Go Back   Doom9's Forum > Capturing and Editing Video > NLE - Non Linear Editing
Old 25th March 2020, 00:49   #1  |  Link
Stereodude
Resolve 16.2 mangles chroma
Is there a way to get Resolve to not mangle the chroma of a video with non square pixels? (I'm guessing the non square pixels are the problem)
I have a NTSC 16:9 enhanced DVD (720x480), I converted it to a .mov containing 8-bit 420 H.264 (crf 1) with VD2 so I can mess with the grade in Resolve. I put it into Resolve into a 720x480 NTSC DV 16:9 timeline, do some color grading and then output it as uncompressed 10bit 422 YUV in a .mov and I get this crap.
Here's the input (scaled to 2x by madVR)
Here's the output (scaled to 2x by madVR)
I've tried other output formats, like Cineform and got the same thing. I tried a custom 720x480 timeline, but that doesn't seem to stick. It keeps reverting back to 720x480 NTSC DV 16:9.
Are there some settings I'm missing (I'm very far from a Resolve guru) or is Resolve just broken?
Stereodude is offline   Reply With Quote
Old 25th March 2020, 03:48   #2  |  Link
Stereodude
So I did a little more testing. I'm not sure if it is Resolve's 420 -> 422 conversion that's the problem or perhaps an issue with H.264, but if I convert the DVD to ProRes 422 instead of near lossless H.264 and feed that into Resolve the chroma in the output is fine.
Old 25th March 2020, 04:36   #3  |  Link
poisondeathray
If that's the case why would cineform 422 be affected as well ?
Old 25th March 2020, 04:47   #4  |  Link
Stereodude
Because the CineForm 422 was an output format I tried with the same near lossless 420 H.264 input. When I changed the input format to ProRes 422 or uncompressed v210 the problem goes away in the output.
I can't narrow down the issue on the input side any more because Resolve won't take uncompressed 8-bit or 10-bit 420 video in a .mov container as a source file. So I'm not sure if it's a H.264 420 specific issue or a 420 specific issue. Resolve didn't want to take a 4:2:2 H.264 input file either.
They desperately need to support VFW AVI codecs.
Old 25th March 2020, 04:51   #5  |  Link
poisondeathray
I misunderstood, I though you meant you tested cineform as the input and output (yes, even though it said output... )
This will never happen
Old 25th March 2020, 05:37   #6  |  Link
Cary Knoop
Cary Knoop
Cary Knoop's Avatar
Did you verify it is not an interlacing thing instead of a chroma thing?
Cary Knoop is offline   Reply With Quote
Old 25th March 2020, 05:46   #7  |  Link
Stereodude
The source is progressive 30/1.001.
Old 25th March 2020, 06:41   #8  |  Link
poisondeathray
It looks like point sampled (nearest neighbor) chroma . It's just duplicating samples up to 4:4:4 then RGB, then back down to 4:2:2 when exporting a 4:2:2 format
So if you export some 4:2:2 format, you can downsample back to 4:2:0 using chromaresample="point" and it will look close to what you started with
#exported 4:2:2 format like prores
ConvertBits(8)
ConvertToYV12(chromaresample="point")
Or you can use avsresize eg. for 10bit , but 4:2:0
z_ConvertFormat(pixel_type="YUV420P10", resample_filter="point")
(I tested this on some patterns in Resolve Studio 15, similar conditions 720x480 x264 4:2:0 import, 720x480 timeline settings, 422 export)
Old 25th March 2020, 07:18   #9  |  Link
Stereodude
I'll take really poor algorithm choices for $1000 Alex.
BTW, thanks for figuring this out!
Old 25th March 2020, 17:52   #10  |  Link
poisondeathray
BTW that bottom graphic is labelled in correctly it should be avsresize point 10bit420, not 10bit422 - (ie. 422=>420 just discarding the samples that were duplicated)
Old 28th March 2020, 18:25   #11  |  Link
Stereodude
ConvertBits(8)
So I decided to measure the PNSR of this. The numbers aren't stellar. I can't speak to whether the results are visually apparent or not. I didn't attempt to examine that aspect.
This is lossless:
Convert YV12 source to v210 in Avisynth -> uncompressed v210 .mov (VD2) -> Resolve -> uncompressed v210 .mov -> Avisynth convert back to YV12
This is not even close:
Compress the YV12 source to near lossless (qp 1 / keyint 1) H264 -> Resolve -> v210 .mov -> Avisynth convert back to YV12
The near lossless H264 compression is good for -~70-75dB
The Resolve -> YV12 in Avisynth step degrades it quite a bit further dipping all the way down to ~46dB for a section on my 5000 frame test clip.
My guess is that it has something to do with the chroma placement and the transformation matrix not aligning between the 4:2:0 -> 4:2:2 conversion in Resolve and 4:2:2 -> 4:2:0 back in Avisynth.
Edit: It seems like this is potentially a significant issue for anyone who uses 4:2:0 video from their cameras directly in Resolve and then exports from Resolve in a lossless or with a "light touch" codec to encode in something else. You can visually improve the chroma with a point resample of it back to 4:2:0, but you can't actually reverse the operation.
Also for a point of reference while I was at it I measured Cineform's performance (forcing a re-encode in Resolve) using the same flow vs. v210 uncompressed and got this:
Convert YV12 source to v210 in Avisynth -> CineForm FS3 v210 .mov (VD2) -> Resolve -> CineForm Best v210 .mov -> Avisynth convert back to YV12
Old 28th March 2020, 21:27   #12  |  Link
poisondeathray
There is an intermediate RGB step in Resolve too. If there wasn't, and Resolve could work in YUV, you would expect Y to be the same since you're measuring Y psnr in those graphs, not Y, U, V or aggregate YUV PSNR. For programs that are YUV capable, there is no alteration of the Y plane . v210 gets special treatment - it actually gets special treatment in other NLE's too, even ones that work internally in RGB . It's a native format that gets passthrough . For some Windows based NLE's, you can use IYUV (8bit 4:2:0, with fourcc IYUV, or 8bit 4:2:2 with fourcc UYVY) and those gets passthrough , but Resolve is really devloped from a Mac environment , there is no way to get it to work with uncompressed 8bit 4:2:0
Was this internal avs function conversion, or z_convert_format?
Recall there is a chroma shifting issue in the internal avs resizers . It's not a true point resize. There are workarounds such as resize8, but z_convert_format works properly
But it would partially depend on how resolve is defining the chroma placement too.
Old 28th March 2020, 21:57   #13  |  Link
poisondeathray
On a synthetic test clip (the one above, but there is animation, rotation, but it's just simple text motion)
Same thing 720x480 YV12 source => Resolve => Export v210 => Convert back to YV12
ConvertBits(8).ConvertToYV12(chromaresample="point")
[Parsed_psnr_4 @ 000000702506d280] PSNR y:71.482031 u:48.201779 v:48.396939 average:53.027946 min:52.964134 max:53.075222
Z_ConvertFormat(pixel_type="YV12", resample_filter="point")
[Parsed_psnr_4 @ 000000a5d07f7800] PSNR y:68.920585 u:61.097875 v:73.214861 average:66.519582 min:64.670853 max:67.972861
The U, V scores are much lower for the internal avs as expected with the known shifting
I'll try some real clips when I get a chance , but with synthetic test patterns it might be possible to figure out how it's interpeting the chroma and reverse it more closely
Old 28th March 2020, 23:54   #14  |  Link
poisondeathray
UHD YV12 1152 frame , fairly high scene complexity with foliage, people, movement
Spline16Resize => 720x480p23.976 . Did not compensate for colormatrix or anything else. This is the new source "orig"
Encoded x264 --qp 1 --keyint 1 --tune psnr
Import qp1_intra version into Resolve, matched all import/export settings. Check marked retain sub black and super white on export (this clip has some since it was a native camera shot)
Calculated per frame metrics, but I didn't plot it out, I'm just posting the averages . FFmpeg psnr
self test check orig vs. orig
lossless
x264_qp1_intra vs. orig
PSNR y:68.087383 u:67.117369 v:67.088122 average:67.733770 min:67.343042 max:68.028963
ConvertBits(8).ConvertToYV12(chromaresample="point") vs. orig
PSNR y:67.782155 u:65.525216 v:66.421621 average:67.082155 min:65.246296 max:67.911099
ConvertToYUV420(chromaresample="point").ConvertBits(8) vs. orig
#In theory 10bit downsample before converting to 8 is better, but it doesn't matter when you're just dropping samples with "point", it should with other kernals
z_convertformat(pixel_type="YV12", resample_filter="point", resample_filter_uv="point") vs. orig
PSNR y:53.656829 u:66.398999 v:66.530673 average:55.305442 min:53.734979 max:57.186774
There is some loss , but PSNR Y,U,V > 65 is pretty good . Minus 1 or 2 db per channel vs. the qp1_keyint1 input into Resolve . You expect some loss because of the internal YUV=>RGB=>YUV conversion in resolve, in addition to, and separate from the subsampling/upsampling
Using long GOP, you expect that up/down pattern in those charts, especially with b-frames using default I/P/B ratios. Maybe try repeating with intra
Maybe a big problem with zimg Y plane 10bit => 8bit conversion. A 12-13db PSNR delta is massive. I have a feeling user error somewhere but I repeated results with vapoursynth version , same values. I'll recheck everything, but on that colored text clip it was lower than internal AVS too.
Old 29th March 2020, 00:43   #15  |  Link
Stereodude
I guess I can't speak to what resolve is doing internally. I presumed it converts to RGB all the time, but maybe not. I unchecked the box for "Bypass re-encode when possible". Obviously I couldn't make any changes to the video or I'd lose my ability to do a PNSR. I guess I could have use two inline grade nodes that cancel each other out. I didn't try that.
I also didn't realize I was only looking at the Y plane. Oops. I'm brand new to using the MSU VQMT tool.
I tried both internal avs function and z_convert. I need to retest using YUV PNSR.
How are you measuring PNSR with ffmpeg? The free version of MSU VQMT can't do 10-bit which makes this a big pain.
Old 29th March 2020, 01:02   #16  |  Link
Stereodude
Checking with YUV PNSR, z_lib (avsresize) is lossless 4:2:0 -> 4:2:2 -> 4:2:0 using point resize. The internal Avisynth functions are not lossless.
A quick test of a few other z_lib resize kernels show they are are not lossless.
Old 29th March 2020, 01:38   #17  |  Link
poisondeathray
https://ffmpeg.org/ffmpeg-filters.html#psnr
Nor can it do >720p . But the GUI and plots are a nice touch and it's user friendly
Old 29th March 2020, 02:00   #18  |  Link
Stereodude
I used a MPEG-2 DVD source with non-square pixels since that's what I've been working on in Resolve. Maybe that has something to do with the numbers.
I compressed to H264 using --qp 1 --keyint 1 --tune psnr using the x264 engine in the latest VD2. (it's the upper set of lines on the graphs)
I redid my tests using YUV
I converted the v210 422 Quicktime back to 8-bit 420 with
z_ConvertFormat(pixel_type="YV12", resample_filter="point", colorspace_op="170m:601:170m:f=>170m:601:170m:f")
This gave different results
ConvertToYUV420(matrix="PC.601", chromaresample="point").ConvertBits(8, dither=0)
Old 29th March 2020, 04:36   #19  |  Link
poisondeathray
Seems a bit low for some of those sections. Is something special about them visually?
I tried vqmt and got slightly different values (maybe slightly different psnr calcs) , but the trend was the same, average in the mid sixties. Nothing dropping that low, maybe 59.something was the lowest. Nothing to suggest a significant difference between ffmpeg psnr and msu vqmt's psnr
Mine was oversampled non square pixel , 720x480 . It was encoded with --sar 32:27 too but I doubt that would make a difference
Can you upload small clip test section that includes a peak and valley ?
Old 29th March 2020, 10:10   #20  |  Link
kolak
Resolve handling of 420/422 was far from correct.
It was enough to export v210 5x back to v210 (which was always going through RGB) and you had red channel shifted few pixels! Then they improved it a bit, but it's still not very good. They will also now pass v210 (and not only) without any processing if you do just cut editing.
chroma bug, resolve
