Old 23rd June 2022, 07:23   #1  |  Link
kivuy
deinterlace question
hi if anyone know how to deinterlace 1080i with top field first ?>?
kivuy is offline   Reply With Quote
Old 23rd June 2022, 20:58   #2  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Maybe start here:
http://avisynth.nl/index.php/Interla..._deinterlacing
http://avisynth.nl/index.php/QTGMC
Old 24th June 2022, 10:42   #3  |  Link
richardpl
QTGMC changes both fields, this is far from optimal solution.
richardpl is offline   Reply With Quote
Old 24th June 2022, 14:33   #4  |  Link
poisondeathray
It depends on what your goals are for "deinterlacing"
QTGMC also has a lossless option that retains the original fields
But if your goal was to reduce bob flicker and aliasing artifacts, then choosing to retain the original fields is far from the optimal solution
Old 25th June 2022, 14:13   #5  |  Link
cubicibo
Suggest something else then. Sure, you could use "MSU Deinterlacer" or NNEDI3 that leave the input fields untouched but you're in for serious shimmering and flickering on most if not all footages.
At times, it is better to have something pleasing to look at than being just lossless.
cubicibo is online now   Reply With Quote
Old 25th June 2022, 14:20   #6  |  Link
LoRd_MuldeR
Software Developer
Also, to my understanding, QTGMC has a so-called "lossless" mode, if that is desired:
http://avisynth.nl/index.php/QTGMC#S...h_.2F_Lossless
The additional Lossless modes are designed to take source-match to its logical conclusion: Lossless mode 1 restores the *exact* pixels of the source into the output (provided NoiseRestore=0). This recovers a liitle more source detail but can introduce shimmering, minor combing, noise etc. Note the Sharpness and MatchEnhance settings have little effect in lossless mode 1. Lossless mode 2 makes the clip lossless before the sharpening & final temporal smooth. This removes most of the lossless artefacts and also allows sharpness control. This mode will not give an exactly lossless output but it will gain a little more detail.
