex is offline   Reply With Quote
Old 17th April 2009, 08:49   #24  |  Link
turbojet
Rodger: do all test samples play ok? If you get a chance does a full-bd done with bd-rb work without removing the auxdata folder?
zodex: thanks for the test results, i added them to the list. Do you have a chance to try out old-bd, avchd-crop-720 and/or full-bd from bd-rb?
Old 21st April 2009, 17:16   #25  |  Link
Rodger
Finally tested all images: Here is the conclusion
Old 21st April 2009, 17:24   #26  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
So it looks like they finally implemented full AVCHD support.
Old 21st April 2009, 17:27   #27  |  Link
rack04
Care to explain what you mean by "may need to disable 24p"? I have a BD-35 and I enable "change FPS" and "Change Level" in every meta file regardless that the video is 24000/1001 and level 4.1.
rack04 is offline   Reply With Quote
Old 21st April 2009, 17:45   #28  |  Link
deank
deank's Avatar
It is a function of the player/tv, not tsmuxer/software.
Old 21st April 2009, 18:18   #29  |  Link
rack04
Oh I see. Thanks.
Old 21st April 2009, 20:00   #30  |  Link
Furiousflea
Originally Posted by Trahald View Post
What do you base that on? While it very well may be true (I have no clue either way) I'm just curious if there is evidence (ie working PIP produced by pro bluray authoring software written to the SAME media tested on the SAME stb) or is it a gut feeling (which I can then safely ignore)
No, it's how it stands as of now.
Who even said PIP doesn't work?
Nobody.
The reason PIP doesn't work at the moment (as far as any of us know) is because BDRB just discards the PIP track it anyway so it wouldn't play on any player. There has been no test to even check if it works. The only reason it's even there is because (and this is my gut feeling ) a few people such as myself who own the Sony BDP-SXXX have reported that discs containing PIP tracks could potentially be causing problems for BDRB as it seems to map the wrong streams so that selecting 1 audio language for example will have the effect of playing a different one.
I suspect this "issue" has been lost in translation and appeared as "has issues with PIP discs". Which is simply not true to anyone's knowledge.
There's no reason to suggest it wouldn't play...Don't even know how it got misinterpreted to this point, unless someone has checked?
Furiousflea is offline   Reply With Quote
Old 21st April 2009, 20:23   #31  |  Link
deank
deank's Avatar
PIP playback may be disabled in ALL players if they detect content as AVCHD or if BD player is an older model or conforms to BD profile 1 only.
Old 21st April 2009, 20:29   #32  |  Link
Furiousflea
I'm not sure about DVD5\9 but when you burn to BD-R the Sony S550 reads it as "BD-R BDMV"...(this is what pops up when the bluray loads)I realise this thread is dealing with DVD5\9 but if BD-Live\BDJ is all working on DVD5\DVD9 (and it is)...
So shouldn't be a problem, but hey...you know never know Point is, nobody does know and there is no reported problem to the effect of saying PIP does not work for those Sony players. (Hence my post) If there is a problem, well that's great too just I've not read anywhere anyone actually checking.
Old 22nd April 2009, 09:08   #33  |  Link
koutou
I'm using 1.8.35. Is it the old or new bd?
I currently don't own a standalone player but I would like to start creating blu-ray backups (just the movie) and burn them to disks. Which version should I use for best future compatibility? I guess the old one as seen from the chart?
Thank you for your help
koutou is offline   Reply With Quote
Old 23rd April 2009, 13:42   #34  |  Link
deank
deank's Avatar
@all: I created a small BDMV application to display some of the player's capabilities.
Check this post and comment here if you wish.
Old 24th April 2009, 09:52   #35  |  Link
turbojet
Rodger: thanks for the results I updated the first post.
1.8.35 - 1.9.5 AVCHD output appears to be identical to OLD-BD output. I added this to the legend.
The only playability difference I know of between OLD-BD and AVCHD is the AUXDATA folder. 3 Denon's and a Phillips need this folder while 4 Samsung must not have this folder.
I wouldn't suggest using bluray output after 1.8.34 for your case because it's yet to be tested thoroughly on red and blue laser media.
A 100% working version with all types of players doesn't exist. So I don't think a version can be recommended for your situation. It all really depends on what player you get supports. I have a feeling Denon and Philips requiring AUXDATA folder is more likely to change then Samsung's situation.
Old 25th April 2009, 19:10   #36  |  Link
Ghitulescu
Ghitulescu's Avatar
It may be a good idea to specifiy, if possible, the firmware version and the market (US, EU etc. since there are differences in hardware and firmware for the same player).
Old 28th April 2009, 10:11   #37  |  Link
deank
deank's Avatar
Another request I posted in multiAVCHD thread:
Please someone with Panasonic/Samsung test if your players will play:
[AVCHD for DVD-R] output with [x] Stricter AVCHD folder mode checked (i.e. without CERTIFICATE/AUXDATA and all other non-AVCHD folders) ... and burn the output to DVD-RW.
DVD should contain only:
BDMV\index.bdmv
BDMV\MovieObject.bdmv
BDMV\CLIPINF
BDMV\PLAYLIST
BDMV\STREAM
Dean
Originally Posted by jfcarbel View Post
I will give it a try and report back.
UPDATE:
It now works, my Panasonic BD30 can now play it even with the Stricter AVCHD folder mode checked
Great work, thanks.
When all files are AVCHD compliant BD players should not require CERTIFICATE/AUXDATA or any other then the above listed. I posted this here just to let you all know if you didn't check this thread.
Old 29th April 2009, 08:41   #38  |  Link
Ghitulescu
Ghitulescu's Avatar
B-pyramids may be a problem to Pioneers, although I'm not 100% sure (need more sources to check this). ->http://forum.doom9.org/showthread.ph...22#post1279322.
After reencoding the video to 100% BD compliance it worked perfectly.
Old 29th April 2009, 11:16   #39  |  Link
Ryu77
Ryu77's Avatar
I just bought a Sony BDP-S550 and I can not seem to be able to get DTS-HD MA or Dolby TrueHD to work from DVD media (AVCHD)...
Is this normal or have I got a faulty unit? These discs seem to play back fine on my PS3 (although of course HD audio is decoded internally). Is there any workaround that anybody knows of to enable HD audio from DVD media on this player?
Also, it might be a good idea to include which players support HD audio from DVD Media (AVCHD).
Edit: I tested Dolby TrueHD and DTS-HD MA on the Panasonic DMPBD35 and DMPBD60 today. They both played (via bitstream) DTS-HD MA from DVD media with no problem. However, Dolby TrueHD kept sticking and audio was screechy (if that's a word) and broken.
Ryu77 is offline   Reply With Quote
Old 1st May 2009, 11:52   #40  |  Link
Ryu77
Ryu77's Avatar
Should I assume that nobody here is really interested in HD audio on DVD media?
I know in most cases space constraints make this an unsuitable choice. However, I have found that movies under 1 hour 45 minutes in length can still include HD audio with enough bitrate to spare for good quality 1080p video.
As I sell Home Theater/TV's, I have access to quite a few players and I can help compile which players support HD audio from DVD media and which do not.
I really think it's a good idea to include this on the list. We just got the LG BD370's in, I am hoping they might support TrueHD as well as DTS-HD MA...
I will post back soon.
