#21 | Link |
Hi this completed and I'm happy with the results (Thank you Kuler087 (Reset)), also it took less than 4 hours so not too bad, I will try with the lookahead options next time I have a title that needs baking. Thank you.
#22 | Link |
Posts: n/a
A few questions....
I am of course still learning this, and I have found a couple of things that I can't figure out. 1) When converting say a .thd, when the process if done, it's in an .mkv container, open it in MediaInfo, it's only the converted audio. So it basically needs to be demuxed, or maybe renamed.... 2) I tried to convert a Profile 5 (only) movie, with option 8-2-1, and it states that the P5 will be injected as a P8.1, these rpu's are in the temp folder (until they're not), so I copied them to play with later (yet to do that), but the processed file is a .hevc, no audio, no sub's, just the HDR10 conversion..I guess now I need to run it thru 3-1 to create a hybrid ??? 3) Is there a way to save the temp folder, just in case there's something that might be needed ?? 4) Also, if there are some temp or processed files from a previous job still present, and another job is started, and you don't notice, when it's almost completed, it states there are some same named files, and the process stops ![]() 5) Also, you use FFMS2 as the decoder, is there a way to use some other decoder, eg:- L-Smash, DGindex, etc ? 6) I acquired DEE for another purpose, so I tried to map that, but it wasn't happy. I think that's it, for now, sorry. Cheers |
#23 | Link |
1- Yes, EC3 track are encoded to an mkv container in order to preserve any delay present in input.
2- Encoder workflows don't mux by design. If you just mediainfo the hevc file, it won't show any DV info. You have to mux to mkv/ts/mp4 and then the DV flag will be present. 3- No but I could add the option in the next version 4- I've never seen that? if you start a workflow and the same temp folder already exist, it's automatically deleted before running the workflow. 5- I never had issue with ffms2 so I have no reason to use other indexers. 6- I don't like DEE... I wont touch those workflows.
DoVi_Scripts |
#24 | Link | |
Posts: n/a
Thanks for the comments/feedback, Reset
![]() Quote:
#25 | Link | |
DoVi_Scripts |
#26 | Link | |
Posts: n/a
Hi Reset,
I have come across a dilemma (for me, that is), I have some video's (LOTR series), and they are "loaded" with DV P8.1, HDR10 & HDR10+. My question is, I want to edit certain stuff out of each clip (eg:- the intro, previously on, and maybe end credits), would it better to extract the rpu before the editing, and can the original unedited rpu inject properly ?? (I don't know how rpu's work) OR just do the edits, and process it as a "new" hybrid ?? More info:- I just did a quick edit on a sample of this, and after running it thru RipBit264, it loses both the DV & HDR10+ info ![]() So it will need something injected afterwards, maybe easier just to run a Hybrid conversion. It shouldn't matter if the HDR10+ info has gone, when you get the DV info back...correct ?? Even more info_:- Just did a quick Hybrid on the above sample, and it gets DV back, but only P8.0 (original was P8.1), (can you add a P8.1 option ??) also, I converted the AAC track to FLAC....DoVi_Scripts (or something it uses, I know you mention tsmuxer) doesn't like FLAC, there was no audio track, just video & sub's. Might extract the rpu from the unedited sample, and see what happens trying to inject it...worth a shot. Didn't work, got a lot of errors, this one was the first of many Quote:
#27 | Link | ||||
see this video if you don't understand how to verify your RPU scene cuts: https://www.youtube.com/watch?v=lIO_ZfT-LnY Quote:
The script can only convert lossless audio to flac or pcm Quote:
DoVi_Scripts |
#28 | Link | ||||
Posts: n/a
But yeah, I'm probably missing a lot of things. ---------------------------------------------------------------------------- I know that I have only been using this for a couple of weeks, and it just keeps amazing me what it can do ![]() I know I'll have more questions, but I'll try not to bother you too much. But whatever info you post here, will help others that want to use this. Thanks again. Cheers |
#29 | Link | |
You just copy the text from the window like this: https://justpaste.it/ejshe this is a FLAC mkv input btw
DoVi_Scripts |
#30 | Link |
Posts: n/a
Me again,
Now testing with 2.0.2...some nice changes & additions ![]() So first off, I have been using the mp4.bat, as that will play on my LG TV. Then, earlier today, I grabbed the latest beta, which in only mkv, and one of the first things I noticed in 3-1 was this :- Code:
------------------------------------------ Input tracks info: index=1 codec_name=truehd channel_layout=7.1 TAG:language=eng index=2 codec_name=ac3 channel_layout=5.1(side) TAG:language=eng ------------------------------------------ Do you want to convert the audio to DDP? (y or n default=n) if input is 7.1, a 2nd window will popup, DO NOT CLOSE IT ----------------------------------------------------------------------------- So anyway, I processed a short HD10+ clip thru 2.0.3, and of course got an .mkv. And here's the MediaInfo video data on that conversion:- Code:
MediaInfo data from DoVi_Scripts 2.0.3 BETA mkv:- Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, Profile 8.1, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2094 App 4, Version HDR10+ Profile A, HDR10+ Profile A compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 10 min 0 s Bit rate : 43.9 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.221 Stream size : 3.07 GiB (87%) Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 737 cd/m2 Maximum Frame-Average Light Level : 130 cd/m2 Code:
MediaInfo data from DoVi_Scripts 2.0.1 mp4:- Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, Profile 8.0, dvhe.08.06, BL+RPU / SMPTE ST 2094 App 4, Version HDR10+ Profile A, HDR10+ Profile A compatible Codec ID : dvhe Codec ID/Info : High Efficiency Video Coding with Dolby Vision Duration : 10 min 0 s Bit rate : 43.9 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.221 Stream size : 3.07 GiB (86%) Default : Yes Alternate group : 1 Encoded date : 2024-02-22 04:35:46 UTC Tagged date : 2024-02-22 04:36:39 UTC Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 737 cd/m2 Maximum Frame-Average Light Level : 130 cd/m2 Codec configuration box : hvcC+dvcC |
#31 | Link | ||
probably because the script, by default use the very old mp4muxer which doesn't have a parameter to set the BL ID. Change the script MP4 version to new and mediainfo should report 8.1
DoVi_Scripts |
#32 | Link | |
Posts: n/a
Hopefully changing to the newer mp4muxer won't affect the playback on my LG. Cheers. |
#33 | Link |
if it's 2019+ , the new mp4muxer should work.
DoVi_Scripts |
#34 | Link |
Posts: n/a
Hmmm, I have a 55SK8500PTA, which I think is mid to late 2018...I guess there's only way to find out.
I'll let you know. UPDATE:- Well, unfortunately P8.1 won't display DV, only HDR ![]() Last edited by TDS; 23rd February 2024 at 04:04. |
#35 | Link | |
![]() Join Date: Jan 2006
I was pleasantly startled when my 2017 Z9D magically gained Dolby Vision support several years after I acquired it. |
#36 | Link |
I think 2018 is the year they added Profile 8 support. The LG C7 doesn't support it but the C8 does.
DoVi_Scripts |
#40 | Link |
aac, I'm not sure if it's supported but I think AC3 is supported if you just run a file without lossless audio in 8-1-1
I'll check it out.
DoVi_Scripts Last edited by Kuler087; 23rd February 2024 at 14:18. |
batch scripts, dolby vision processing, dovi_scripts |
