Thread Tools Display Modes
Old 9th March 2022, 07:46   #1  |  Link
RocketJet
RocketJet's Avatar
VirtualDub2: HUFFYUV won't do YUY2 in Windows 10
In both VirtualDub and VirtualDub2, under Windows 10, HUFFYUV ignores the YUY2 setting in the configuration window, so output is always RGB.
Could this be investigated, please?
RocketJet is offline   Reply With Quote
Old 9th March 2022, 08:39   #2  |  Link
Sharc
No problem here.
So what should be "investigated"? What are you doing? You should provide more info if you want help.
Old 9th March 2022, 11:32   #3  |  Link
RocketJet
RocketJet's Avatar
I am creating video files using VirtualDub2, with the HUFFYUV codec.
In the configuration window, I click on "<-- convert to YUY2",
which should change the output color space from RGB to YUY2.
However, it ignores the setting, and the output is RGB.
This should not happen.
YUY2 color space compresses more than RGB color space,
so it is important to me.
Old 9th March 2022, 12:03   #4  |  Link
Sharc
In Vdub2:
Video->Compression->Huffyuv v2.1.1->PixelFormat: select 'No change' or 'YCbCr 4:2:2' for example.
(You have probably selected RGB there)
Old 9th March 2022, 12:34   #5  |  Link
RocketJet
RocketJet's Avatar
That worked fine. Thank you very much.
Old 9th March 2022, 18:50   #6  |  Link
You should also not select the default, Menu/Video/Full Processing -
mode, should be either Fast Recompress OR Normal Recompress.
Otherwise you provide the HuffYUV compressor with RGB (when Full Processing mode).
You should also select in HuffYUV config, something like (I dont have HuffYUV installed)
RGB>YUV, and one of the other options, Something like "Left Median" - Fastest ... or something like that.
huffyuv, virtualdub2, yuy2
Thread Tools
