Old 7th June 2017, 23:58   #44041  |  Link
Dorohedoro
Honestly, I'd just start with a clean config. Grab MPC-HC/BE use LAV or internal filters, back up your madVR settings and reset to default, disable ffdshow, disable reclock and see what happens.
If still getting stuttering, uninstall your graphics drivers completely, reboot and reinstall.
Sadly I already did all of that. I've tested different configs with mpc-hc, zoomplayer, potplayer, even with windows media player lol.
Thanks!
Dorohedoro is offline   Reply With Quote
Old 8th June 2017, 22:22   #44042  |  Link
daglax
Hi madshi,
i try to switch profiles depending on the display name:
if (display = "Acer") "Profile1" else "Profile2"
But that doesnt work as expected. Seems like madvr doesnt recognize the display name. I tried the name that madvr shows me under the "devices" tab in madvr settings. Is this a bug?
daglax is offline   Reply With Quote
Old 9th June 2017, 02:45   #44043  |  Link
Georgel
Visual Novel Dev.
Georgel's Avatar
Originally Posted by Olivier C. View Post
For sure !
Try one of these :
- Screenpresso (Free version available) :
https://www.screenpresso.com/
- Lightscreen (free) :
http://lightscreen.com.ar/
(non exhaustive list)
Then go to Settings and define a default directory, filename, format (png, ...) and hotkeys !
You should disable FSE (Full Screen Exclusive mode) :
madVR Settings --> Rendering --> General Settings
Now you can take screenshots in a very fast way (without dialog), in both windowed and fullscreen modes (disable FSE in madVR)
Enjoy !
Thank you very much!
Your advice is excellent, those tools work great!
Georgel is offline   Reply With Quote
Old 10th June 2017, 02:57   #44044  |  Link
70MM
X Cinema Projectionist NZ
Is there anyway to stop the first quick initial burst of repeated/dropped frames when you first start a video. I dont get them after about 4/5 secs just till everything settles down at the start. maybe 1 dropped frame and 9/10 repeated frames, 4/5 secs later it stops.
70MM is offline   Reply With Quote
Old 10th June 2017, 06:29   #44045  |  Link
ryrynz
ryrynz's Avatar
Maybe by changing power profile or buffers.
Old 10th June 2017, 07:37   #44046  |  Link
70MM
ryrynz would you mind telling me where do I find power profile and buffers to test please?
Ive been looking and not sure where to find them in madvr....
Old 10th June 2017, 08:47   #44047  |  Link
ryrynz
ryrynz's Avatar
Power profiles are graphics card related, check the control panel.
Buffers or queues are under General, Windowed and Exclusive. CPU, GPU queues and 'frames presented in advance' try lower values.
High priority on the media player may help but it's likely it's just your GPU not ramping up fast enough to cope.
If none of those helps then see if lower demanding settings change anything, most aren't concerned with frame drops at the start.
Old 10th June 2017, 09:14   #44048  |  Link
70MM
Ok thank you I understand. I dont use exclusive mode but have tested changes in window mode but it doesn't help. Maybe I also just live with drops at the startup of a film, it only lasts less than 5 secs, after that its amazingly stable, drops/repeats after days....
Old 10th June 2017, 10:29   #44049  |  Link
Sunset1982
Is anyone here running a gtx1050ti for upscaling 1080p24 to 4k?
I consider buying a new gtx1050ti (4gb) or 1060 (6gb) for upscaling 1080p24 to my uhd tv. I wonder if it has enough power using ngu high for luma and ngu aa mid for chroma...
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64)
LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set
Sunset1982 is offline   Reply With Quote
Old 10th June 2017, 10:49   #44050  |  Link
cork_OS
cork_OS's Avatar
GTX 1060 3Gb, 1080p doubling, NGU AA med + NGU Sharp high = 20.6..21.00ms
For 1080p60 -> WQHD I use sXBR 125 + NGU Sharp med.
I'm infected with poor sources.
cork_OS is offline   Reply With Quote
Old 10th June 2017, 10:51   #44051  |  Link
johnnylaiyee
johnnylaiyee's Avatar
I'm using a 1050 2gb and upscaling 1080p to 2160p with luma ngu high chroma superxbr 200% without any issue. Averaging around 28ms.
Sent from my LG-H860 using Tapatalk
johnnylaiyee is offline   Reply With Quote
Old 10th June 2017, 11:02   #44052  |  Link
HillieSan
What is wrong with your RX 480?
HillieSan is offline   Reply With Quote
Old 10th June 2017, 15:09   #44053  |  Link
Sunset1982
good to know, thx!
Got HDMI connection errors sometimes during movies and getting black screen video, while audio still works. Got a friend having same problems. So I put the rx480 into my gaming pc.
Old 10th June 2017, 15:36   #44054  |  Link
had the same problem and AMD was playing on time.
that's the only reason i had to replace it.
Old 10th June 2017, 19:11   #44055  |  Link
mzso
Hi!
How good is madVR's deinterlacing considered? Becuse I see a lot of combing artifacts. And I'm not sure whether it's working correctly or not. (madvr shows "deinterlacing on")
Old 10th June 2017, 20:37   #44056  |  Link
video mode deinterlancing is DXVA deinterlancing.
film mode deinterlancing is a field match algorithm that can do more you will get combing with it if you run it on true interlanced content.
make sure your GPU queues are at least at 8.
Old 10th June 2017, 21:40   #44057  |  Link
mzso
I get quite severe combing with forced video mode. Meanwhile with LAV's HW deinterlacer I see none. Is it that much superior?
Old 10th June 2017, 21:59   #44058  |  Link
it should be the same can you make a screen of the OSD?
Old 10th June 2017, 23:46   #44059  |  Link
AbbeKoenig
Unstable display rate?
This is my setup:
Asus GL702VM (nVidia GTX1060, 75Hz G-Sync), latest stable builds of MPC-HC, madVR, LAV filters and assFilterMod, all 64bit where available.
I am having a slightly funny problem of unstable display rate. I'm talking about the "display" line when one presses Control-J while playing a file.
The composition rate stays at 75.00-something Hz while the display rate fluctuates around 74.8-something Hz, but never hits 75 Hz. After a rather significant amount of time - mostly after about an hour into a movie because I don't notice this when playing 24-minute anime episodes - the display rate sharply drops to 40.00-something Hz, then slowly climbs back up to 66.3-something Hz. This all happens without any visible effects or any increase in the dropped frames/display glitches counters. Interestingly the clock deviation statistic does not seem to change along with the display rate change. I am not using ReClock.
This does not seem to happen in windowed mode, however both fullscreen exclusive and non-exclusive is plagued with this problem. In windowed mode, display rate is at a steady 75.00-something Hz and never dips below 75 Hz.
Even though there don't seem to be any visual effects related to this, I'm still rather bothered by this problem. Any help is greatly appreciated. Thank you!
AbbeKoenig is offline   Reply With Quote
Old 11th June 2017, 00:32   #44060  |  Link
mzso
Why? I already told you deinterlacing is on.
Anyway here it is:
