Old 14th January 2012, 13:36   #1  |  Link
mikewando
Dehalo on text
There are several instances of pretty blatant halos around text (mostly credits, but some text creeps up throughout the episodes too) in this source (there is some haloing on other parts of the source, but nothing as blatant, nor would I suspect as easy to fix, so for now I'm just focusing on the text):
Halo: http://i.imgur.com/PZwer.png
Blurred: http://i.imgur.com/Mm6oL.png
The second image is a simple blur(1.2) which does a better job at hiding the halos than any of the various dehalo filters I found lying around, but of course it destroys a lot of detail in more complicated scenes, and even on some of the kanji themselves. I tried preventing the more detailed parts of scenes, and scenes without text from being affected by throwing together a quick mask, but I don't really (obviously) have much experience trying to mask things off:
halod = last
dhalod = halod.blur(1.2)
mask = halod.mt_edge(mode="laplace", thY1=30, thY2=30).averageblur(radY=5).mt_binarize(0)
mt_merge(halod, dhalod, mask)
The result of this is pretty good for my purposes. The idea is that this will find the places with really high luma differences (white text on dark background), expand the area to include the halos, and replace that portion with the blurred portion.
Besides blurring the kanji (since I couldn't really think of a good way to expand just the edges of the mask) it doesn't take into account changes to the mask over time so sometimes as the background moves behind the text, portions of the text will flicker between halo'd and blurred.
So I was wondering if anyone could think of some ways to improve on this idea. Basically better ways to detect the white text, expand the edges of the mask so it covers just the halos, and prevent the mask from popping in and out.
mikewando is offline   Reply With Quote
Old 21st January 2012, 17:02   #2  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
What if you try DeHalo_alpha() and sharpen back afterwards ?
This is what I use sometimes.
You got to vary rx and ry to fit your source of course.
#   --------------------------------------------Start of DeHaloing------------------------------
#BlindDeHalo3(rx=3.2,ry=1.5) # or
DeHalo_alpha(rx=3.0, ry=2.5, darkstr=1.2, brightstr=1.0, lowsens=50, highsens=50)#gets rid of medium sharpening halos
#   function DeHalo_alpha(clip clp, float "rx", float "ry", float "darkstr", float "brightstr", float "lowsens", float "highsens", float "ss")
#   rx = default( rx, 2.0 )#xradius for Halo removal 1.0...2.0...3.0 Set as low as possible. If set too high, it will start missing small spots.
#   ry = default( ry, 2.0 )#yradius for Halo removal 1.0...2.0...3.0 Set as low as possible. If set too high, it will start missing small spots.
#   darkstr = default( darkstr, 1.0 )#0.0..1.0 The strength factors for processing dark and bright halos. Default 1.0 both for symmetrical processing. <0.0 and >1.0 possible.
#   brightstr = default( brightstr, 1.0 )#0.0..1.0 On Comic/Anime, darkstr=0.4~0.8 sometimes might be better ... sometimes. In General, the function seems to preserve dark lines rather good.
#   lowsens = default( lowsens, 50 )#0..50..100 Sensitivity settings, not that easy to describe them exactly ... in a sense, they define a window between how weak an achieved effect has to be
#   highsens = default( highsens, 50 )#0..50..100 to get fully accepted, and how strong an achieved effect has to be to get fully discarded. Defaults are 50 and 50 ... try and see for yourself.
#   ss = default( ss, 1.5 )#1.0..1.5..Supersampling factor, to avoid creation of aliasing.
#   --------------------------------------------End of DeHaloing--------------------------------
Followed by one of these sharpeners:
LSFmod (moderate and nice)
SSSharp2 (slow and more ringing, but sometimes very helpful, depending on nature of source)
MedSharp2(veryslow, but awesome)
"Data reduction ? Yep, Sir. We're working on that issue. Synce invntoin uf lingöage..."
dehalo, masks, text
