Old 15th August 2016, 11:12   #941  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Originally Posted by WSC4 View Post
Updater.exe runs during a re-boot when it likes. No way to switch it off or on. What files does it change, remove, update? I see no change in MPlayer.exe, SMPlayer.exe, MPUI.exe
If you decided to install/activate the "auto-update" feature during MPlayer for Windows installation, it will periodically check for new updates (every 14 days).
Technically, the auto-updater will run on each system start. But the first things it does is checking whether the update checking period has elapsed yet or not. If not, it will exit immediately. Otherwise it will actually check for new updates.
If and only if a new update was found, the auto-updater will suggest to download and install the new version. Installing the new version still requires confirmation by the user though! None of your files are changed "silently".
(BTW: In case you which to revert your decision and "disable" the auto-updater, just use "msconfig" or Autoruns).
Old 6th December 2016, 07:53   #942  |  Link
WSC4
Any reason why MPUI.exe has hijacked the Windows Media Player icon? As well as your SMPlayer, I have it shortcut on the desktop. There is only 1 icon to choose from in MPUI if you want to change it, and it's a rip of the WMP icon. Expected their own short list of original icons.
WSC4 is offline   Reply With Quote
Old 11th December 2016, 21:48   #943  |  Link
LoRd_MuldeR
Software Developer
MPlayer for Windows 2016-12-11
https://github.com/lordmulder/mplaye...eleases/latest
[2016-05-04]
* MPlayer binaries updated to SVN-r37905
* SMPlayer updated to version v16.11.0 (SVN-r8243)
* Now shipping Qt5 Runtime Libs (v5.6.0)
[MPlayer/MEncoder r37905]
* Upgraded MinGW-w64 to 5.0.0 and gcc 6.x
* Removed support for libfaac in FFmpeg (dropped upstream)
* Updated libfdk-aac (git) - please download updated dlls
* Updated frei0r (git) - please download updated plugins
* Updated libass (git)
* Updated libbluray (git)
* Updated libmodplug (git)
* Updated libvpx (git)
* Updated x264 (git)
* Updated x265 (hg)
* Updated freetype to 2.7
* Updated libjpeg-turbo to 1.5.1
* Updated libpng to 1.6.26
Old 6th January 2017, 00:52   #944  |  Link
WSC4
In the past, I found -vo gl to be sharper, clearer and render the colours better than -vo directx.
I don't know when -vo direct3d was introduced, but it seems to be better than -vo gl. Do you agree? Of the 17 choices, which video output driver is the best?
Old 3rd March 2018, 17:35   #945  |  Link
LoRd_MuldeR
Software Developer
MPlayer for Windows 2018-03-03
[2018-03-03]
* MPlayer binaries updated to SVN-r38018
* SMPlayer updated to version v18.2.2 (SVN-r8937)
* Some installer improvements
[MPlayer r38018+gdd8351b118]
Upgraded gcc to 7.3, enabled lto in FFMpeg
Enabled dash demuxer in FFMpeg
Enabled libopenmpt in FFMpeg
Updated gnutls to 3.5.18
Updated openh264 (git)
Updated kvazaar (git)
Updated x265 (hg)
Updated x264 (git)
Updated fdk-aac (git), download new dll
Updated frei0r (git), download new plugins
Updated libdvdcss (git)
Updated libdvdnav (git)
Updated libdvdread (git)
Updated freetype to 2.9
Updated zlib to 1.2.11
Updated enca to 1.19
Updated gmp to 6.1.2, nettle to 3.4 and gnutls to 3.3.28
Updated gme to 0.6.2
Added libkvazaar HEVC encoder (git)
Added Cisco's Open Source H.264 Codec (git)
libxml2: fix for CVE-2017-8872
libmad: updated patches from debian (security fixes)
Windows XP warning: If you are still using Windows XP and you are trying to update via the Auto-Update tool, you probably will experience download errors. The cause of this is that most of our download mirrors (GitHub, Bitbucket, etc) have switched to TLS-only downloads by now – i.e. any plain HTTP request is redirected to HTTPS – but Windows XP only supports outdated TLS cipher-suites that are considered "insecure" and therefore are not allowed by these sites anymore. This will result in a TLS handshake failure on Windows XP systems. There is no way to fix this, except by updating to a less antiquated operating system. Please see here for details!
Old 11th March 2018, 17:42   #946  |  Link
Starks
Thanks. What's new with mplayer that mpv hasn't already been doing and better?
Starks is offline   Reply With Quote
Old 18th March 2018, 17:42   #947  |  Link
LoRd_MuldeR
Software Developer
See answer from "mpv" FAQ:
How is mpv related to MPlayer?
The relation between the two projects is mostly historic. They should be considered two separate projects. mpv and MPlayer are different software, incompatible to each other. There is no overlap in developers and other project members between MPlayer and mpv. mpv is not a drop-in replacement for MPlayer, and the command line switches and behavior are different.
MPlayer users should not expect that mpv is in any way similar to it. Both are CLI video players, and have common roots, but in some areas there are radical differences.
Old 18th March 2018, 17:44   #948  |  Link
LoRd_MuldeR
Software Developer
MPlayer for Windows 2018-03-18
[2018-03-18]
* MPlayer binaries updated to SVN-r38020
[MPlayer r38020+g7af2336598]
* Added libcodec2 0.7 and enabled in FFMpeg
* Added wavpack patches for CVE 2018 6767/7253/7254
* Added z.lib (git) and enabled in FFMpeg
* Added FFMpeg Nvidia Codecs headers to build Nvidia hw accels
* Added mpg123 1.25.10 and enabled in MPlayer
* Added harfbuzz 1.7.6
* Removed faac from MEncoder, please use -oac lavc -lavcopts acodec=libfdk_aac and the binary dll
* Updated libwebp to 0.6.1
* Updated libopenmpt to 0.3.7
* Updated xvidcore to 1.3.5
* Updated fontconfig to 2.13.0, updated configurations in dist
* Updated fribidi to 1.0.1
* Updated fdk-aac (download new dll)
* Updated libxml to 2.9.8 (with included CVE patches)
* Updated soxr to 0.1.3
* Updated libcdio/paranoia, now using git repo
* Updated libdvdcss (git)
* Updated openh264 (git)
* Updated kvazaar (git)
* Updated x265 (hg)
Old 27th March 2018, 04:58   #949  |  Link
WSC4
Your bundled visions of SMPlayer, MPUI (MPlayer GUI) and MPlayer works find, but I have decided now to uninstall MPlayer For Windows and I'll unsubscribe from this thread.
I did not like SMPlayer and only used it a few times to try out. MPUI I found better with far less bells and whistles and used it only every now an then. Most of my work is done with MPlayer on the command line.
All these programmes you can get individually from Sourceforge.net, and I'll download MPUI and MPlayer form there in the future.
Last edited by WSC4; 26th April 2018 at 04:29. Reason: Uninstalling MPlayer For Windows
Old 16th October 2019, 22:40   #950  |  Link
LoRd_MuldeR
Software Developer
MPlayer for Windows 2019-10-15
[2019-10-15]
* MPlayer binaries updated to SVN-r38152
* SMPlayer updated to version v19.5.0.0 (SVN-r9214)
[MPlayer r38152+gcc50d113c8]
* Switched from gnutls to mbedtls
* Updated zimg (git)
* Updated x265 (hg)
* Updated libcdio/paranoia (git)
* Updated fdk-aac (git), download updated dll
* Updated frei0r (git), download updated plugins
* Updated twolame to 0.4.0
* Updated expat to 2.2.9
* Updated bzip2 to 1.0.8
* Updated flac to 1.3.3
* Updated freetype to 2.10.1
* Updated fribidi to 1.0.7
* Updated giflib to 5.2.1
* Updated libiconv to 1.16
* Updated libjpeg-turbo to 2.0.3
* Updated libogg to 1.3.4
* Updated libopenmpt to 0.4.9
* Updated libwebp to 1.0.3
* Updated mpg123 to 1.25.12
Old 16th October 2019, 22:49   #951  |  Link
stax76
Originally Posted by LoRd_MuldeR View Post
Why not use mpv instead? It's far superior.
Old 24th October 2019, 09:01   #952  |  Link
avih
Capture, Deinterlace
avih's Avatar
It's also very different, has higher requirements (e.g. no XP support), and removed some things which mplayer probably still supports. It's not "mplayer with few more things", and some people may prefer mplayer in general or for some specific use cases.
avih is offline   Reply With Quote
Old 27th October 2019, 12:26   #953  |  Link
LoRd_MuldeR
Software Developer
Well, because this is an MPlayer distribution package. Maybe MPV could be included as an option, but I would have check the implications.
Old 25th April 2020, 16:37   #954  |  Link
LoRd_MuldeR
Software Developer
MPlayer for Windows 2020-04-25
[2020-04-25]
* MPlayer binaries updated to SVN-r38184
* SMPlayer updated to version v20.4.2.0 (SVN-r9306)
* Included 64-Bit (x86-64) MPlayer build for 64-Bit systems (new default on 64-Bit systems, disables support for "binary" Codecs)
MPlayer r38184+g13171ad2e3 - FFmpeg N-97389-g13171ad2e3
* Updated x265 (hg)
* Updated libfdk-aac (git), download updated dll
* Updated WavPack (git)
* Updated libcdio-paranoia (git)
* Updated libdvdread/libdvdnav (git)
* Updated fribidi to 1.0.9
* Updated gme to 0.6.3
* Updated libdca to 0.0.7
* Updated libjpeg-turbo to 2.0.4
* Updated libopenmpt to 0.4.12
* Updated SDL2 to 2.0.12
mplayer, mpui, player, smplayer, win32
