Thread Tools Display Modes
Old 3rd January 2026, 19:43   #1941  |  Link
rgr
Originally Posted by v0lt View Post
I don't care about bugs in older versions when a newer release has been released.
I have no issues with Direct3D 9.
I can confirm that the latest VDub (test) also hangs with DirectX9, and the only way to fix it is to kill it from the task manager.
Switching to DirectX11 solves the problem.
The hang seems to always occur in one specific instance: when I switch from VDub to another program/window while a video is playing (+AVS loaded via CID as usual).
I don't know which version this has been happening since, as I was previously working with OpenGL.
rgr is offline   Reply With Quote
Old 7th January 2026, 13:35   #1942  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
I don't know if anyone will care, but:
With Display options set to Use OpenGL, scale at 75%, and filter as Bicubic, the image comes out somewhat aliased. I haven't seen it happen with any other combination yet.
Bicubic on left, bilinear on right.
wonkey_monkey is offline   Reply With Quote
Old 7th January 2026, 13:53   #1943  |  Link
tormento
Acid fr0g
tormento's Avatar
Any kernel introduces some artifacts.
When zooming to see the REAL quality of a video or an applied filter, I prefer to use the least invasive kernel possible.
Otherwise, what you are watching are the filter artifacts, not the video itself.
@turment on Telegram
Old 7th January 2026, 14:09   #1944  |  Link
wonkey_monkey
Bicubic shouldn't introduce these artefacts. It looks fine under DirectX 9, for example, so there's something wrong somewhere under OpenGL.
Actually I think it's just not implemented and is reverting to Nearest Neighbour.
Old 18th January 2026, 02:15   #1945  |  Link
jay123210599
I put this in a Vapoursynth script:
clip = clip.std.SetFrameProps(_Matrix=1, _Primaries=1, _Transfer=1)
But when I put the script in VirtualDub2 with the code, the actual format was YUV420 instead of YUV420-709. How do I change that?
jay123210599 is offline   Reply With Quote
Old 22nd January 2026, 12:25   #1946  |  Link
rgr
Use Caching Input Driver, not AVIFile.
Old 25th January 2026, 06:28   #1947  |  Link
v0lt
... or configure the Decode Format settings.
v0lt is offline   Reply With Quote
Old 25th January 2026, 14:21   #1948  |  Link
jay123210599
How would that help with my problem?
Old 26th January 2026, 09:32   #1949  |  Link
rgr
AVIFile does not detect the format, it uses the one you set in Decoder Format.
Old 27th January 2026, 19:17   #1950  |  Link
jay123210599
How do I use Caching Input Driver?
Old 3rd February 2026, 21:34   #1951  |  Link
rgr
File-->Open video file-->Open using...
Old 13th February 2026, 00:11   #1952  |  Link
jay123210599
It doesn't work for .vpy scripts.
Old 13th February 2026, 13:24   #1953  |  Link
Maybe like so, [Set, "Files Of Type"] [EDIT: Untested, I dont use vpy]
Old 13th February 2026, 14:32   #1954  |  Link
v0lt
Test build VirtualDub2 v2.5.2.1123
Fixed display of the duration of the selected range in the status.
Potential memory leaks have been fixed.
32-bit "PICVideo Lossles JPEG Codec" (pvljpg20.dll) is not supported because it crashes when opening the video compression selection window.
Fixed video capture with compression in the "FFmpeg FFV1" and "x264 8 bit" codecs.
Old 14th February 2026, 01:07   #1955  |  Link
jay123210599
How do I use Caching Input Driver for my scripts, then?
Old 14th February 2026, 01:14   #1956  |  Link
jay123210599
How do I set the time format to this: 0:00:06.95
Old 25th February 2026, 15:48   #1957  |  Link
nji
v2.5.1.1095_win32.7z: Malware by Fortinet
https://www.virustotal.com/gui/url/9...c0c0?nocache=1
nji is offline   Reply With Quote
Old 25th February 2026, 18:33   #1958  |  Link
Thundik81
It's a scan for the link!
https://github.com/v0lt/VirtualDub2/releases
sha256:bdaed02fd92ddd67e9ee43ddc9cacb79192462833fc122e1e2608fe1f6d8ac93
https://www.virustotal.com/gui/file/...608fe1f6d8ac93
Up to you to Reanalyze all files included:
https://www.virustotal.com/gui/file/...ac93/relations
Thundik81 is offline   Reply With Quote
Old 25th February 2026, 18:54   #1959  |  Link
nji
You are right, thank you.
Sorry about that!
However that's kind of confusing at the virustotal page.
I always thought that by entering an URL there would make unnecessary to d/l the file,
but have virustotal analyse the file directly from the URL given.
This doesn't seem to be possible?
Old 25th February 2026, 19:43   #1960  |  Link
Columbo
What time format? Where?
Columbo is offline   Reply With Quote
Thread Tools
