Old 17th October 2019, 08:35   #21  |  Link
markfilipak
markfilipak's Avatar
Location: Mansfield, Ohio (formerly San Jose, California)
@poisondeathray
@ChaosKing
@stax76
Thanks All! You've given me so much to think about: good suggestions, reassurance that I'm not crazy, confirmation that some people really do know their stuff, a comparative survey of methods, and a little history.
You did not disappoint. But it's 3:30 AM here and I'm passing out. I'll read this stuff in detail in the morning.
Thank You!
markfilipak is offline   Reply With Quote
Old 18th October 2019, 23:32   #22  |  Link
markfilipak
Originally Posted by ChaosKing View Post
vsedit has a small bug. When you open the encode dialog the first time after app start it won't set the Header to Y4M (it shows no header). Just select another profile ...
I don't know how to do that (and the menu shows no such "profile" choice).
... and then select the previous again or just set it to y4m by yourself.
I don't know how to "set it to y4m". I pasted the script into my programmers editor and searched for "header" (no case) and found nothing. If a "header" entry needs to be added, I don't know how/where to do that.
== I assume from the contents of 'test.vpy' that it will produce a short color bar video.
Old 18th October 2019, 23:45   #23  |  Link
poisondeathray
in vsedit, when you use script => encode video (or push f8) , a new dialog box will open up , and a section Header: , with a drop down box. You can select Y4M, or No Header. Also, there will be a box for presets
Old 19th October 2019, 00:43   #24  |  Link
markfilipak
Got that. Did it.
I aborted when I received this log entry:
"Script exceeded memory limit. Consider raising cache size".
I don't know how to do that. I looked through the menu and 'Edit' 'Settings' but found no Joy.
Old 19th October 2019, 00:55   #25  |  Link
ChaosKing
You can ignore this message for now. (Thats what I do )
But if you want you can add something like
core.max_cache_size = 4000 # http://www.vapoursynth.com/doc/pytho...max_cache_size
to your script. After the "core = vs.get_core()" line...
ChaosKing is online now   Reply With Quote
Old 28th May 2021, 09:06   #26  |  Link
M00NWALKER
hi am new here , and i also have this error appearing from time to time , Script exceeded memory limit. Consider raising cache size, so where exactly would i write this --> core.max_cache_size = 4000, and how do i know what amount to to write in, i do see in another post in was written in Options- filters box.
M00NWALKER is offline   Reply With Quote
Old 28th May 2021, 10:39   #27  |  Link
DJATOM
DJATOM's Avatar
I'm setting near 80% of my RAM and that plays well on my end.
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
Old 28th May 2021, 14:06   #28  |  Link
M00NWALKER
it seems to happen to me when i'm encoding any 4k size video down to 1080p. whether its a small 8gb file @ 4k resolution or 30gb file @ 4k resolution it happens. i have a pretty fast PC as well. i dont know what i need to do to fix it from saying it.
Windows 10 PC specs
AMD Ryzen 5 5600X 6-Core Processor
RAM 32.0GB
Motherboard ASUSTeK PRIME B550M-A
Graphics 4095MB NVIDIA GeForce RTX 2060 SUPER (Gigabyte)
SSD 465GB Samsung SSD 970 EVO Plus 500GB
750w Power Supply
64-bit, found, installation, python, suitable
