Old 25th November 2008, 00:45   #1  |  Link
rufsiany
fast motion
What is the a good/easiest way of creating fast motion with Avisynth? I have an 1 hour video of the office interior taken from the tripod and want to speed it up to e.g 20seconds. I can do it in VirtualDub: menu -> Video -> Frame Rate -> (Change frame rate to (fps): 10000. Convert to fps: 25). But I would rater do it entirely within avisynth script. AssumeFPS()? ChangeFPS()?, ConvertFPS()? Which one to use? The doc. is rather vague on their purposes.
Thanks
rufsiany
rufsiany is offline   Reply With Quote
Old 25th November 2008, 00:59   #2  |  Link
linyx
Un-Registered User
linyx's Avatar
Say your source is 30 fps then AssumeFPS(60) would play it at 2x speed. So a few calculations should give you what you need.
linyx is offline   Reply With Quote
Old 25th November 2008, 02:51   #3  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Right. Then changeFPS to decimate it down to your final frame rate. (30?)
~MiSfit
Old 25th November 2008, 02:59   #4  |  Link
linyx
Un-Registered User
linyx's Avatar
@Blue_MiSfit
Good idea. Never thought to change the framerate down again.
Old 29th November 2008, 20:11   #5  |  Link
PeaceAnt
also known as GrassHoppeR
selectevery(100) gives you 100x speedup
pozdrawiam
PeaceAnt is offline   Reply With Quote
avisynth, fast, framerate, motion
