Old 22nd November 2022, 17:20   #41  |  Link
kedautinh12
Don't up attach file here, you will waiting moderator approval forever
Old 22nd November 2022, 21:30   #42  |  Link
color
color's Avatar
Ah, that explain some things.
Automatic Colorization
color is offline   Reply With Quote
Old 23rd November 2022, 09:30   #43  |  Link
color
color's Avatar
Originally Posted by VoodooFX View Post
You are even more hardcore than me, InpaintDelogo has zillion possible combinations of the parameters to make some specific frame look better.
Look, Inpaint [adjusted] vs Deblend:
How did you get deblend so good? Can you share the script?
Old 24th November 2022, 06:04   #44  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Sry for the late answer, I used personal "dev" version, didn't had time for a public release yet, expect it sooner than later...
VoodooFX is offline   Reply With Quote
Old 24th November 2022, 17:36   #45  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
On that frame I used something like this [you need to get v3.4 for it to work]:
LWLibAvVideoSource("D:\output.mkv")
Trim(500,11363)
InpaintDelogo(mask="D:\mask.bmp", Loc="1388,944,-280,-24", Mode="Deblend", Analyze=3, Interp=3, IntSpd=4, Optimize=1, dPP=-5, Greyscale=1)
Or you can download ebmp: https://we.tl/t-BSOqlnl5By
You can use ebmp like this:
InpaintDelogo(mask="D:\UCLA.ebmp", Loc="1388,944,-280,-24", Interp=3, IntSpd=4, Optimize=1, dPP=-5, Greyscale=1)
Old 25th November 2022, 09:32   #46  |  Link
color
color's Avatar
Trim(500,11363)
I did update to your new script as well. Thank you.
avisynth, virtualdub
