Old 8th November 2022, 10:41   #41  |  Link
tormento
Acid fr0g
tormento's Avatar
Of course there are downmix functions and also upmix functions.
Did you ever try to understand how good is DEE downmix function?
@turment on Telegram
Old 8th November 2022, 12:46   #42  |  Link
tebasuna51
tebasuna51's Avatar
DEE ddp Downmix
7.1 -> 5.1 Something like:
FL' = 0.54*FL
FR' = 0.57*FR
FC' = 0.64*FC
LF' = 1.00*LF
SL' = 0.4*SL + 0.4*BL
SR' = 0.4*SR + 0.4*BR
7.1 -> 2.0 Something like:
FL' = 0.54*FL + 0.45*FC + 0.34*SL + 0.33*BL [1.66 clip risk]
FR' = 0.48*FR + 0.45*FC + 0.30*SR + 0.34*BR [1.57 clip risk]
5.1 -> 2.0 Something like:
FL' = 0.54*FL + 0.38*FC + 0.47*SL [1.39 clip risk]
FR' = 0.48*FR + 0.38*FC + 0.46*SR [1.32 clip risk]
Old 30th November 2022, 21:34   #43  |  Link
pandy
This triggered my curiosity - isn't feasible to use SOFA filter https://ffmpeg.org/ffmpeg-filters.html#sofalizer to downmix 7.1 (up to 9 channels) to 2 channel? Of course some synthetic SOFA file can be used if HRTF is unwanted.
pandy is offline   Reply With Quote
Old 1st December 2022, 00:46   #44  |  Link
richardpl
Can use headphone filter, and also afir filter in casea impulse response files are really big.
richardpl is offline   Reply With Quote
Old 4th February 2023, 17:28   #45  |  Link
tebasuna51
tebasuna51's Avatar
1) If your input is 7.1, first do a 7.1 -> 5.1 downmix with the compand selected (see precedent posts):
-filter_complex "asplit [f][s]; [f] pan=3.1|c0=c0|c1=c1|c2=c2|c3=c3 [r]; [s] pan=stereo|c0=0.5*c4+0.5*c6|c1=0.5*c5+0.5*c7, compand=attacks=0:decays=0:points=-90/-84|-8/-2|-6/-1|-0/-0.1, aformat=channel_layouts=stereo [d]; [r][d] amerge [a]" -map "[a]"
WARNING: when use these filters with a recent ffmpeg v5.1 there are a regression detected.
Use a ffmpeg v4.4 until the regression was solved.
Old 9th February 2023, 23:34   #46  |  Link
tebasuna51
tebasuna51's Avatar
The regression detected is not fixed.
I open a new one
Old 11th February 2023, 16:10   #47  |  Link
Selur
Selur's Avatar
Confused, according to your link:
Status: new → closed
Fixed in 93a9ee7afd7bf2e019490117f1bada30724a0200
Old 12th February 2023, 12:55   #48  |  Link
tebasuna51
tebasuna51's Avatar
It is not fixed, now do other remix unwanted, see the image in the new one.
Old 19th February 2023, 22:43   #49  |  Link
Balling
Fixed now.
Balling is offline   Reply With Quote
Old 21st February 2023, 12:39   #50  |  Link
tebasuna51
tebasuna51's Avatar
I test the Latest Auto-Build (2023-02-20 12:35) in https://github.com/BtbN/FFmpeg-Builds/releases
Seems work correctly now:
1) 7.1 -> 5.1 downmix with the compand selected (see precedent posts):
There are two 'green messages':
[Parsed_pan_1 @ 000001fc795c1d80] Pure channel mapping detected: 0 1 2 3
It always appears no matter what I use:
until
pan=FL+FR+FC+LFE|FL=FL|FR=FR|FC=FC|LFE=LFE
And
[Parsed_amerge_5 @ 000002ac9b81ce00] Input channel layouts overlap: output layout will be determined by the number of distinct input channels
But any attempt to specify the correct channel layout for the surround channels, instead 'stereo', like:
pan=SL+SR...,compand...
or
aformat=channel_layouts=SL+SR
abort the process.
2) I suggest use for 6.1 -> 5.1 downmix:
-filter_complex "asplit [f][s]; [f] pan=3.1|c0=c0|c1=c1|c2=c2|c3=c3 [r]; [s] pan=stereo|c0=0.412*c4+0.588*c5|c1=0.412*c4+0.588*c6, compand=attacks=0:decays=0:points=-90/-85.4|-8/-3.4|-5/-1|-0/-0.1, aformat=channel_layouts=stereo [d]; [r][d] amerge [z]" -map "[z]"
Old 22nd February 2023, 13:53   #51  |  Link
Balling
What do you suggest should happen with Back Centre channel? We do not support mixing that into back channels.
https://trac.ffmpeg.org/ticket/10207#comment:4
Old 22nd February 2023, 15:50   #52  |  Link
tebasuna51
tebasuna51's Avatar
Your sample is a problematic AAC 6.0 (MediaInfo and faad inform with channel layout L R C Cb Lb Rb).
qaac can't decode it: ERROR: Not available input file format
NeroAacDec decode it in wrong (I suposse) channel order (maybe FL FC FR SL BC SR) without channel mask.
faad seems decode it without channel mask with the order FL FR FC BC SL SR
ffmpeg decode it like 5.1 but with channel mask 0 in the same order than faad.
To convert that 6.0 to 5.1 I suggest try:
-filter_complex "asplit [f][s]; [f] pan=3.1|c0=c0|c1=c1|c2=c2|c3=0.0*c3 [r]; [s] pan=stereo|c0=0.412*c3+0.588*c4|c1=0.412*c3+0.588*c5, compand=attacks=0:decays=0:points=-90/-85.4|-8/-3.4|-5/-1|-0/-0.1, aformat=channel_layouts=stereo [d]; [r][d] amerge [z]" -map "[z]"
Old 23rd February 2023, 14:07   #53  |  Link
Balling
channel layout L R C Cb Lb Rb, yep, where Cb is back center. Wav does support that channel. https://learn.microsoft.com/en-us/wi...rmatextensible
So your command puts back center where?
Old 23rd February 2023, 22:35   #54  |  Link
tebasuna51
tebasuna51's Avatar
Half mixed in surround channels, make a fantom back center.
downmix, phase shift
