Old 3rd March 2010, 03:44   #1  |  Link
moozooh
HQ deinterlacer recommendations/comparisons?
Hi. I've been doing some research on deinterlacing and found myself unable to understand the difference between the filters labeled as high quality (MVBob, MCBob, etc.). I mean there certainly is some difference, but it's hard for me to compare because I'm not well-familiar with deinterlacing artifacts so I can't really tell which of them restores better.
So the questions are:
1) how do the high quality full-framerate (i.e., no framerate conversion) deinterlacers compare to each other? What's the main difference between them?
2) Which would be the one recommended to use if processing speed was completely disregarded (e.g., max possible quality)?
3) Is there a chance for a quick comparison table like the one found in this thread?
Thank you.
moozooh is offline   Reply With Quote
Old 3rd March 2010, 10:04   #2  |  Link
Terka
2) tgmc
3) do yourselves
Terka is offline   Reply With Quote
Old 3rd March 2010, 11:46   #3  |  Link
moozooh
Originally Posted by Terka View Post
2) tgmc
Alright, thank you.
I tried to locate the most recent version of TGMC, but the only version I managed to find online is "something point something, beta-2" (sic). The homepage is down, too — maybe it's worth noting that the AviSynth wiki has a number of broken links like that.
3) do yourselves
I wouldn't trust myself with something I have no methodology for, and I expect neither would you.
Old 3rd March 2010, 12:30   #4  |  Link
Didée
That's right. "Something-point-something, beta-2" indeed is the most recent version.
I havn't ever set up a real homepage (the top page is this, since day one), because I didn't want to maintain one. I've only ever used it as a "drop box". At some point in time, Arcor changed the service so that it doesn't allow to automatically display folder content. Hence, links that just point to the subfolders don't work anymore. Direkt links to files still do work, though.
Example: TempGaussMC_beta2, directly linked from my 'not-a-homepage'.
Old 3rd March 2010, 15:56   #5  |  Link
moozooh
I see, thank you.
I've been encoding video since about 2004, but I haven't really had any first-hand experience with interlaced content (I mainly captured or transcoded progressive content until recently). I will do some testing and see if I can come up with anything of public use.
Old 4th March 2010, 01:25   #6  |  Link
hydra3333
Hello, http://avisynth.org/mediawiki/TempGaussMC "There seems to be a TempGaussMC_beta1u MVtools2 version, as at 3 Nov 2009, in common use even by Didee, possibly the latest version at http://forum.doom9.org/showthread.ph...12#post1340412 - tempgaussmc_beta1u seems to allow nnedi2 whereas the main ones pointed to in this wiki don't. "
I wonder if thsi is "right" and which version is Didee's favourite.
conversion, deinterlacing, framerate
