#1 | Link |
Firefox Addons
EDIT: Thread name changed from TextArea Cache to FireFox Addons
TextArea Cache Hi guys, just a recommendation here for Firefox addon "TextArea Cache", First time I've had to use it and saved me about 20->30 minutes of repeated searching to re-write post after accidental deletion. I had several different threads open on D9, and accidentally went back to previous page on the wrong tab, result: about 20 to 30 minutes of searching/writing lost. I clicked on the TextArea Cache tool icon, and it was there just like it was before deletion, this is defo gonna be staying on all my machines, it was there just when I needed it. It saves copy of text edit boxes of fireFox. [you can give list of websites not to cache eg your on-line banking] Saved my bacon, perhaps do same for you one day. ![]() EDIT: https://addons.mozilla.org/en-GB/fir...extarea-cache/ Also available for Chrome:- https://chrome.google.com/webstore/d...hcmnbmab?hl=en [not sure if above link will work(may have re-directed to another page), for me it shows correctly that I dont have Chrome installed, so cannot install addon] reviews (2nd link has two alternative addons, but I'm happy with this one): https://www.ghacks.net/2019/03/03/ne...extarea-cache/ https://www.raymond.cc/blog/saving-w...our-compouter/ EDIT: You can set it to Not Allow to run in Private Windows (is FireFox controlled Default [unless you changed Firefox default], eg when banking), I have about a couple of dozen entries all automatically saved since yesterday (I updated firefox yesterday so none before that, probably for that reason, think it is auto set for 7 day recall).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 11th November 2019 at 20:46. |
#3 | Link |
Before NEW [only NEW] install of a FireFox addon, clear out your temp folder eg
C:\Users\MyUserName\AppData\Local\Temp\ and just before clicking OK on final (2nd) "Add to FireFox" type alert, look in temp folder, and copy the XPI file, give it another name instead of eg "xya080adas.xpi" and archive so you can install on another machine (also handy so as to have all addons available without having to search for them). then can Update as required. [Can use Firefox "Install Add-on From File" on the Updates drop down menu, can group select & bulk install many xpi's at once]. Will not be in TEMP folder on subsequent updates, first install only. (XPI will sometimes be removed from TEMP after install, but not always) filler56789, You could delete the addon, and new install again should make it available in TEMP folder. EDIT: Just found this one too, DarkReader:- https://addons.mozilla.org/en-GB/fir...on/darkreader/ DOCS:- https://darkreader.org/help/en/ First post of this thread using DarkReader [click on thumbnail, then click on larger image to show full size] ![]() EDIT: Should help squeeze a little more battery life out of my Tablet/Laptop thingy [I get about 7/8 hours anyway] ![]()
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 2nd January 2020 at 21:58. |
#5 | Link |
Yep, and here an example with an image, ie colorbars [from Wonkey_Monkey WaveForm thread]:
![]() EDIT: I guess if you have any recommendations for Add-ons [particularly if useful on the D9], you can post them here. I've renamed thread to FireFox Addons. EDIT: And whereas above image is indirect from PostImage.org, below Attachment on Doom9 [FranceBB post in nfv thread Proper PAL Video(not film) to NTSC conversion] ![]() Chopped some off just to get FranceBB name in picture [you know how he likes to see his name in print ![]()
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 11th November 2019 at 20:30. |
#6 | Link | ||
cosmic entity
Good Article..
https://www.dedoimedo.com/computers/...ars-later.html this one caught my eye... Absolute Enable Right Click & Copy Quote:
#7 | Link |
Cheers Beta13, keep em coming
#8 | Link | |
ангел смерти
![]() Join Date: Nov 2004
![]() Heck, maybe enabling that is all the extension does. |
#9 | Link |
All that there about:config stuff is a bit obscure, maybe somebody should do an addon to make em all an easy config app.
[with one line of explanation for each opt, maybe, and link to better explanation, maybe exists already].
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 1st December 2019 at 17:18. |
#10 | Link | |
I was also a long time user of various "hecking" addons. For old firefox i was using Lazarus form recovery. For now, WebExt i use Form history control II, easy to recover forum posts and forms or any input. I was also using right to click, Nowaday replacement Right click to copy is essential one ![]() Somehow easy to bring back closed tabs is thanks to Undo closed Tabs Button by clicking on top bar button instead of going through menus. I use Flagfox for easy identyfiyng site whois, coutry registration flag, alexa (for admins ![]() Greasemonkey is powerful addon. I used to use many many scripts in old days. My beloved was YT age bypass verification, now i omit this restriction by the other way. But my main script now is Google Search Extra Buttons and some antimalware, antiads. One of fancy addons category is Link Alert. My newest addon is Enhancer for Youtube. First of first it is compatible all the time. I use mainly for custom default resolution. Flying videoplayer window is another fancy feature. I very most miss Tab Mix Plus. The existing webextension is just template. C'mon mozilla guys, how i cannot set tabs in the rows by normal option...? J.. just why? BTW, i already enabled Webrenderer in about:config, which is not yet official ready for intel on battery, however im happy with it. OMG. Thanks to this thread i found another awsome extension is back! Its DownThemAll. After all that drama, its Great!, installing now, looking for DTA Anti Container. Last edited by littleD; 1st December 2019 at 23:07. |
#11 | Link | |
Broadcast Encoder
A a side note, I made my first documentary for the company I work for which has been released both on the big screen and on TV, so I'm finally gonna be credited on IMDB for the very first time, which for me it's the perfect Christmas Present and a thing I've been waiting for my whole life (not that my life is long, though xD). Anyway, back on the topic, I like the extension you suggested and it could have saved me several times, especially 'cause I do many other things while I post on Doom9 and sometimes the browser crashed or I closed the wrong tab or I made some other boo boo 'cause it was early in the morning and I needed coffee xD The good thing is that thanks to you and TextArea Cache that's not gonna happen again. ![]() |
#12 | Link | |
Me also likes FlagFox, and User Agent Switcher, and usually have several FlashBlock type addons.
Image Block X also is handy [block all images, easy on/off toggle]. Name on IMDB, fame indeed ![]() Keep em comin'. EDIT: Got about 4, "Print To PDF" type addons, none of them bullet proof [sometimes fail or lousy output]. EDIT: For those of you with delicate sensibilities ![]() Quote:
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 4th December 2019 at 16:03. |
#13 | Link |
SiteDelta Watch:- https://addons.mozilla.org/en-GB/fir...ch/?src=search
Suggested in PM by nji, I did say that he should maybe post here, but he has not done so, so I have. Can enable for a web page and shows differences since last visit, see what edits people have made since last visit. Perhaps of use to some, although I usually am satified with the "Todays Posts" option on the drop down "Quick Links" item. EDIT: TextAreaCache (first post) has recently saved me about 3 or four more times, I'm very happy with it.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 3rd January 2020 at 03:18. |
#14 | Link |
@StainlessS
You might like these two https://addons.mozilla.org/en-US/fir...ox/?src=search https://addons.mozilla.org/en-US/fir...17/?src=search Last edited by gonca; 3rd January 2020 at 00:01. |
#15 | Link |
Thanks gonco, I already have PrivacyBadger, but not the AnonymoX, I will not be using AnonymoX, because the "Guideline For Proper Use" page comes up as
"Secure Connection Failed" which is a FireFox non overrule-able error, ie cannot view it (also, I'm a bit wary of Proxies).
#16 | Link |
This is not a firefox addon, but is a firefox tweak to restore old behaviour for the HTTPS padlock on address bar
(used to be green but is now grey - a bit disconcerting to not know why its now grey) From GHacks.net [how-to-restore-the-green-lock-icon-in-firefoxs-address-bar] https://www.ghacks.net/2019/10/28/ho...s-address-bar/ or simply Code:
Restore the Firefox green HTTPS security lock color to green Making Firefox`s padlock icon green again 1 Load about:config in the Firefox address bar. 2 Confirm that you will be careful if a warning screen is displayed. 3 Use the search at the top to find security.secure_connection_icon_color_gray. 4 Toggle the preference so that its value is FALSE. Restoring Extended Validation Certificate information in Firefox 1 Visit the about:config page again. 2 Search for security.identityblock.show_extended_validation this time. 3 Set the preference to TRUE to enable the display of extended validation information in the browser's address bar. Display "Not Secure" for sites that don't use HTTPS 1 Visit about:config in the Firefox address bar. 2 Search for security.insecure_connection_text.enabled. 3 Set the value of the preference to TRUE to enable "not secure" or FALSE to disable it. Bonus: If you want to apply the change to private browsing connections as well, search for security.insecure_connection_text.pbmode.enabled and set the value accordingly. Also,for those wanting to test out security for 1) Firewall 2) ISP port blocking 3) HTTPS Interception Detection (are you being spied upon by your ISP, school, employer, even when banking, passwords etc) see GRC.Com [Gibson Research, by Steve Gibson, author of SpinRite - been visiting this site for years]. EDIT: Microsoft sells a proxy (cant remember the name) whose specific job is to spy upon a companies employees, my mate is a sys admin who does not dare use company provided desktops/laptops/phones etc for anything that needs [EDIT: personal] security/privacy. (He even switches off his company provided phone after work so that they dont know where he is, big prestigious UK corporation, offices in [I think] 70+ countries, spies on everything) EDIT: 3) above, is another check for the proxy spy thing that the green security lock of FireFox is for. MicroSoft's Internet Explorer [and presumably Edge] do not have the security lock thing, as it would expose the use of their despicable proxy whotsit and they like to keep it secret from users to maintain their subterfuge [when you 'squirt' down someones leg, its best to tell them its raining].
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 28th February 2021 at 14:20. |
addon, browser, firefox |
