Old 3rd October 2019, 16:29   #3441  |  Link
clsid
Most likely a problem with the NVIDIA driver.
Old 3rd October 2019, 18:45   #3442  |  Link
bigboyman
Wouldn't that make it more prevalent over a range of files instead of a single batch? Dumping file info in case it helps.
Filter : LAV Video Decoder - CLSID : {EE30215D-164F-4A92-A4EB-9D4C13390F9F}
- Connected to:
CLSID: {B98D13E7-55DB-4385-A33D-09FD1BA26338}
Filter: LAV Splitter Source (internal)
Pin: Video
- Connection media type:
Video: HVC1 1404x1080 (58:45) 29.97fps
AM_MEDIA_TYPE:
majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71}
subtype: Unknown GUID Name {31435648-0000-0010-8000-00AA00389B71}
formattype: FORMAT_MPEG2_VIDEO {E06D80E3-DB46-11CF-B4D1-00805F6CBBEA}
bFixedSizeSamples: 0
bTemporalCompression: 1
lSampleSize: 1
cbFormat: 255
VIDEOINFOHEADER:
rcSource: (0,0)-(1404,1080)
rcTarget: (0,0)-(1404,1080)
dwBitRate: 0
dwBitErrorRate: 0
AvgTimePerFrame: 333667
VIDEOINFOHEADER2:
dwInterlaceFlags: 0x00000000
dwCopyProtectFlags: 0x00000000
dwPictAspectRatioX: 58
dwPictAspectRatioY: 45
dwControlFlags: 0x00000000
dwReserved2: 0x00000000
MPEG2VIDEOINFO:
dwStartTimeCode: 0
cbSequenceHeader: 123
dwProfile: 0x00000001
dwLevel: 0x00000096
dwFlags: 0x00000004
BITMAPINFOHEADER:
biSize: 40
biWidth: 1404
biHeight: 1080
biPlanes: 1
biBitCount: 12
biCompression: HVC1
biSizeImage: 2276640
biXPelsPerMeter: 0
biYPelsPerMeter: 0
biClrUsed: 0
biClrImportant: 0
pbFormat:
0000: 00 00 00 00 00 00 00 00 7c 05 00 00 38 04 00 00 ........|...8...
0010: 00 00 00 00 00 00 00 00 7c 05 00 00 38 04 00 00 ........|...8...
0020: 00 00 00 00 00 00 00 00 63 17 05 00 00 00 00 00 ........c.......
0030: 00 00 00 00 00 00 00 00 3a 00 00 00 2d 00 00 00 ........:...-...
0040: 00 00 00 00 00 00 00 00 28 00 00 00 7c 05 00 00 ........(...|...
0050: 38 04 00 00 01 00 0c 00 48 56 43 31 20 bd 22 00 8.......HVC1 ".
0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0070: 00 00 00 00 7b 00 00 00 01 00 00 00 96 00 00 00 ....{.......–...
0080: 04 00 00 00|01 01 40 00 00 00 00 00 00 00 00 00 ......@.........
0090: 96 f0 00 fc fd f8 f8 00 00 47 03 20 00 01 00 19 –...G. ....
00a0: 40 01 0c 01 ff ff 01 40 00 00 03 00 00 03 00 00 @....@........
00b0: 03 00 00 03 00 96 84 30 24 21 00 01 00 35 42 01 .....–„0$!...5B.
00c0: 01 01 40 00 00 03 00 00 03 00 00 03 00 00 03 00 ..@.............
00d0: 96 a0 02 c0 80 11 07 72 e5 84 3b 90 94 41 0f 55 – .€..r„;”A.U
00e0: 55 55 43 ff 00 28 00 27 01 00 00 03 03 e9 00 00 UUC.(.'.......
00f0: 75 30 08 22 00 01 00 07 44 01 c0 f7 c0 cc 90 u0."....D.̐
SW:
Windows 10
MPC-HC (latest)
LAV Video, Audio, Splitter
madVR, EVR (CP), ...
XYsub, ASS, VobSub, ...
HW:
i7-6700HQ @ 2.60 GHz
GTX 960M (4 GB)
16 GB DDR4 RAM
1TB HDD + 128GB SSD
bigboyman is offline   Reply With Quote
Old 3rd October 2019, 19:28   #3443  |  Link
clsid
That video has an uncommon resolution. Plus the encoding settings of the video can be very different between files.
Start by updating to the latest version of MPC-HC. Then update the NVIDIA driver.
Old 3rd October 2019, 22:21   #3444  |  Link
bigboyman
Did that but still no luck. What else?
SW:
Windows 10
MPC-HC (latest)
HW:
GTX 960M (4 GB)
16 GB DDR4 RAM
1TB HDD + 128GB SSD
Old 4th October 2019, 15:09   #3445  |  Link
clsid
Send me a private message with a link to one of those files that has issues.
Old 21st July 2020, 13:23   #3446  |  Link
Faiakes
Video blinks (black frames?) when not on top (with MPC Video Renderer)
This is not happening on every video.
It does not happen with EVR-CP.
This is my current setup:
MPC-HC (Nightly, 64-bit)
Build information:
    Version:            1.9.6.28 (e518e401c)
    Compiler:           MSVC v19.26.28806
    Build date:         Jul 10 2020
LAV Filters:
    LAV Splitter:       0.74.1.64
    LAV Video:          0.74.1.64
    LAV Audio:          0.74.1.64
    FFmpeg compiler:    MinGW-w64 GCC 9.3.0
Operating system:
    Name:               Windows NT 10.0 (build 20170)
    Version:            10.0 (64-bit)
Hardware:
    CPU:                Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz
    GPU:                Intel(R) HD Graphics 620 (driver version: 27.20.100.8425)
Here's one file it happens with:
Format                      : Matroska
Format version              : Version 4
File size                   : 1.91 GiB
Duration                    : 30 min 7 s
Overall bit rate mode       : Variable
Overall bit rate            : 9 054 kb/s
Encoded date                : UTC 2020-07-20 04:01:56
Writing application         : mkvmerge v48.0.0 ('Fortress Around Your Heart') 64-bit
Writing library             : libebml v1.4.0 + libmatroska v1.6.0
Video
Format                      : AVC
Format/Info                 : Advanced Video Codec
Format profile              : Main@L4
Format settings             : CABAC / 4 Ref Frames
Format settings, CABAC      : Yes
Format settings, Reference  : 4 frames
Codec ID                    : V_MPEG4/ISO/AVC
Bit rate mode               : Variable
Bit rate                    : 8 668 kb/s
Maximum bit rate            : 12.4 Mb/s
Width                       : 1 920 pixels
Height                      : 1 080 pixels
Display aspect ratio        : 16:9
Frame rate mode             : Constant
Frame rate                  : 29.970 (30000/1001) FPS
Color space                 : YUV
Chroma subsampling          : 4:2:0
Bit depth                   : 8 bits
Scan type                   : Progressive
Bits/(Pixel*Frame)          : 0.139
Stream size                 : 1.82 GiB (96%)
Language                    : English
Default                     : Yes
Forced                      : No
Audio
Format                      : AC-3
Format/Info                 : Audio Coding 3
Commercial name             : Dolby Digital
Codec ID                    : A_AC3
Bit rate mode               : Constant
Bit rate                    : 384 kb/s
Channel(s)                  : 2 channels
Channel layout              : L R
Sampling rate               : 48.0 kHz
Frame rate                  : 31.250 FPS (1536 SPF)
Compression mode            : Lossy
Stream size                 : 82.8 MiB (4%)
Language                    : English
Service kind                : Complete Main
Default                     : Yes
Forced                      : No
Text
Format                      : UTF-8
Codec ID                    : S_TEXT/UTF8
Codec ID/Info               : UTF-8 Plain Text
Duration                    : 29 min 47 s
Bit rate                    : 129 b/s
Count of elements           : 1150
Stream size                 : 28.2 KiB (0%)
Title                       : English (SDH)
Language                    : English
Default                     : No
Forced                      : No
Faiakes is offline   Reply With Quote
Old 21st July 2020, 15:34   #3447  |  Link
clsid
For MPC Video Renderer bugs you need to go here:
https://github.com/Aleksoid1978/VideoRenderer
Old 21st July 2020, 22:07   #3448  |  Link
Faiakes
Thanks
Old 25th July 2020, 22:10   #3449  |  Link
Ejziponken
What the difference between HC and BE? Any reason to pick one over the other?
Playing mostly 4k HDR movies with madVR and LAV.
Ejziponken is offline   Reply With Quote
Old 26th July 2020, 07:10   #3450  |  Link
Klaus1189
Differents projects. MPC VR is developed by MPC-BE devs.
Old 2nd April 2021, 17:58   #3451  |  Link
Katie Boundary
Katie Boundary's Avatar
One is still updated and the other isn't.
I ask unusual questions but always give proper thanks to those who give correct and useful answers.
Katie Boundary is offline   Reply With Quote
Old 2nd April 2021, 21:50   #3452  |  Link
butterw2
Originally Posted by Remicade View Post
Wsat is the difference between MPC HC and MPC BE ???
From page1 (13th December 2012), some questions never get old it seems.
Current mpc-hc development: https://github.com/clsid2/mpc-hc
butterw2 is offline   Reply With Quote
Old 2nd April 2021, 22:32   #3453  |  Link
LigH
LigH's Avatar
Also read on: MPC-HC 1.9.x+
New German Gleitz board
Old 22nd February 2024, 14:25   #3454  |  Link
stelfex
Hi, could you tell me the cause of the slowdowns when I go to check my MP3? I leave you an explanatory video. HI
https://www.mediafire.com/file/jm3ki...e_mp3.mp4/file
stelfex is offline   Reply With Quote
dxva, media player classic, mpc, mpc-hc
