3rd February 2021, 13:05 | #61 | Link |
Lost my old account :(
Just to add some numbers regarding utilization with threading options left at default:
--main10 --preset slow --crf18 on an 24C/48T Eypc Rome: 1080p Bluray source: With CTU 64 & Merange 57: 25-35% With CTU 32 & Merange 26: 50-70% 2160p UHD Bluray source: With CTU 64 & Merange 57: 50-95% (24threads pinned at 100%, the other 24 is very unstable). 1080p with CTU 32, and UHD at default should give great saturation up to 16/32 for single instance encoding. 5950X is likely the fastest single instance encoding processor you can get for these cases atm (I would guestimate that it would beat 3960X & whatever intel has to offer including all xeons). Last edited by excellentswordfight; 3rd February 2021 at 13:28. |
3rd February 2021, 15:47 | #62 | Link |
CPU usage should be even higher if you do some heavy filtering like denoising in avisynth (MDegrain + prefetch 24)
3rd February 2021, 23:30 | #63 | Link |
But how many threads can those algorithms usefully use at once? Temporal denoising can be hard to parallelize because it is an interframe analysis process. But possible if each frame is doing forward and backward comparisons without reusing other analysis of the same frames. Can double the total CPU, but offer a lot better parallelism.
4th February 2021, 00:05 | #64 | Link |
Modern video processing frameworks relying on caches, no need to compute stuff twice. Just pick cached frame and reuse or fallback to full processing on cache misses. With high amount of RAM MDergain is fast enough.
4th February 2021, 21:55 | #65 | Link | |
18th August 2021, 17:36 | #67 | Link | |
https://forum.doom9.org/showthread.php?t=174393&page=4 The 3900x is barely ahead of the 5800x. |
27th August 2021, 14:13 | #68 | Link | |
3rd September 2021, 07:31 | #69 | Link |
Video Fanatic
I've just ordered an AMD 5900x and RTX 3080 for encoding (NVENC still has a few use cases outside of streaming). The reason for the 5900x (or even going for a 3000-series or any other 5000-series) is power savings, less heat, and better value for money with multithreaded workloads such as encoding. As it stands, I would recommend AMD (I believe that's the first time I've written that since I purchased an Athlon 64 X2 as a child!).
PC: R9 5900X | 32GB 3600 MT/s RAM | 2*1TB NVMe | RTX 3080 | water-cooled NAS: SM 48-bay 240TB+ storage | Xeon 1220 | 32GB DDR4 ECC HTPC: Pentium J5005 | 16GB RAM | 256GB SSD | 15W |
12th September 2021, 21:04 | #71 | Link |
I assume AMD will be better (HW encoding usually performs worse than SW), and 8 big + 8 small cores might make things slower against full-power 16 cores by AMD. So just wait for actual release and check speed comparisons before buy.
13th September 2021, 17:42 | #72 | Link | |
I don't know anyone doing that in practice for file-to-file encoding. |
16th September 2021, 09:47 | #74 | Link |
You can root Intel Chipset Minix OS and get access to ucode and modify it. So Intel, of course. What a dumb question! Just simply picosecond precision digital analyser inside is already equvivalent to millions of $.
20th September 2021, 19:39 | #76 | Link |
All ryzen cpus with a integrated GPU have a smaller L3 cache. So there's a small downside
20th September 2021, 19:42 | #77 | Link | |
https://tpucdn.com/review/intel-core...ncode-h265.png Not sure about the speed as I rarely use preset fast, nor own an 5800x, but I would guestimate that it would be in in the 50fps+ range. Last edited by excellentswordfight; 20th September 2021 at 21:15. |
21st September 2021, 00:47 | #79 | Link |
Right, no AVX512 in any of the announced, or even rumored, AMD CPUs.
However, Zen3 CPUs encode with x265 very quickly, so the lack of AVX512 is not really a minus for x265 encoding.
madVR options explained |
21st September 2021, 15:59 | #80 | Link |
Intel 11th gen desktop igpu has a good hardware hevc encoder (in addition to an av1 hardware decoder).
avx512 isn't reported as being available with 12th gen Intel desktop (releasing Q4 2021).
bShaders: realtime Effects/filters for video players |
