Old 22nd February 2011, 18:05   #1  |  Link
EpheMeroN
EphMan
MPC HomeCinema as default player
I have MPC HomeCinema setup as my default player. Everything works fine. However, if I have a dvd in any drive, and I double-click on the icon from "My Computer", Windows Media Player still attempts to play the disc.
If I have MPC HomeCinema setup as my default player shouldn't this be covered as well?
EpheMeroN is offline   Reply With Quote
Old 22nd February 2011, 18:41   #2  |  Link
iTijn
iTijn's Avatar
It can be done:
- open options. (press O)
Player>Formats window:
Here you can check what MPC is used for.
Also Autoplay DVD can be checked.
iTijn is offline   Reply With Quote
Old 23rd February 2011, 01:26   #3  |  Link
EpheMeroN
EphMan
Originally Posted by iTijn View Post
It can be done:
I already have it setup to play ALL video formats and I have ffdshow setup in case any formats are not supported by MPC's built-in codecs.
I am referring to when you actually double-click the DVD drive icon within My Computer. No matter what I do it always tries to open the disc with Windows Media Player, but only this way. All other ways MPC HomeCinema works as the default player.
Old 23rd February 2011, 15:15   #4  |  Link
mr.duck
quack quack
It's probably some Windows auto run setting rather than assigning a program to a file type. I always disable auto run completely.
On Windows 7 you might need to look in control panel >> AutoPlay
mr.duck is offline   Reply With Quote
default, dvd, player
