21st June 2020, 01:22 | #441 | Link |
Thanks it works. The only thing needed in this case was the filename, so just FN_NAME ONLY was sufficient - and I commented out the other parts for the subs/text like frame number , aspect ratio, etc...
if(SUBS) { FN_NAME_ONLY = RT_FilenameSplit(FN,get=4) # Name node only, no path, no extension k=k.subtitle(FN_NAME_ONLY) } Thanks again |
21st June 2020, 02:53 | #442 | Link |
About to post in Shuffle thread, New ShuffleT(clip c, Int "Seed"=0 , Bool "Inverse"=False ) # Shuffle Temporal, ie shuffle frame order. All valid colorspaces.
16th July 2020, 15:58 | #443 | Link |
hi StainlessS
I am trying to make function that convert avs trim to trimIn for tfm and still apply the normal trim in the same time, so I come with this Code:
function intrim(clip i, string "trimline", string "output", string "type") { Assert(defined(trimline), "'intrim' trimline is needed") i lastframe = framecount() - 1 TrimFile=defined(output) ? output : "TrimFile.TXT" intrimloop(trimline, TrimFile, type, lastframe, true) eval(trimline) } function intrimloop(clip i, string "trimline", string "output", string "type", int "lastframe", bool "firstcall") { firstcall = default(firstcall, false) ofindtrim = FindStr(trimline, "trim") sishtrim = ofindtrim != 0 trimstart = FindStr(trimline, "(") findtrimstart = trimstart + 1 trimend = FindStr(trimline, ")") findtrimend = trimend - 1 taketrim = MidStr(trimline, findtrimstart, findtrimend) trims = FindStr(taketrim, ",") strim = MidStr(taketrim,1,trims-1).Value.Int etrim = MidStr(taketrim,trims+1).Value.Int etrim = etrim == 0 ? lastframe : etrim ntrimr = rightStr(trimline,StrLen(trimline)-trimend) ofindntrim = FindStr(ntrimr, "trim") sishntrim = ofindtrim != 0 ntrimstart = FindStr(ntrimr, "(") findntrimstart = ntrimstart + 1 ntrims = FindStr(ntrimr, ",") sntrim = MidStr(ntrimr,1,ntrims-1).Value.Int istrim = strim !=0 && firstcall ? 0 : etrim + 1 ietrim = firstcall && istrim == 0 ? strim-1 : sishntrim ? sntrim - 1 : lastframe writeline = !sishntrim ? etrim < lastframe : strim !=0 && sishtrim writeline ? RT_WriteFile(output, \ "%d,%d\n", istrim, ietrim) : nop() sishntrim ? intrimloop(i, firstcall && istrim == 0 ? trimline : rightStr(trimline,StrLen(trimline)-trimend), output, type, lastframe) : i } Code:
ColorBars() intrim("Trim(2, 198)++Trim(243, 2410)++Trim(20768, 39916)++Trim(42635, 43513)") Code:
0,1
See My Avisynth Stuff Last edited by real.finder; 16th July 2020 at 17:08. Reason: better trim line |
16th July 2020, 17:34 | #444 | Link |
RF, can you post exactly what you expect out of it (I aint ever used that intrim with tfm and am falling asleep as I write this).
EDIT: Like this ? [ranges on separate lines] Code:
0,1 199,242 2411,20767 39917,42634 43514,107891
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 16th July 2020 at 17:40. |
16th July 2020, 17:38 | #445 | Link | |
See My Avisynth Stuff Last edited by real.finder; 16th July 2020 at 17:41. |
16th July 2020, 18:17 | #446 | Link |
Would something like this be preferable ? [ FrameSel:- https://forum.doom9.org/showthread.php?t=167971 ]
ColorBars().ShowFrameNumber ofn=".\Outfile.txt" SCMD=""" 2,198 243,2410 20768,39916 42635,43513 """ FrameSel_CmdReWrite(Last,ofn,scmd=SCmd,Reject=True,Range=True,Space=False,Prune=False) Last.FrameSel(scmd=SCMD) Code:
0,1 199,242 2411,20767 39917,42634 43514,107891 EDIT: Or like this using Prune Code:
ColorBars().ShowFrameNumber outfn = ".\Outfile.txt" Prunefn= ".\Prunefile.txt" SCMD=""" 2,198 243,2410 20768,39916 42635,43513 """ FrameSel_CmdReWrite(Last,outfn, scmd=SCmd,Reject=True,Range=True,Space=False,Prune=False) FrameSel_CmdReWrite(Last,Prunefn,scmd=SCmd,Reject=false,Range=True,Space=False,Prune=true) # Fixed in Blue Last.Prune(cmd=Prunefn) Code:
0,1 199,242 2411,20767 39917,42634 43514,107891 Code:
0,2,198 0,243,2410 0,20768,39916 0,42635,43513
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 16th July 2020 at 19:10. |
16th July 2020, 18:22 | #447 | Link | |
See My Avisynth Stuff |
16th July 2020, 18:37 | #448 | Link |
The SelectRanges() version [but does pretty much same as the Prune version in prev post script]
ColorBars().ShowFrameNumber outfn = ".\Outfile.txt" SCMD=""" 2,198 243,2410 20768,39916 42635,43513 """ FrameSel_CmdReWrite(Last,outfn, scmd=SCmd,Reject=True,Range=True,Space=False,Prune=False) # Trim excluded SelectRanges(scmd=SCMD) # Trim Included (SelectRanges Script in FrameSel AVS dir (also requires Prune if audio)) EDIT: Maybe best like this Code:
ColorBars().ShowFrameNumber outfn = ".\Outfile.txt" PruneTMP=RT_GetSystemEnv("TEMP") + "\~PruneTMP_" + RT_LocalTimeString(file=True) + ".TMP" # Unique name in User TEMP directory SCMD=""" 2,198 243,2410 20768,39916 42635,43513 """ FrameSel_CmdReWrite(Last,outfn, scmd=SCmd,Reject=True,Range=True,Space=False,Prune=False) # Trim Excluded ranges FrameSel_CmdReWrite(Last,PruneTMP,scmd=SCmd,Reject=False,Range=True,Space=False,Prune=true) # Trim Included ranges in Prune Format # Fixed in Blue Prune(cmd=PruneTMP) # Trim RT_FileDelete(PruneTMP) # Del temp prune command file Return Last Code:
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 16th July 2020 at 19:02. |
16th July 2020, 19:37 | #449 | Link | |
function intrim(clip i, string "trimline", string "output", string "type") { Assert(defined(trimline), "'intrim' trimline is needed") i lastframe = framecount() - 1 TrimFile=defined(output) ? output : "TrimFile.TXT" intrimloop(LCase(trimline), TrimFile, type, lastframe, true) eval(trimline) } function intrimloop(clip i, string "trimline", string "output", string "type", int "lastframe", bool "firstcall") { firstcall = default(firstcall, false) ofindtrim = FindStr(trimline, "trim") sishtrim = ofindtrim != 0 trimstart = FindStr(trimline, "(") findtrimstart = trimstart + 1 trimend = FindStr(trimline, ")") findtrimend = trimend - 1 taketrim = MidStr(trimline, findtrimstart, findtrimend) trims = FindStr(taketrim, ",") strim = MidStr(taketrim,1,trims-1).Value.Int etrim = MidStr(taketrim,trims+1).Value.Int etrim = etrim == 0 ? lastframe : etrim ntrimr = rightStr(trimline,StrLen(trimline)-trimend) ofindntrim = FindStr(ntrimr, "trim") sishntrim = ofindntrim != 0 ntrimstart = sishntrim ? FindStr(ntrimr, "(") : nop() findntrimstart = !sishntrim ? nop() : ntrimstart + 1 ntrims = !sishntrim ? nop() : FindStr(ntrimr, ",") sntrim = !sishntrim ? nop() : MidStr(ntrimr,findntrimstart,ntrims-1).Value.Int istrim = strim !=0 && firstcall ? 0 : etrim + 1 ietrim = firstcall && istrim == 0 ? strim-1 : sishntrim ? sntrim - 1 : lastframe writeline = sishtrim ? sishntrim ? strim != 0 : etrim < lastframe : false writeline ? RT_WriteFile(output, \ "%d,%d\n", istrim, ietrim, append=true) : nop() sishntrim ? intrimloop(i, firstcall && istrim == 0 ? trimline : rightStr(trimline,StrLen(trimline)-trimend), output, type, lastframe) : i }
16th July 2020, 23:40 | #450 | Link | |
ColorBars().ShowFrameNumber SCMD=""" 2,198 199,242 243, 2410 2411, 20767 20768, 39916 39917, 42634 42635, 43513 """ outFn = ".\Abridgement.txt" FrameSel_CmdReWrite(Last,Outfn, scmd=SCmd, Reject=False,Ordered=True,Range=True,Space=False,Prune=False) Return Last Code:
2,43513 Code:
ColorBars().ShowFrameNumber INCMD=""" 2,198 243, 2410 20768, 39916 42635, 43513 """ OUTCMD=""" 199,242 2411, 20767 39917, 42634 """ SCMD = INCMD + OUTCMD outFn = ".\Abridgement.txt" FrameSel_CmdReWrite(Last,Outfn, scmd=SCmd, Reject=False,Ordered=True,Range=True,Space=False,Prune=False) Return Last EDIT: What is the end result of all of this, give complete description of ALL required [and take your time ]. EDIT: Also, what about audio ?
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 17th July 2020 at 00:48. |
17th July 2020, 00:40 | #451 | Link | |
function abtrim(string "trimline") { Assert(defined(trimline), "'intrim' trimline is needed") abtrimloop(LCase(trimline)) } function abtrimloop(string "trimline", int "remainder") { remainder = default(remainder, -1) otrimline = trimline trimline = remainder > 0 ? RightStr(trimline, remainder) : trimline ofindtrim = FindStr(trimline, "trim") sishtrim = ofindtrim != 0 trimstart = FindStr(trimline, "(") findtrimstart = trimstart + 1 trimend = FindStr(trimline, ")") findtrimend = trimend - 1 taketrim = MidStr(trimline, findtrimstart, findtrimend) trims = FindStr(taketrim, ",") strim = !sishtrim ? nop() : MidStr(taketrim,1,trims-1).Value.Int etrim = !sishtrim ? nop() : MidStr(taketrim,trims+1).Value.Int ntrimr = RightStr(trimline,StrLen(trimline)-trimend) ofindntrim = FindStr(ntrimr, "trim") sishntrim = ofindntrim != 0 ntrimstart = sishntrim ? FindStr(ntrimr, "(") : nop() findntrimstart = !sishntrim ? nop() : ntrimstart + 1 ntrims = !sishntrim ? nop() : FindStr(ntrimr, ",") sntrim = !sishntrim ? nop() : MidStr(ntrimr,findntrimstart,ntrims-1).Value.Int ntrimline=LeftStr(otrimline,trims+findtrimstart+(remainder > 0 ? remainder : 0))+(((etrim+1)==sntrim) ? MidStr(ntrimr,ntrims+1) : MidStr(trimline,trims+findtrimstart+1)) pointer = !sishtrim ? 0 : remainder != 0 ? remainder == -1 ? ntrimline != otrimline ? FindStr(ntrimline, "+") != 0 ? trims+findtrimstart-1 : 0 : FindStr(ntrimline, "+") : remainder + FindStr(RightStr(ntrimline, StrLen(ntrimline) - remainder), "+") : nop() pointer != 0 ? abtrimloop(ntrimline, pointer) : ntrimline } but still not for this (need fix, still working on it) abtrim("trim(2, 198)++trim(243, 2410)++Trim(2411, 20767)++Trim(20768, 39916)++Trim(39917, 42634)++Trim(42635, 43513)") and it need nothing but avs
See My Avisynth Stuff Last edited by real.finder; 17th July 2020 at 10:51. |
17th July 2020, 01:02 | #452 | Link | |
I'll look again at all of this tomorrow.
Would be a lot easier (I think) if had frames list source (String or file), and processed that, instead of screwing around trying to parse list with "Trim(xxx, yyy) ++ ..." etc, much easier to create trim command from frames string/file than to parse trims command and extract frames list from that. Also, making it all work in Avs script alone [and properley] is not gonna be easy, nor small. EDIT: Although with recent AVS+ arrays at least can implement frame range sorting and coalescing with less difficulty. (I'm not using array supporting versions of Avs+, it dont work with XP MeGUI, so I'm pretty much sticking with avs+ 3.5, r3106) EDIT: Quote:
For your abridgement thing, you need to parse and verify correctness of your frame ranges, eg end frame same or after start frame, for coalescing, you also need sorting all ranges beforehand. If you dont do it properley, it will bite your ass the first time somebody screws up the trims/ranges list. Without proper parsing/sorting/checking, will run risk of eg Infinite Recursion, stack exhaustion, where script/avisynth will just disappear without any error message or indication of what went wrong, not a good way to crash, or, it might just badly mangle your result clip. The things you are attempting are quite tricky even in C, in basic script is gonna be less easy. EDIT: Also, before you use RT_WriteFile with Append=true, is best to use RT_FileDelete on the target file [in the intrim() func]. Otherwise on multiple use eg Code:
0,1 199,242 2411,20767 39917,42634 43514,107891 0,1 199,242 2411,20767 39917,42634 43514,107891 ... etc
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 17th July 2020 at 09:40. |
17th July 2020, 10:46 | #453 | Link | ||
edit: I think this did it! Code:
function abtrim(string "trimline") { Assert(defined(trimline), "'intrim' trimline is needed") abtrimloop(LCase(trimline)) } function abtrimloop(string "trimline", int "remainder") { remainder = default(remainder, -1) otrimline = trimline sisending = !(remainder < StrLen(trimline)) trimline = remainder > 0 ? !sisending ? RightStr(trimline, StrLen(trimline) - remainder) : trimline : trimline ofindtrim = sisending ? nop() : FindStr(trimline, "trim") sishtrim = sisending ? false : ofindtrim != 0 trimstart = !sishtrim ? nop() : ofindtrim + FindStr(MidStr(trimline, ofindtrim + 1), "(") findtrimstart = !sishtrim ? nop() : trimstart + 1 trimend = !sishtrim ? nop() : ofindtrim + FindStr(MidStr(trimline, ofindtrim + 1), ")") findtrimend = !sishtrim ? nop() : trimend - 1 taketrim = !sishtrim ? nop() : MidStr(trimline, findtrimstart, findtrimend - findtrimstart + 1) trims = !sishtrim ? nop() : FindStr(taketrim, ",") strim = !sishtrim ? nop() : MidStr(taketrim,1,trims-1).Value.Int etrim = !sishtrim ? nop() : MidStr(taketrim,trims+1).Value.Int ntrimr = !sishtrim ? nop() : RightStr(trimline,StrLen(trimline)-trimend) ofindntrim = !sishtrim ? nop() : FindStr(ntrimr, "trim") sishntrim = !sishtrim ? nop() : ofindntrim != 0 ntrimstart = !sishtrim ? nop() : sishntrim ? FindStr(ntrimr, "(") : nop() findntrimstart = !sishtrim ? nop() : !sishntrim ? nop() : ntrimstart + 1 ntrims = !sishtrim ? nop() : !sishntrim ? nop() : FindStr(ntrimr, ",") sntrim = !sishtrim ? nop() : !sishntrim ? nop() : MidStr(ntrimr,findntrimstart,ntrims-1).Value.Int domerge = !sishtrim ? nop() : sishntrim ? ((etrim+1)==sntrim) : false ntrimline=!sishtrim ? nop() : !domerge ? otrimline : LeftStr(otrimline,(remainder > 0 ? remainder : 0) + findtrimstart + trims - 1) + MidStr(ntrimr,ntrims+1) remainder = !sishtrim ? nop() : domerge ? remainder : max(0,remainder) + trimend !sishtrim ? otrimline : sishntrim ? abtrimloop(ntrimline, remainder) : ntrimline } Code:
function abtrim(string "trimline") { Assert(defined(trimline), "'intrim' trimline is needed") function abtrimloop(string "trimline", int "remainder") { remainder = default(remainder, -1) otrimline = trimline sisending = !(remainder < StrLen(trimline)) trimline = remainder > 0 ? !sisending ? RightStr(trimline, StrLen(trimline) - remainder) : trimline : trimline ofindtrim = sisending ? nop() : FindStr(trimline, "trim") sishtrim = sisending ? false : ofindtrim != 0 trimstart = !sishtrim ? nop() : ofindtrim + FindStr(MidStr(trimline, ofindtrim + 1), "(") findtrimstart = !sishtrim ? nop() : trimstart + 1 trimend = !sishtrim ? nop() : ofindtrim + FindStr(MidStr(trimline, ofindtrim + 1), ")") findtrimend = !sishtrim ? nop() : trimend - 1 taketrim = !sishtrim ? nop() : MidStr(trimline, findtrimstart, findtrimend - findtrimstart + 1) trims = !sishtrim ? nop() : FindStr(taketrim, ",") strim = !sishtrim ? nop() : MidStr(taketrim,1,trims-1).Value.Int etrim = !sishtrim ? nop() : MidStr(taketrim,trims+1).Value.Int ntrimr = !sishtrim ? nop() : RightStr(trimline,StrLen(trimline)-trimend) ofindntrim = !sishtrim ? nop() : FindStr(ntrimr, "trim") sishntrim = !sishtrim ? nop() : ofindntrim != 0 ntrimstart = !sishtrim ? nop() : sishntrim ? FindStr(ntrimr, "(") : nop() findntrimstart = !sishtrim ? nop() : !sishntrim ? nop() : ntrimstart + 1 ntrims = !sishtrim ? nop() : !sishntrim ? nop() : FindStr(ntrimr, ",") sntrim = !sishtrim ? nop() : !sishntrim ? nop() : MidStr(ntrimr,findntrimstart,ntrims-1).Value.Int domerge = !sishtrim ? nop() : sishntrim ? ((etrim+1)==sntrim) : false ntrimline=!sishtrim ? nop() : !domerge ? otrimline : LeftStr(otrimline,(remainder > 0 ? remainder : 0) + findtrimstart + trims - 1) + MidStr(ntrimr,ntrims+1) remainder = !sishtrim ? nop() : domerge ? remainder : max(0,remainder) + trimend !sishtrim ? otrimline : sishntrim ? abtrimloop(ntrimline, remainder) : ntrimline } abtrimloop(LCase(trimline)) } function intrim(clip i, string "trimline", string "output") { Assert(defined(trimline), "'intrim' trimline is needed") i lastframe = framecount() - 1 TrimFile=defined(output) ? output : "TrimFile.TXT" Exist(TrimFile) ? RT_FileDelete(TrimFile) : nop() function intrimloop(clip i, string "trimline", string "output", int "lastframe", bool "firstcall") { firstcall = default(firstcall, false) ofindtrim = FindStr(trimline, "trim") sishtrim = ofindtrim != 0 trimstart = !sishtrim ? nop() : FindStr(trimline, "(") findtrimstart = !sishtrim ? nop() : trimstart + 1 trimend = !sishtrim ? nop() : FindStr(trimline, ")") findtrimend = !sishtrim ? nop() : trimend - 1 taketrim = !sishtrim ? nop() : MidStr(trimline, findtrimstart, findtrimend-findtrimstart+1) trims = !sishtrim ? nop() : FindStr(taketrim, ",") strim = !sishtrim ? nop() : MidStr(taketrim,1,trims-1).Value.Int etrim = !sishtrim ? nop() : MidStr(taketrim,trims+1).Value.Int etrim = !sishtrim ? nop() : etrim == 0 ? lastframe : etrim ntrimr = !sishtrim ? nop() : rightStr(trimline,StrLen(trimline)-trimend) ofindntrim = !sishtrim ? nop() : FindStr(ntrimr, "trim") sishntrim = !sishtrim ? nop() : ofindntrim != 0 ntrimstart = !sishtrim ? nop() : sishntrim ? FindStr(ntrimr, "(") : nop() findntrimstart = !sishtrim ? nop() : !sishntrim ? nop() : ntrimstart + 1 ntrims = !sishtrim ? nop() : !sishntrim ? nop() : FindStr(ntrimr, ",") sntrim = !sishtrim ? nop() : !sishntrim ? nop() : MidStr(ntrimr,findntrimstart,ntrims-1).Value.Int istrim = !sishtrim ? nop() : !sishtrim ? nop() : strim !=0 && firstcall ? 0 : etrim + 1 ietrim = !sishtrim ? nop() : !sishtrim ? nop() : firstcall && istrim == 0 ? strim-1 : sishntrim ? sntrim - 1 : lastframe writeline = sishtrim ? sishntrim ? strim != 0 : etrim < lastframe : false writeline ? RT_WriteFile(output, \ "%d,%d\n", istrim, ietrim, append=true) : nop() sishtrim ? intrimloop(i, firstcall && istrim == 0 ? trimline : rightStr(trimline,StrLen(trimline)-trimend), output, lastframe) : i } intrimloop(abtrim(trimline), TrimFile, lastframe, true) eval(trimline) } edit: I added them in https://github.com/realfinder/AVS-St...AnimeIVTC.avsi if there any update in future it will be there
See My Avisynth Stuff Last edited by real.finder; 17th July 2020 at 21:53. |
15th December 2020, 00:09 | #454 | Link | |
15th December 2020, 18:24 | #455 | Link |
I really should not be spending any time on D9, too busy.
But, when I do get time, I'll dissect UniversalPluginsFolders and steal all of the good bits.
29th December 2020, 19:00 | #456 | Link |
RT_Stats 2.0 Beta 13, Update:- https://www.mediafire.com/file/xa3t1...01229.zip/file
Also on SendSpace below this post.
30th March 2021, 08:40 | #457 | Link |
lets say that there are comments (with #) like this:-
#~ Trim(0, 9006)++Trim(9007, 23602)++Trim(23603, 40776)++Trim(40777, 43472)++Trim(43473, 44402) Trim(44403, 48808)++Trim(48809, 64002)++Trim(64003, 85162)++Trim(85163, 87858)++Trim(87859, 88788) #~ ++Trim(88789, 94064)++Trim(94065, 108480)++Trim(108481, 129550)++Trim(129551, 132246)++Trim(132247, 133356) Code:
See My Avisynth Stuff Last edited by real.finder; 30th March 2021 at 08:53. |
30th March 2021, 16:11 | #458 | Link |
Does this sort you out OK R.F., ?
(I've left in non required Chr testing funcs) Code:
Function ChrIsNul(String S) {return RT_Ord(S)== 0} # End of String Function ChrIsTAB(String S) {return RT_Ord(S)== 9} # TAB Function ChrIsLF(String S) {return RT_Ord(S)==10} # Line Feed (New Line) Function ChrIsCR(String S) {return RT_Ord(S)==13} # Carriage Return Function ChrIsSPACE(String S) {return RT_Ord(S)==32} # SPACE Function ChrIsBang(String S) {return RT_Ord(S)==33} # ! Function ChrIsDQuote(String S) {return RT_Ord(S)==34} # " Function ChrIsHash(String S) {return RT_Ord(S)==35} # # Function ChrIsDollar(String S) {return RT_Ord(S)==36} # $ Function ChrIsPercent(String S) {return RT_Ord(S)==37} # % Function ChrIsAmp(String S) {return RT_Ord(S)==38} # & Function ChrIsSQuote(String S) {return RT_Ord(S)==39} # ' Function ChrIsOParen(String S) {return RT_Ord(S)==40} # ( Function ChrIsCParen(String S) {return RT_Ord(S)==41} # ) Function ChrIsStar(String S) {return RT_Ord(S)==42} # * Function ChrIsPlus(String S) {return RT_Ord(S)==43} # + Function ChrIsComma(String S) {return RT_Ord(S)==44} # , Function ChrIsHyphen(String S) {return RT_Ord(S)==45} # - Function ChrIsDot(String S) {return RT_Ord(S)==46} # . Function ChrIsSlash(String S) {return RT_Ord(S)==47} # / Function ChrIsColon(String S) {return RT_Ord(S)==58} # : Function ChrIsSColon(String S) {return RT_Ord(S)==59} # ; Function ChrIsLT(String S) {return RT_Ord(S)==60} # < Function ChrIsEqual(String S) {return RT_Ord(S)==61} # = Function ChrIsGT(String S) {return RT_Ord(S)==62} # > Function ChrIsQuery(String S) {return RT_Ord(S)==63} # ? Function ChrIsAt(String S) {return RT_Ord(S)==64} # @ Function ChrIsOSquare(String S) {return RT_Ord(S)==91} # [ Function ChrIsBSlash(String S) {return RT_Ord(S)==92} # / Function ChrIsCSquare(String S) {return RT_Ord(S)==93} # ] Function ChrIsHat(String S) {return RT_Ord(S)==94} # ^ Function ChrIsUScore(String S) {return RT_Ord(S)==95} # _ Function ChrIsOCurly(String S) {return RT_Ord(S)==123} # { Function ChrIsPipe(String S) {return RT_Ord(S)==124} # | Function ChrIsCCurly(String S) {return RT_Ord(S)==125} # } Function ChrIsTilde(String S) {return RT_Ord(S)==126} # ~ # Function ChrIsWhite(String S) {C=RT_Ord(S) return C==32||C>=8&&C<=13} # SPC, BackSPC, TAB, LF, VT, FF, CR Function ChrIsDigit(String S) {C=RT_Ord(S) return C>=48&&C<=57} Function ChrIsUCase(String S) {C=RT_Ord(S) return C>=65&&C<=90} Function ChrIsLCase(String S) {C=RT_Ord(S) return C>=97&&C<=122} Function ChrIsAlpha(String S) {C=RT_Ord(S) return C>=65&&C<=90||C>=97&&C<=122} Function ChrIsHex(String S) {C=RT_Ord(S) return C>=48&&C<=57||C>=65&&C<=70||C>=97&&C<=102} # Req GScript or AVS+ Function ChrEatWhite(String S) {i=1 C=RT_Ord(S,i) While(C==32||C>=8&&C<=13) {i=i+1 C=RT_Ord(S,i)} return i>1?MidStr(S,i):S} Function ChrEatAlpha(String S) {i=1 C=RT_Ord(S,i) While(C>=65&&C<=90||C>=97&&C<=122) {i=i+1 C=RT_Ord(S,i)} return i>1?MidStr(S,i):S} Function ChrEatDigits(String S) {i=1 C=RT_Ord(S,i) While(C>=48&&C<=57) {i=i+1 C=RT_Ord(S,i)} return i>1?MidStr(S,i):S} Function ChrEatHex(String S) {i=1 C=RT_Ord(S,i) While(C>=48&&C<=57||C>=65&&C<=70||C>=97&&C<=102) {i=i+1 C=RT_Ord(S,i)} return i>1?MidStr(S,i):S} #################################### Above, we only use ChrEatWhite SSS=""" #~ Trim(0, 9006)++Trim(9007, 23602)++Trim(23603, 40776)++Trim(40777, 43472)++Trim(43473, 44402) Trim(44403, 48808)++Trim(48809, 64002)++Trim(64003, 85162)++Trim(85163, 87858)++Trim(87859, 88788) #~ ++Trim(88789, 94064)++Trim(94065, 108480)++Trim(108481, 129550)++Trim(129551, 132246)++Trim(132247, 133356) """ NewS = "" LineCount = SSS.RT_TxtQueryLines for(i=0,LineCount-1) { # Will Ignore Blank lines and lines where first non-white char is hash '#'. TmpS = SSS.RT_TxtGetLine(i).ChrEatWhite # Get line of text from multi-line string and remove leading whitespace. if(TmpS.RT_Ord != 35 && TmpS.RT_Ord != 0) { # NOT '#' or End Of Line NewS = (NewS=="") ? TmpS : NewS + Chr(10) + TmpS } } BlankClip(Width=1024,height=640,length=1).RT_Subtitle("Stripped =\n%s",NewS)
30th March 2021, 16:41 | #459 | Link |
yes, thanks StainlessS
4th April 2021, 20:57 | #460 | Link |
StainlessS is RT_QwikScan() aimed to align matching shots or only frames (ala MatchFrames). I spend a lot of time syncing videos (to match audio actually) and I grew tired of it, some shots are longer, shorter, slided, added or omitted, as such an example manually crafted script would look like this:
v=ffvideosource("E:\video01.mkv") a=LWLibavaudioSource("E:\video01.mkv") v2=ffvideosource("E:\video02.mkv") a2=LWLibavaudioSource("E:\video02.mkv").ConvertAudioToFloat() a.ConvertAudioToFloat() audiodub(v,last) assumefps(24000,1001) av2=audiodub(v2,a2) TimeStretch(rate=((24000.0/1001.0)*100.0)/25.0) trim(746,0) trim(0,28046)+trim(av2,28046+1,28502)+trim(28202+1,0) trim(0,30886)+trim(av2,30886+1,30886+14*24+4)+trim(30886+1,0) trim(0,37583)+trim(av2,37583+1,37583+13*24+3)+trim(37583+1,0) trim(0,39334)+trim(av2,39334+1,39334+18*24-7)+trim(39334+1,0) trim(0,43695)+trim(av2,43695+1,43695+5*24)+trim(43695+1,0) (...) trim(0,137057)+trim(av2,137057+1,137666-4)+trim(137057+1,0) trim(0,137907)+trim(av2,137907+1,138531-1)+trim(137907+1,0) trim(0,139372)+trim(av2,139372+1,139665)+trim(139372+1,0) trim(0,141478)+trim(av2,141478+1,142295)+trim(141478+1,0) trim(0,145026)+trim(av2,145026+1,145411+8)+trim(145026+1,0) trim(0,149794)+trim(av2,149794+1,150601+48+19)+trim(149794+1,0) trim(0,151913)+trim(av2,151913+1,151913+24*13+38)+trim(151913+1,0) trim(0,155769)+trim(av2,155769+1,155769+24*32-14)+trim(155769+1,0) trim(0,157588)+trim(av2,157588+1,158418)+trim(157683,0) trim(0,158766)+trim(av2,158766+1,158986)+trim(158766+1,0) trim(0,160356)+trim(av2,160356+1,160356+24*14-6)+trim(160356+1,0) trim(0,161050)+trim(av2,161050+1,161976)+trim(161050+1,0) trim(0,162076)+trim(av2,162076+1,162205+24+25)+trim(162076+1,0) delayaudio(32*0.0417) killvideo() |
averageluma, correlation, lumadifference, runtime |
