Old 21st August 2016, 16:41   #401  |  Link
feisty2
I'm Siri
feisty2's Avatar
Originally Posted by jackoneill View Post
Any reason why I shouldn't just remove the SATD functions entirely?
because they are the components from avisynth mvtools..?
well, SATD transforms the difference to frequency domain(Hadamard Transform = Discrete Fourier Transform mathematically on a 2^n * 2^n square block) and it helps with shimmering and fading sometimes like dct=1, but much faster than that
If I got new ideas, will post here: https://github.com/IFeelBloated
feisty2 is online now   Reply With Quote
Old 21st August 2016, 16:48   #402  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
I have a simple question. Has anyone ever tried SAD but with the average value of the input blocks adjusted? I mean the main point of this exercise is to reduce the whole block average into a single coefficient to reduce its influence a lot. There should be some faster but still good for 90% of the times trick.
And saying it's in avisynth is a bad excuse. Temporalsoften is in avisynth and that's nothing to be proud of.
Myrsloik is offline   Reply With Quote
Old 21st August 2016, 16:57   #403  |  Link
feisty2
I'm Siri
feisty2's Avatar
more specific? adjusted how, and mode 6-10 are hybrid SAD/SATD modes, and faster than mode 5(100% SATD)
Old 23rd August 2016, 12:54   #404  |  Link
VS_Fan
I was trying to remember what's the purpose of using SATD in mvtools, so I googled a little, and found: I couldn't find much more.
And then I thought: if people at VideoLAN / MulltiCoreWare implemented the asm functions for SATD for x265? Could they be used? As I’m not a developer, I can't answer that question. Is this a possibility?
In the search I saw things like:
[x265] [PATCH] primitives: asm: update: implementation of satd(sse2)
[x265] [PATCH] primitives: asm: satd: fix for 32 bit issue
Could those be used for mvtools-VapourSynth ???
VS_Fan is offline   Reply With Quote
Old 23rd August 2016, 13:30   #405  |  Link
feisty2
I'm Siri
feisty2's Avatar
No, because stupid asm fixed SATD to a certain bitdepth(say, 8bits)
That's exactly why asm SATD functions from avisynth mvtools are useless
Old 23rd August 2016, 15:16   #406  |  Link
feisty2
I'm Siri
feisty2's Avatar
there are several approaches available to calculate the difference between 2 macroblocks.
1. SAD, sum of the absolute difference between each pair of samples
2. dct=1, transform both current block and the reference block to frequency domain, and calculate the sum of the absolute difference between each pair of transformed samples
3. SATD, get the difference block between 2 macroblocks, and transform that difference block to frequency domain and calculate the sum of the absolute value of each sample in that transformed difference block
basically, dct=5(SATD) is the compromise between dct=0(SAD) and dct=1(frequency domain SAD)
Old 23rd August 2016, 21:19   #407  |  Link
VS_Fan
Let me rephrase my thought: In the same search at videolan, I though I saw 8, 10 (may be 12) bit_depth sse2 and/or avx optimizations for SATD calculation.
My question is then: No matter what the original video clip bit_depth is, could you use a “simplified” 8, 10 or 12 bit temporary version of the clip for the motion estimation? (reusing the x265 SATD asm optimizations)
Edit: By the way, thanks for the explanation
Old 23rd August 2016, 21:22   #408  |  Link
Nevilne
You will actually get more useful motion estimation from even blurring the search clip.
Doesn't stop people here from doing stuff like nnedi for subpixel clips.
Nevilne is offline   Reply With Quote
Old 23rd August 2016, 21:33   #409  |  Link
jackoneill
unsigned int
jackoneill's Avatar
I considered it, but: http://forum.doom9.org/showthread.ph...61#post1695761
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline   Reply With Quote
Old 23rd August 2016, 21:43   #410  |  Link
feisty2
I'm Siri
feisty2's Avatar
SATD is a pretty simple transform and not hard to program at all...
Why not just re-program it in c/c++ like I did and it would be generic to all sample types
Old 23rd August 2016, 22:24   #411  |  Link
VS_Fan
Originally Posted by cretindesalpes View Post
Don’t waste your time at this, moreover it would be misleading. We can explicitly convert the high-bitdepth clips to 8 bits for analysis. Anyway, I think there is a definite benefit to run the analysis on 10–12 bits. I often remap the luma channel to increase the contrast is some specific ranges (generally the dark parts), and keeping 8 bits crunches other ranges, reducing the accuracy of the analysis on fine textures.
I hope you can come up with a neat strategy to deal with SATD.
I congratulate and thank you all for the VapourSynth's 5th birthday!!! 2 days in advance
Old 25th August 2016, 17:45   #412  |  Link
kolak
Would anyone consider making mvtools faster and better as a paid project?
Old 25th August 2016, 17:57   #413  |  Link
feisty2
I'm Siri
feisty2's Avatar
I assume you're that "anyone" since you're the only one that has ever asked about this..
jackoneill's wishlist
edit:typo
Old 25th August 2016, 18:26   #414  |  Link
kolak
Are these ebooks?
I will buy all of them+ many more
Old 25th August 2016, 18:33   #415  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Which parts faster? Which parts better? Better in what way?
Yes, ebooks.
Old 26th August 2016, 01:31   #416  |  Link
kolak
I'm mainly interested in frame rate interpolation part.
There would be quite specific problems to "solve" as well as speeding up whole conversion process, ideally by about 2x.
I will send you pm.
Old 17th September 2016, 10:43   #417  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Originally Posted by feisty2 View Post
good news and bad news here
I fixed the SATD functions. Please test: http://savedonthe.net/download/914/v...atd-win64.html
Old 17th September 2016, 15:02   #418  |  Link
feisty2
I'm Siri
feisty2's Avatar
it works, but the result looks slightly different from my implementation
mine looks closer to dct=1, and yours closer to dct=0 (set thSAD to 10000 in MDeGrain and you will see the difference)
not sure why..
Old 17th September 2016, 17:00   #419  |  Link
jackoneill
unsigned int
jackoneill's Avatar
not sure why..
It's the same code used by MVTools for Avisynth and x264.
Old 23rd October 2016, 15:47   #420  |  Link
jackoneill
unsigned int
jackoneill's Avatar
v17 brings more speed for certain configurations, larger blocks, and a bug fix or two: https://github.com/dubhater/vapoursy...leases/tag/v17
   * Analyse, Recalculate: Fix bug that broke 16 bit processing (patches by feisty2).
   * Analyse, Recalculate: Support block sizes of 64x32, 64x64, 128x64, and 128x128.
   * Analyse, Recalculate: Make dct=1..4 a bit faster on x86.
   * FlowFPS, FlowInter: Add AVX2 code.
   * Analyse, Recalculate: Fix SATD functions used when dct=5..10 and the input is 16 bit.
   * Analyse, Recalculate: Allow dct=5..10 with blocks larger than 16x16.
