Old 19th January 2020, 11:47   #1  |  Link
dadix
Dedicated video player for DLP projectors
Hello.
I am a big fan of video projectors .
I would like to discuss a problem with DLP video projectors. I suspect that from the way the image is formed using micro-mirrors, a separate video player should be developed for these types of video projectors.
I have 2 video projectors with DLP and one with 3LCD. Optoma ep727 (dlp) has smoother image than Benq W1080ST (DLP). I suspect this is because of the poor video processing in the Benq model. The Benq W1080ST plays many block artifacts and the image looks smoother in Optoma EP727.
I studied this problem a bit and saw that the Optoma model has a separate image processor from Pixelworks namely PW392.
This processor hase some technologies like these :
-- DNX Deinterlacing with LAI technology uses video processing algorithms, including advanced motion-adaptive deinterlacing for both standard television formats and also high definition television formats, automatic film mode detection with 3:2 and 2:2 pull-down, advanced noise reduction and low angle edge detection to virtually eliminate 'jaggies' and other image artifacts.
-- DNX PixelBoost(TM) technology improves pixel response rates to eliminate blurring in fast-motion video as seen on some LCD panels.
-- DNX Rich Color Processing technology is the first low-cost technology for rendering more than one billion colors with 10-bit color processing and also remaps a display's color palette intelligently to optimize content appearance based on specific characteristics of the particular display technology.
-- DNX Advanced Scaling technology intelligently resizes HD and standard-resolution images to fit a wide variety of standard and widescreen displays.
-- DNX Video Enhancement technologies such as DCTI/DLTI, white/black level expansion and digital luminance peaking produce sharp, rich picture quality.
-- Enhanced Intelligent Windowing allows total user control for managing multiple content, including Split Screen, POP, and PIP with alpha blending.
-- Advanced 256-color bit-mapped on-screen display features provide for high-quality user interfaces.
They also have a picture and show this
So the question is which video player can do this image from right part and "
Primitive algorithms simply "paint" images by crudly placing pixels." - like they say in the promotion .
Here is the link to that LAI Technology : https://roa.optoma.com/Product/Produ...egory=SG9tZQ==
dadix is offline   Reply With Quote
Old 20th January 2020, 19:34   #2  |  Link
Asmodian
madVR?
madVR options explained
Old 22nd January 2020, 13:09   #3  |  Link
dadix
Originally Posted by Asmodian View Post
madVR?
Thank you for suggestion . It's working on GNU / Linux ?
Old 23rd January 2020, 00:56   #4  |  Link
Asmodian
No, Windows only
Old 25th January 2020, 09:57   #5  |  Link
dadix
No, Windows only
Thank you for answer .
benq, dlp, lai, player, projector
