Old 16th February 2009, 05:05   #1  |  Link
sdsumike619
batch convert mono to stereo WAV files
I've been trying for the last hour to use BeSweet in its wizard and batch mode and cannot figure out how to do this. I have about a hundred 30 minute single channel mono 48,000 sample rate wav files that I need to convert to 44,100 two channel stereo wav so they can easily be burned to CD. Is there something out there that can do this for me? Or can someone shed some light on how to do it with BeSweet?
sdsumike619 is offline   Reply With Quote
Old 16th February 2009, 05:31   #2  |  Link
RunningSkittle
Skittle
RunningSkittle's Avatar
foobar2000 can!
RunningSkittle is offline   Reply With Quote
Old 16th February 2009, 05:33   #3  |  Link
sdsumike619
I thought foobar was just a player? It does encoding too?
Old 16th February 2009, 08:17   #4  |  Link
kypec
User of free A/V tools
kypec's Avatar
foobar2000 is NOT just a player. It allows tagging and conversion functions too (some encoders might need to be installed separately like FLAC or LAME but they're free so it doesn't matter really)
foobar2000 provides sleek and mighty GUI to those tools, which you can benefit from.
kypec is offline   Reply With Quote
Old 16th February 2009, 08:24   #5  |  Link
smok3
brontosaurusrex
smok3's Avatar
from batch it could be like
m2s.exe -l left.wav -r left.wav -o out.wav
:: then
ssrc --rate 41000 --twopass --dither 2 "out.wav" "out.ssrc.wav"
maybe you can even pipe this two together somehow.
m2s and ssrc should be found here
http://www.rarewares.org/
certain other member
smok3 is offline   Reply With Quote
Old 16th February 2009, 08:26   #6  |  Link
sdsumike619
I think foobar is working for me. I used the convert feature with the DSP, using "convert mono to stereo" and Resampler (PPHS) and it seems to have worked just fine. I'll explore it a bit more tomorrow. Thanks for the recommendation
batch, mono, rate, wave
