Thread Tools | Display Modes |
#941 | Link | |
DoVi_Scripts //// Dolby Vision Stuff (more tabs below) LG OLED G5 77'' + 7.2.4 Denon AVR + Ugoos AM6Bplus + Kaleidescape Strato E Sorry for my English |
#943 | Link |
Also, the plex app and the tv menu navigation are noticeably slower and sometimes lag. I hate this update!!!
#944 | Link | |
QfG Group Germany
I have a Dune Homatics 4k R Plus Box, with a CoreELEC CPM build and full FEL support. I can only recommend it to everyone.
#945 | Link |
Thank you again Kuler087 for the awesome tools and research. Do you or anyone else know if Snake Eyes 1998 or Andor S01 UHD are safe to convert to 8.1 without baking fel etc. ? I don't see them on the spreadsheet. Thanks!
#946 | Link |
I dont remember. Run the files in workflow 7-1 and find out.
#947 | Link |
If anyone is interested in testing a new function? I did a new workflow(7-4) that can create DV metadata comparison videos with 10 frames in loop.
it takes 10 different frames (auto or manual) and makes a loop of 69 frames alternating No metadata/no tone mapping vs L1(L3) only vs L1+ artistic trims The whole process is very fast, about 5 minutes on my PC and supports batch processing. So comparing the DV tone mapping is now very easy and effortless. latest beta: https://drive.google.com/file/d/128g...usp=drive_link new files to put in the tools folder: https://drive.google.com/drive/folde...usp=drive_link I did a couple of samples: https://drive.google.com/drive/folde...iSlcdMiy2ka0mf (7-5) I'll also add another similar workflow that compares DV metadata with FEL baked and without FEL. This workflow is not completed yet.
#948 | Link | |
my PC with Ryzen 7950X Last edited by DMD; 12th January 2025 at 23:00. |
#949 | Link |
@R3S3T
If I bake FEL using workflow 8-2-1 to get a 1080p rip, then from that rip I extract the 8.1 RPU with workflow 1, can I inject the said RPU to a fresh 1080p BL/HDR10 rip of the same movie and preserve the FEL information as the original rip did? |
#950 | Link |
only if the other 1080p encode has FEL baked in.
#952 | Link |
The P7 RPU can only be played properly with a BL that has fel baked in so if the second video was not processed with the dovi baker, you can't inject the rpu.
#954 | Link |
Is anyone aware of a list of P7 disc-sourced titles that are CMv4 ? I just looked at the UK release of The Usual Suspects and doviscripts reports it as MEL CM 4. I can't imagine that my Panny UB820 can take advantage of that, but my Ugoos and ATV can. For curiosity I guess there is a plotting workflow that can show what the additional v4 levels are doing?
#955 | Link | ||
#957 | Link |
8-2-2 HDR to SDR x264
I've noticed a similar CPU usage scenario when encoding from HDR to SDR ( x264) as with FEL to SDR (x264). Adding Prefetch(2) to ::tonemap, enabled ≈ 100% CPU usage from ≈ 70%.
::tonemap if "%SDR%"=="y" echo ConvertBits(16) >> "%TEMP%script.avs" if "%SDR%"=="y" echo libplacebo_Tonemap(src_csp=%inCS%, dst_csp=0, dst_max=%SDR_target_nits%, dynamic_peak_detection=%peak_detect%, smoothing_period=%smoothing_period%, percentile=%percentile%, tone_mapping_function="%tone_mapping_function%", gamut_mapping_mode="%gamut_mapping_mode%") >> "%TEMP%script.avs" if "%SDR%"=="y" echo ConvertToYUV420(matrix="709") >> "%TEMP%script.avs" if "%SDR%"=="y" echo ConvertBits(10) >> "%TEMP%script.avs" if "%SDR%"=="y" echo Prefetch(2) >> "%TEMP%script.avs" Last edited by Gatorman3385; 19th January 2025 at 20:19. |
#958 | Link | |
Ok, (7-5) is now completed. You can now create BL vs FEL videos comparison that will show you exactly how FEL looks on device that can't decode it and on device that can. latest beta: https://drive.google.com/file/d/128g...usp=drive_link You must update these files again: https://drive.google.com/drive/folde...usp=drive_link I did a couple of samples: https://drive.google.com/drive/u/0/f...BIQmziCe_R_IKe These updated files also fix a bug in 7-4 with input that had a 100 and 1000nits trim (rare). these are SDR GIFs of HDR output, so ignore the clipping... ![]()
#959 | Link |
thanks
#960 | Link |
Some help please.
Running DoVi_Scripts_MKV.bat’s workflow(6-2) process Calculating per shot MaxFALL threshold...issues: Python was not found; run without arguments to install from the Microsoft Store, or disable this shortcut from Settings. Both python.exe and pythonw.exe are in a same folder. Python.exe opens its Dolby_Scripts_GUI V1.0.0_BETA Window. And, how to understand run without arguments? I’ve tried running DoVi_Scripts_MKV.bat without processing file but no result. Thanks Last edited by spasv; 20th January 2025 at 16:45. |
| Tags |
| batch scripts, dolby vision processing, dovi_scripts |
| Thread Tools | |
| Display Modes | |
