#1 | Link |
film gate wave/shaking in part of frame
Im working in this movie that shows some strange artifacts. I thought it was shaking, but if you pay attention to the second 8 you can see that the chimney moves related to the wall next to it. Is a bad deinterlace what made this? How can I fix it? I have no idea, so any help is more than welcome.
38 Mb http://www.sendspace.com/file/olybyr
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 17th May 2010 at 16:56. Reason: title |
#3 | Link |
All old anime have this problem, where the entire frame shakes on playback AND some of the objects in the frame shake up and down as well, it's just the way it is. The one in your sample wasn't that bad, I've seen worse in my collection.
I've a thread about this before and ended up with this, it works well on my 3 samples before. The stab function took care of the global shakes, and the rest of the script stabilize the inner shakes. |
#4 | Link | |
Yes, I had read that thread too, but I thought you were dealing with deshake+denoise. Now trying to test it, Im converting everything to MVTools 2, but I dont know what refframes is supposed to be in MAnalyse.
I will use Deshaker by Gunnar also, as stab (that is Depan) never gave me good results. Edit: I see, refframes is the Mdegrain2, Mdegrain3 thing, right? How can I translate that? So far this is how Im adapting it: Quote:
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 30th April 2010 at 13:57. |
#6 | Link |
yes, I have it. But Id to stick to my everyday plugins. Cant it be done with MVTools 2.0?
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread |
#8 | Link | |
######################################################## _fft = 2 _thSAD = 100 _bs = 16 _ov = 4 osuper = MSuper() asuper = FFT3DFilter(sigma=_fft, plane=4, bw=32, bh=32, ow=8, oh=8, bt=3, ncpu=2).MSuper() b3v = MAnalyse(asuper, isb=true, delta=3, blocksize=_bs, overlap=_ov) b2v = MAnalyse(asuper, isb=true, delta=2, blocksize=_bs, overlap=_ov) b1v = MAnalyse(asuper, isb=true, delta=1, blocksize=_bs, overlap=_ov) f1v = MAnalyse(asuper, delta=1, blocksize=_bs, overlap=_ov) f2v = MAnalyse(asuper, delta=2, blocksize=_bs, overlap=_ov) f3v = MAnalyse(asuper, delta=3, blocksize=_bs, overlap=_ov) process = MDeGrain1(osuper, b1v, f1v, thSAD=_thSAD) # process = MDeGrain2(osuper, b1v, f1v, b2v, f2v, thSAD=_thSAD) # process = MDeGrain3(osuper, b1v, f1v, b2v, f2v, b3v, f3v, thSAD=_thSAD) mt_merge(process, mt_edge("min/max").RemoveGrain(19), U=3, V=3) ######################################################## Last edited by Stephen R. Savage; 1st May 2010 at 21:59. Reason: Typo |
#9 | Link | |
#10 | Link |
The main points of Josey Wells' "Multi" modification are:
- less typing. Instead of writing several lines with "vector1= / vector2= / ...etcetcetc... / vectorNN=", it's just one line for MVAnalyseMulti, and the result contains all the different vector clips in one single monolothic clip. - (much) wider temporal radius for MVDegrain is possible. With standard MVTools, you're basically limited to a temporal radius of maximally +/-3 frames. For ref=1/2/3, it's basically the same what you have with MVDegrain1/2/3. With the Multi version, you can easily use MVDegrain with a radius of 4, 5, 6, 7, ... (don't know how much are allowed at max). With standard MVtools, you'd have to do multiple instances of M(V)Degrain, and average them together. (Which BTW isn't exactly the same: averaging different MDegrain's gives more weight to the center frame.) - Multithreading. IIRC, MVAnalyseMulti has the possibility to spawn several threads for the vector search for each single frame. IMHO this is definetly the preferred way of MT, as far as MVTools is concerned. Combining standard MVTools with MT() is a compromise that comes with a drawback (spatial limitations, and overhead due to slice overlap). Combining standard MVTools with SetMTMode() is a compromise that comes with a drawback (system ressources. From the basic idea, SetMTMode with 4 threads is similar to running 4 scripts in parallel.) For my understanding, the way of MVToolsMulti is much nicer for Multi-Threading. When you're concerned it takes too long for one man to build one house, the solution of SetMTMode is to let 4 people build 4 houses simultaneously. The way of MVToolsMulti is to let 4 people build one house at a time. At least for building houses, the latter way definetly is the preferred one. For multithreading Avisynth, I think it should be, too ... but I'm not fully sure, there's lots of pitfalls and technical sideaspects which I can't rate sufficiently.
#11 | Link |
Im getting "wrong super clip (pseudoaudio) parameters" at first line of Manalyse. I fixed the blocksize to blksize, but the problem persists. By line checking I found out its FF3DFilter what triggers that message, but FF3DFilter works nice by itself if used alone so...
@ Didée: So up to vector3 its just the same that MVtools 2 quality wise, except the multithreading approach. I mean what do you normally use? Id stick with that lol
#12 | Link | ||
- Tell you what, I use exactly nothing. Toying a little here a little there, but thats not "usage". The rig is (was) just too slow to do anything.
#13 | Link |
I can't help you with fixing it, but I can explain this issue (I think!)
It looks like a very juddery telecine transfer that has been poorly stabilised later. Basically, the film has slipped around a lot in the telecine device, and the stabilisation done afterwards has not been entirely effective, so you get some parts that still move around a little. Film transfer technology has improved a lot since then. |
#14 | Link |
I see, its called jitter (in a different mean of shake), I think it refers to the intra-shaking/waving artifacts. This is one filter that removes it, but as my sample is not THAT bad Im unsure it would be worse than better. Normally is something to do with capturing signals interferences, which relies on hardware TBC stabilisation(?). This is a cool thread discussing the same matter. This one is another plugin (for another image processor) for the described case.
#16 | Link |
And dont you think this is a captured VHS source packed into a DVD?
#17 | Link |
No, it's definitely not VHS. More likely some sort of old broadcast format like U-Matic or Betacam (I don't know the age of the material to make a better guess).
Even if it was from VHS, it doesn't have that problem. |
#18 | Link | |
I have been nailing my script in respect of internal fluctuations. I found a script in the Despot manual which relates to this same matter, Im using the last example together with the script Stephen adapted for MVtools 2, in expect to get a strong stabilisation. Normally I pixel compare my frames with Photoshop, but I was getting a bit dizzy, so I tried ssim to get real values to check how much I was correcting. But I didnt get any change using both scripts together, although the first script alone works nice. I further checked and I couldnt manage to make the second script work alone, so Im missing a filter or something Im doing is wrong, any help to this?
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 9th May 2010 at 16:40. |
#19 | Link | |
As nobody tried to help me I blindly fiddled with the script and ended with this, ssim proves changes are greater than any of the scripts alone, my question is whether this concept is correct and if I can switch the mdegrain in bold with mflow or some kind of warper and how, as my intention is not to denoise at that stage but "unbake" "unwarp" "dejitter" or whatever you wanna call it. I cant desist!
#20 | Link |
I think that if you changed the thread title to "film gate wave / shaking in part of frame" (or something like that), you might get more responses. I only clicked on it by accident, but it's exactly what I'm dealing with at the moment, so I'll take a proper look.
Cheers, David. |
bake, dejitter, deshake, stab, wave |
