Old 19th August 2018, 20:43   #1  |  Link
zlorf
Automatically detect number of available audio channels
I'm using mpc hc + lav splitter and ffdshow or lav audio decoder (I can easily switch them).
PC has two audio outputs:
1) stereo speakers for daily activities;
2) yamaha receiver + beam projector for home cinema (5.1) via hdmi cable
I can switch audio output using built-in Windows 7 audio dialog (changing default playback device)
The problem I'm facing is that player/LAV doesn't detect currently selected playback device and number of available channels. So that when I'm playing some 5.1 content on stereo speakers, the center channel is muted.
I can of couse go to LAV audio decoder -> Mixing -> Enable mixing + stereo, this way I can hear sound properly on stereo speakers, but then I need to uncheck "enable mixing" every time I switch to 5.1 setup and it's cumbersome.
So, is there a way to tell player/LAV/ffdshow "hey man, look at the system settings and find out how many audio channels are available, then use this knowledge to automix"?
zlorf is offline   Reply With Quote
Old 19th August 2018, 22:46   #2  |  Link
what audio renderer hare you using?
windows is can do on it's own. you usually have to to nothing.
Old 20th August 2018, 15:18   #3  |  Link
clsid
Control Panel > Sounds > Speakers > Configure > select Stereo
Old 20th August 2018, 19:59   #4  |  Link
zlorf
@huhn
As I've written, I'm currently using LAV audio decoder, but previously I've tried ffdshow aduio as well (and the same problem).
@clsid
Yeah I've done that (Moreover, I've configured yamaha receiver to be 5.1 (in the same way via control panel)). The problem is that player + LAV still tries to output 5.1 content on these stereo speakers, effectively dropping center channel out.
Old 20th August 2018, 21:06   #5  |  Link
clsid
It should not matter what the decoders are outputting. The Windows mixer is supposed to downmix it to stereo. The driver may be at fault.
Old 21st August 2018, 07:54   #6  |  Link
zlorf
Ah, that may be the cause! I've recently updated audio drivers (realtek). I will take a look.
Old 28th August 2018, 07:54   #7  |  Link
zlorf
@clsid Thanks, that was the right idea. After reinstalling audio drivers everything works as expected.
channels, player
