Old 28th May 2021, 12:34   #1  |  Link
DorianDiaconu
Gone Forever
DorianDiaconu's Avatar
Linux compatible alternatives?
Hi guys, I wasnít sure in which category will this fit, so sorry if I posted it wrong.
Is there any alternative for VirtualDub2 on Linux?
My usual workflow on Windows is MPEG2CUT2 - Avisynth+ - Vdub, but I donít know about Linux.
Thanks!
DorianDiaconu is offline   Reply With Quote
Old 28th May 2021, 17:53   #2  |  Link
Richard1485
AviSynth monkey
Richard1485's Avatar
VirtualDub2 works fine for me under Wine. There's no exact equivalent on Linux. For handling scripts for the Linux build of AviSynth+, use ffplay for previewing and ffmpeg for rendering. You might also look at Avidemux; it might be able to replace some of VirtualDub2's functionality, depending on what exactly you use it for.
Richard1485 is offline   Reply With Quote
Old 28th May 2021, 18:48   #3  |  Link
qyot27
qyot27's Avatar
It's likely overkill, but if the system version of FFmpeg has AviSynth enabled, anything built against that FFmpeg - like kdenlive - will open the scripts. This being if you want the ability to visually cut against a timeline, although not in any way similar to how you'd do it in VDub.
avisynth, linux, vdub, virtualdub, windows
