Old 28th December 2021, 05:49   #121  |  Link
CaptainGotoSV2
Originally Posted by kedautinh12 View Post
Are you download latest ver tdeint???
https://github.com/pinterf/TIVTC/releases
Yeah I did ages ago, I have resolved the problem though, you need to enter an integer in precision e.g. precision=4.
In regards to the credit sequence, I'm too green at AviSynth to make heads or tails of how to get the script to pump out a VFR video, and my attempts to just blend the credits with credconv after normconv from 25fps to 23.976fps aren't working - either the next episode preview is cut or somehow I manage to slow down rendering of the entire video.
CaptainGotoSV2 is offline   Reply With Quote
Old 28th December 2021, 06:24   #122  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Avisynth supports only CFR, for VFR you need some timecode manipulation in the container so the player knows which parts to play at which speed.
Old 28th December 2021, 06:34   #123  |  Link
CaptainGotoSV2
I kinda gave up on VFR, I'm wanting to blend the credits instead, here's my script
global MeGUI_darx = 4
global MeGUI_dary = 3
LoadPlugin("C:\Users\***\Downloads\MeGUI-2913-32\tools\dgindex\DGDecode.dll")
DGDecode_mpeg2source("D:\EVANGELION_PLATINUM_V1\VIDEO_TS\VTS_01_1.d2v", info=3)
LoadPlugin("C:\Users\***\Downloads\MeGUI-2913-32\tools\avisynth_plugin\ColorMatrix.dll")
ColorMatrix(hints=true, threads=0)
AnimeIVTC(mode=2, ediandnn=3, bbob=1, i1=33020, e1=34651, i2=34652, e2=35054, normconv=true, credconv="blend", )
Toon()
mcdaa3()
My problem is after that, playing the resulting footage in AvsPmod is slowed down to a trickle
Old 28th December 2021, 10:32   #124  |  Link
kedautinh12
Cause you use many scripts. Try prefetch can improve your speed
Old 28th December 2021, 19:10   #125  |  Link
CaptainGotoSV2
i'm only using AnimeIVTC, mcdaa and Toon though, that's not all that many. That aside, enabling "blend" in credconv blends the whole video, not just credits
Old 29th December 2021, 00:22   #126  |  Link
kedautinh12
You think AnimeIVTC + mcdaa don't load any plugins, scrips inside?? And you try prefetch with (2->...) you can see it's different
anime aa, animeivtc, chroma fix, deinterlace, mod
